I'm using an nRF52832 in SDK v.17.1.0 and, starting from the ble_app_uart example code, I'm sending data from the board to another device. I want monitoring it with an oscilloscope so I manage the code to invert the state of a led when a packet is arrived. I monitor the packets arrived with the debug terminal and it seems I receive all the packets (since the terminal say in this way) but not for the oscilloscope. So I think the issue come from the led which can't "follow" the signal (the scope is the maximum velocity so I stay on 1.5Mbps).
May you advise me to put a timer and how manage this timer to see on the terminal how much time the code spent to send all the packets?
This is the code:
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_delay.h"
#include "nrf_drv_spi.h"
#include "nrf_drv_gpiote.h"
#include "nrf_drv_timer.h"
#include "bsp.h"
#include "app_error.h"
#include "nrfx_timer.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "Nordic_UART" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
//#define CONN_INTERVAL_DEFAULT (uint16_t)(MSEC_TO_UNITS(50, UNIT_1_25_MS)) /**< Default connection interval used at connection establishment by central side. */
#define CONN_INTERVAL_MIN (uint16_t)(MSEC_TO_UNITS(400, UNIT_1_25_MS)) /**< Minimum acceptable connection interval, in units of 1.25 ms. */
#define CONN_INTERVAL_MAX (uint16_t)(MSEC_TO_UNITS(400, UNIT_1_25_MS)) /**< Maximum acceptable connection interval, in units of 1.25 ms. */
#define CONN_SUP_TIMEOUT (uint16_t)(MSEC_TO_UNITS(4000, UNIT_10_MS)) /**< Connection supervisory timeout (4 seconds). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define DATA_SIZE 6000
#define PACKET_SIZE (NRF_SDH_BLE_GATT_MAX_MTU_SIZE - 3)
#define SCHED_MAX_EVENT_DATA_SIZE APP_TIMER_SCHED_EVENT_DATA_SIZE
bool bleTxBusy = false;
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
static uint8_t data_to_send[DATA_SIZE];
static uint16_t remaining_length;
static uint16_t mandati;
static uint16_t pacchetto;
static uint8_t *data_ptr;
static bool data_ready_to_send = false;
//static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /
static ble_nus_t m_nus;
static uint32_t start_time;
static uint32_t end_time;
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.min_conn_interval = CONN_INTERVAL_MIN;
gap_conn_params.max_conn_interval = CONN_INTERVAL_MAX;
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
uint32_t err_code;
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
do
err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
} while (err_code == NRF_ERROR_BUSY);
if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
uint32_t err_code;
ble_nus_init_t nus_init;
// Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
static void uart_send_data()
uint32_t err_code;
uint16_t packet_length;
NRF_LOG_INFO("Sending data: %d remaining byte", remaining_length);
while (remaining_length > 0)
packet_length = (remaining_length > PACKET_SIZE) ? PACKET_SIZE : remaining_length;
NRF_LOG_INFO("Tentativo di inviare %d byte", packet_length);
err_code = ble_nus_data_send(&m_nus, data_ptr, &packet_length, m_conn_handle);
if (err_code == NRF_SUCCESS)
NRF_LOG_INFO("Data sent: %d byte", packet_length);
//bsp_board_led_on(BSP_BOARD_LED_2);
//nrf_delay_ms(1);
//bsp_board_led_off(BSP_BOARD_LED_2);
//nrf_delay_ms(1);
bsp_board_led_invert(BSP_BOARD_LED_2);
data_ptr += packet_length;
mandati += packet_length;
remaining_length -= packet_length;
NRF_LOG_INFO("To send: %d byte", remaining_length);
else if (err_code == NRF_ERROR_RESOURCES)
bleTxBusy = true;
NRF_LOG_INFO("Softdevice Buffer full. bleTxBusy = true");
NRF_LOG_ERROR("Error: 0x%X", err_code);
pacchetto++;
if (remaining_length==0)
NRF_LOG_INFO("Sent: %d byte", mandati);
NRF_LOG_INFO("Numero pacchetti: %d", pacchetto);
void tx_complete()
if (bleTxBusy)
bleTxBusy = false;
NRF_LOG_INFO("Resuming data transmission. bleTxBusy = false");
if (remaining_length > 0) {
uart_send_data();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
NRF_LOG_INFO("Disconnected");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_2MBPS,
.tx_phys = BLE_GAP_PHY_2MBPS,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
case BLE_GATTS_EVT_HVN_TX_COMPLETE:
NRF_LOG_INFO("BLE_GATTS_EVT_HVN_TX_COMPLETE evento ricevuto, riprendo invio dati");
tx_complete();
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
ret_code_t err_code;
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
case BSP_EVENT_KEY_1:
NRF_LOG_INFO("Pulsante 1 premuto");
NRF_LOG_WARNING("Connessione BLE non valida");
NRF_LOG_INFO("Preparing the buffer");
data_ptr = data_to_send;
remaining_length = DATA_SIZE;
data_ready_to_send = true;
uart_send_data();
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') ||
(data_array[index - 1] == '\r') ||
(index >= m_ble_nus_max_data_len))
if (index > 1)
do
} while (err_code == NRF_ERROR_RESOURCES);
index = 0;
case APP_UART_FIFO_ERROR:
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
/**@brief Application main function.
bool erase_bonds;
// Initialize.
uart_init();
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Start execution.
advertising_start();
// Enter main loop.
for (;;)
//app_sched_execute();
if (data_ready_to_send && !bleTxBusy)
uart_send_data();
idle_state_handle();
