publishing or subscribing to topic aws/certificates/create/json and aws/certificates/create/json/accepted fails with POLLHUP error to end up with aws iot disconnect event
I am trying to get provisioning by trusted user procedure of aws_iot working by making some changes in aws_iot nrf sample
I have tested it with permanent certificates and it works fine
But Whenever I try to connect to aws iot server with these topic
it fails with POLLHUP error, ending client connection be it with permanent certificates or with temp certificates (Used in provisioning by trusted device procedure)
Referring to similar issue I figured it has to do with Modem's limitation on handling big TLS buffers that are sent in response to this topic
( Issue Link: aws iot disconnect event when publishing to $aws/certificates/create/json )
Can we configure it, if not how can we develop a code where we can fetch permanent certs using temp certs with nrf platforms?
P.S. I am using the same aws_iot sample just changed the endpoint, client id and topics
Also I have made sure that AWS side things (provisioning template, policies etc.) are fine as it works for provisioning by trusted user for native ubuntu emulation of the device
