The bonding function does not take effect
I found that after bonding, I could still connect to another board that had burned the same code.
Here is all of my code related to pairing and bonding.
Central:
///////////Added for bonding//////////
#include "peer_manager.h"
#include "peer_manager_handler.h"
#define SEC_PARAM_BOND              1                                   /**< Perform bonding. */
#define SEC_PARAM_MITM              1                                   /**< Enable MITM protection */
#define SEC_PARAM_LESC              0                                   /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS          0                                   /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES   BLE_GAP_IO_CAPS_DISPLAY_ONLY        /**< Display Only. */ //
#define SEC_PARAM_OOB               0                                   /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE      7                                   /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE      16                                  /**< Maximum encryption key size. */
//////////////Added for bonding///////
////////////Added for bonding///////////
// Static passkey
#define STATIC_PASSKEY    "123456"
// static ble_opt_t    m_static_pin_option;
uint8_t passkey[] = STATIC_PASSKEY;
    ret_code_t            err_code;
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_CONNECTED:
						NRF_LOG_INFO("BLE_GAP_EVT_CONNECTED.");
						err_code = pm_conn_secure(0x00, false);
						if (err_code != NRF_ERROR_BUSY)
						printf("a1DIS_CONs");
            NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                         p_gap_evt->conn_handle,
                         p_gap_evt->params.disconnected.reason);
            if (p_gap_evt->params.disconnected.reason == BLE_HCI_CONN_FAILED_TO_BE_ESTABLISHED)
								NRF_LOG_INFO("p_gap_evt->params.disconnected.reason == BLE_HCI_CONN_FAILED_TO_BE_ESTABLISHED");
                if (retry_count < max_retries)
                    NRF_LOG_INFO("Retrying connection attempt %d of %d", retry_count + 1, max_retries);
                    retry_count++;
                    scan_start(false);
                    NRF_LOG_ERROR("Max connection attempts reached");
                    retry_count = 0;
                retry_count = 0;
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
        /////////Remove for bonding///////////
       /* case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
            // Pairing not supported.
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            break;*/
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
//				case BLE_GAP_EVT_SEC_REQUEST:  /** 返回配对请求*/
//						ble_gap_sec_params_t sec_params;
//						memset(&sec_params,0,sizeof(ble_gap_sec_params_t));
//						err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle,BLE_GAP_SEC_STATUS_SUCCESS,&sec_params,NULL);
//						APP_ERROR_CHECK(err_code);
//        break;
				case BLE_GAP_EVT_AUTH_STATUS:
						if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS) {
								NRF_LOG_INFO("Pair success!");
						} else {
								NRF_LOG_INFO("Pair failed!");
								sd_ble_gap_disconnect(p_ble_evt->evt.gap_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
//    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            scan_start(false);
/////////////Added for bonding/////////////
//////////////Added for bonding//////////////
/**@brief Function for initializing the Peer Manager.
 * @param[in] erase_bonds  Indicates whether the bonding information must be cleared from
 *                         persistent storage during the initialization of the Peer Manager.
static void peer_manager_init()
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
Peripheral:
#define SEC_PARAM_MITM                  1                                       /**< Man In The Middle protection is enabled. */
#define SEC_PARAM_IO_CAPABILITIES   	BLE_GAP_IO_CAPS_KEYBOARD_ONLY      	/**< Keyboard Only. */
// Static passkey
    uint32_t err_code;
            NRF_LOG_INFO("Connected");
						data_array[2]=0;
            NRF_LOG_INFO("Disconnected");
						// LED1 ON
						err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
        } break;
        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
						sd_ble_gap_auth_key_reply(0x00, BLE_GAP_AUTH_KEY_TYPE_PASSKEY, passkey);
         /////////Removed for ebonding process//////////
        /*case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
            break;*/
  /*      case BLE_GATTS_EVT_SYS_ATTR_MISSING:
            break;*/
           /////////Removed for bonding process//////////
            // No implementation needed.
            advertising_start();
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    It is possible to bond with one device and still connect to new devices. However, it is possible (and the typical use case) to limit the possibility for new devices to connect after you are bonded with one (or more) devices. This is done by advertising with a whitelist. Please check out the ble_app_gls example for how to do this.
    Edvin
    When pairing, "case BLE_GAP_EVT_AUTH_STATUS:" is called in the central and "case
    BLE_GAP_EVT_AUTH_KEY_REQUEST:" is called in the peripheral.
    But when bonding, neither "case" will be called.
    So I want to know what is going to be called after the bonding because I want to do something after the full connection and
    the "case BLE_GAP_EVT_CONNECTED" is too early to meet my requirements.
    Whenever the connection is encrypted, you should see the event:
    PM_EVT_CONN_SEC_SUCCEEDED
    in pm_handler_pm_evt_log() (or in pm_handler_on_pm_evt, but this one doesn't log anything itself).
    Is that what you were asking for, or did I misunderstand?
    Edvin
