nRF52840 DK P1.11 & P1.12 can not be used.
Hello all,
I use nRF52840 for my custom board. I set P1.11 & P1.12 as UART_RX & UART_TX. But these two pins can not work.
Here is my nrf52840dk_nrf52840.overlay.
&pinctrl {
	uart0_default: uart0_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 1, 12)>;
		group2 {
			psels = <NRF_PSEL(UART_RX, 1, 11)>;
	uart0_sleep: uart0_sleep {
		group1 {
		group2 {
Here is my main.c.
 * Copyright (c) 2016 Intel Corporation
#include <stdio.h>
#include <zephyr/kernel.h>
/* 1000 msec = 1 sec */
#define SLEEP_TIME_MS   1000
/* The devicetree node identifier for the "led0" alias. */
#define LED0_NODE DT_ALIAS(led0)
#define LED1_NODE DT_ALIAS(led1)
 * A build error on this line means your board is unsupported.
 * See the sample documentation for information on how to fix this.
static const struct gpio_dt_spec led0 = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
static const struct gpio_dt_spec led1 = GPIO_DT_SPEC_GET(LED1_NODE, gpios);
void main(void)
	int ret;
	if (!device_is_ready(led0.port)) {
		return;
	if (!device_is_ready(led1.port)) {
		return;
	ret = gpio_pin_configure_dt(&led0, GPIO_OUTPUT_ACTIVE);
	if (ret < 0) {
		return;
	ret = gpio_pin_configure_dt(&led1, GPIO_OUTPUT_ACTIVE);
	if (ret < 0) {
		return;
	while (1) {
		ret = gpio_pin_toggle_dt(&led0);
		printf("blinky\n");
		ret = gpio_pin_toggle_dt(&led1);
		if (ret < 0) {
			return;
		k_msleep(SLEEP_TIME_MS);
My project build configuration is nrf52840dk_nrf52840.
Are these two pins used for other peripherals?
Thanks!
