[LOGGER] LOG_INF dosen't print out in RTT
I am programming BLE with the nRF52840-DK. [Toolchain Manager: v1.3.0, IDE: Visual Studio Code (VSCode), SDK: ncs v2.6.0 ]
I want to debug using the Logger module. Printing with the 'printk' function works fine, but nothing is output when I use the 'LOG_INF' function.
I wonder what I'm doing wrong.
Additionally, I have another question. If I set the following in prj.conf:
CONFIG_LOG=y
CONFIG_LOG_BACKEND_RTT=n
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_PRINTK=n
Will the output from 'LOG_INF' be directed to' COM' instead of 'RTT'?
Is this different from the printk function?"
- Here is my 'main.c' code:
#include <zephyr/bluetooth/conn.h>
#include <zephyr/kernel.h>
#include <zephyr/settings/settings.h>
#include <bluetooth/services/nus.h>
#define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
#define PRIORITY 7
int count = 0;
#define LOG_MODULE_NAME cho
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
#define DEVICE_NAME "SEONGMIN"
#define DEVICE_NAME_LEN	(sizeof(DEVICE_NAME) - 1)
static K_SEM_DEFINE(ble_init_ok, 0, 1);
static struct bt_conn *current_conn;
static struct bt_conn *auth_conn;
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey){
	LOG_INF("Passkey for %s: %06u", addr, passkey);
static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey){
	auth_conn = bt_conn_ref(conn);
	LOG_INF("Press Button 1 to confirm, Button 2 to reject.");
static void auth_cancel(struct bt_conn *conn){
	LOG_INF("Pairing cancelled: %s", addr);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.passkey_confirm = auth_passkey_confirm,
	.cancel = auth_cancel,
static void pairing_complete(struct bt_conn *conn, bool bonded){
	LOG_INF("Pairing completed: %s, bonded: %d", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason){
	LOG_INF("Pairing failed conn: %s, reason %d", addr, reason);
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		LOG_INF("connected: Connection failed (err %u)", err);//printk("connected: Connection failed (err %u)\n", err);
		return;
	LOG_INF("Connected %s", addr); //printk("Connected %s\n", addr);
	current_conn = bt_conn_ref(conn);
	LOG_INF("Disconnected: %s (reason %u)", addr, reason); //printk("Disconnected: %s (reason %u)\n", addr, reason);
static void le_param_updated(struct bt_conn *conn, uint16_t interval,  uint16_t latency, uint16_t timeout)
	LOG_INF("Connection parameters updated.\n"
	       " interval: %d, latency: %d, timeout: %d\n",
	       interval, latency, timeout);
static void le_data_length_updated(struct bt_conn *conn, struct bt_conn_le_data_len_info *info){
	LOG_INF("LE data len updated: TX (len: %d time: %d)"
	       " RX (len: %d time: %d)\n", info->tx_max_len,
	       info->tx_max_time, info->rx_max_len, info->rx_max_time);
static struct bt_conn_cb conn_callbacks = {
	.connected    = connected,
	.disconnected = disconnected,
	.le_param_updated = le_param_updated,
	.le_data_len_updated = le_data_length_updated,
static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data, uint16_t len)
	char addr[BT_ADDR_LE_STR_LEN] = {0};
	bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
	LOG_INF("Received data from: %s", addr); //printk("Received data from: %s\n", addr);
//(*sent)(struct bt_conn *conn);
static void bt_sent_cb(struct bt_conn *conn){
	LOG_INF("bt_sent_cb");//printk("bt_sent_cb\n");
static struct bt_nus_cb nus_cb = {
	.received = bt_receive_cb,
	.sent = bt_sent_cb,
uint8_t data_to_central[244];
#define MTU_SIZE 64
int main(void){
	int err;
	for(int x=0; x<244; x++){
		data_to_central[x] = x;
	//printk("cho >> 240703_scan_adv_peripheral\n");
	LOG_INF("cho >> 240703_scan_adv_peripheral");
	bt_conn_cb_register(&conn_callbacks);
	err = bt_conn_auth_cb_register(&conn_auth_callbacks);  //success: 0
	//printk("bt_conn_auth_cb_register: %d\n",err);
	LOG_INF("bt_conn_auth_cb_register: %d",err);
	err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks); //success: 0
	//printk("bt_conn_auth_info_cb_register: %d\n",err);
	LOG_INF("bt_conn_auth_info_cb_register: %d",err);
	err = bt_enable(NULL);
	//printk("bt_enable: %d\n",err);
	LOG_INF("bt_enable: %d",err);
	k_sem_give(&ble_init_ok);
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_nus_init(&nus_cb);
	LOG_INF("bt_nus_init: %d",err);//printk("bt_nus_init: %d\n",err);
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
	LOG_INF("bt_le_adv_start: %d",err);	//printk("bt_le_adv_start: %d\n",err);
	for (;;) {
		k_sleep(K_MSEC(1000));
void ble_write_thread(void){
	k_sem_take(&ble_init_ok, K_FOREVER);
	for (;;){
		for(int y =0; y< 244; y++){
			if (bt_nus_send(NULL, data_to_central, MTU_SIZE)) {
				LOG_INF("."); //failed
			}else{
				LOG_INF("-"); //success
			LOG_INF("count: %d", count); //printk("count: %d\n", count);
			count++;
K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL, NULL, PRIORITY, 0, 0);
- Here is my 'prj.conf' code:
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="SEONGMIN"
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# This example requires more stack
CONFIG_MAIN_STACK_SIZE=1152
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_PRINTK=n
#CONFIG_LOG_PROCESS_THREAD=y
#CONFIG_LOG_DEFAULT_LEVEL=4
# Ensure sufficient buffer size for RTT
# CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
# CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
CONFIG_ASSERT=y
CONFIG_BT_USER_DATA_LEN_UPDATE=y
    Please make sure you have enabled all the necessary LOG configs in your prj.conf.
    Yes, this is true. If this is the prj.conf that you use, then  the output from LOG_INF will be directed to the UART (COM port) instead of RTT. This is because CONFIG_LOG_BACKEND_UART=y enables the UART backend for the logger, and CONFIG_LOG_BACKEND_RTT=n disables the RTT backend. Please take a look at this documentation.
    Yes, because the print_k is a function which is like a basic logger, i.e. it just logs. It does not require any backend. But on the other hand, the LOG_INF  is part of the Logger module and is more advanced with the requirement of a backend like UART or RTT and the logs will be directed to whichever backend you set up. Please refer this ticket.
    Priyanka
  • Thanks for providing the essential information!
    - here is main.c:
    #include "uart_async_adapter.h"
    #include <zephyr/types.h>
    #include <zephyr/kernel.h> // 세마포어 관련 헤더 파일
    #include <zephyr/drivers/uart.h>
    #include <zephyr/usb/usb_device.h>
    #include <zephyr/device.h>
    #include <soc.h>
    #include <zephyr/bluetooth/uuid.h>
    #include <zephyr/bluetooth/gatt.h>
    #include <zephyr/bluetooth/hci.h>
    #include <dk_buttons_and_leds.h>
    #include <stdio.h>
    #define LOG_MODULE_NAME peripheral_uart
    #define PRIORITY 7
    #define DEVICE_NAME CONFIG_BT_DEVICE_NAME
    #define RUN_STATUS_LED DK_LED1
    #define CON_STATUS_LED DK_LED2
    #define RUN_LED_BLINK_INTERVAL 1000
    #define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
    #define KEY_PASSKEY_REJECT DK_BTN2_MSK
    #define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
    #define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
    #define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
    // 세마포어 객체 정의 및 초기화
    static K_SEM_DEFINE(ble_init_ok, 0, 1); // 초기 값 0, 최대 값 1
    static const struct device *uart = DEVICE_DT_GET(DT_CHOSEN(nordic_nus_uart));
    static struct k_work_delayable uart_work;
    struct uart_data_t {
    	void *fifo_reserved;
    	uint8_t data[UART_BUF_SIZE];
    	uint16_t len;
    static K_FIFO_DEFINE(fifo_uart_tx_data);
    static K_FIFO_DEFINE(fifo_uart_rx_data);
    #if CONFIG_BT_NUS_UART_ASYNC_ADAPTER
    UART_ASYNC_ADAPTER_INST_DEFINE(async_adapter);
    #else
    static const struct device *const async_adapter;
    static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
    	ARG_UNUSED(dev);
    	static size_t aborted_len;
    	struct uart_data_t *buf;
    	static uint8_t *aborted_buf;
    	static bool disable_req;
    	switch (evt->type) {
    	case UART_TX_DONE:
    		LOG_DBG("UART_TX_DONE");
    		if ((evt->data.tx.len == 0) ||
    		    (!evt->data.tx.buf)) {
    			return;
    		if (aborted_buf) {
    			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
    					   data[0]);
    			aborted_buf = NULL;
    			aborted_len = 0;
    		} else {
    			buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t,
    					   data[0]);
    		k_free(buf);
    		buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
    		if (!buf) {
    			return;
    		if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
    			LOG_WRN("Failed to send data over UART");
    	case UART_RX_RDY:
    		LOG_DBG("UART_RX_RDY");
    		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data[0]);
    		buf->len += evt->data.rx.len;
    		if (disable_req) {
    			return;
    		if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
    		    (evt->data.rx.buf[buf->len - 1] == '\r')) {
    			disable_req = true;
    			uart_rx_disable(uart);
    	case UART_RX_DISABLED:
    		LOG_DBG("UART_RX_DISABLED");
    		disable_req = false;
    		buf = k_malloc(sizeof(*buf));
    		if (buf) {
    			buf->len = 0;
    		} else {
    			LOG_WRN("Not able to allocate UART receive buffer");
    			k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
    			return;
    		uart_rx_enable(uart, buf->data, sizeof(buf->data),
    			       UART_WAIT_FOR_RX);
    	case UART_RX_BUF_REQUEST:
    		LOG_DBG("UART_RX_BUF_REQUEST");
    		if (buf) {
    			buf->len = 0;
    			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
    		} else {
    	case UART_RX_BUF_RELEASED:
    		LOG_DBG("UART_RX_BUF_RELEASED");
    		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
    				   data[0]);
    		if (buf->len > 0) {
    			k_fifo_put(&fifo_uart_rx_data, buf);
    		} else {
    			k_free(buf);
    	case UART_TX_ABORTED:
    		LOG_DBG("UART_TX_ABORTED");
    		if (!aborted_buf) {
    			aborted_buf = (uint8_t *)evt->data.tx.buf;
    		aborted_len += evt->data.tx.len;
    		buf = CONTAINER_OF((void *)aborted_buf, struct uart_data_t,
    				   data);
    		uart_tx(uart, &buf->data[aborted_len],
    			buf->len - aborted_len, SYS_FOREVER_MS);
    static void uart_work_handler(struct k_work *item)
    	if (buf) {
    		buf->len = 0;
    	} else {
    		return;
    	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
    static bool uart_test_async_api(const struct device *dev)
    	const struct uart_driver_api *api =
    			(const struct uart_driver_api *)dev->api;
    	return (api->callback_set != NULL);
    static int uart_init(void)
    	int err;
    	int pos;
    	struct uart_data_t *rx;
    	struct uart_data_t *tx;
    	if (!device_is_ready(uart)) {
    		return -ENODEV;
    	if (IS_ENABLED(CONFIG_USB_DEVICE_STACK)) {
    		err = usb_enable(NULL);
    		if (err && (err != -EALREADY)) {
    			LOG_ERR("Failed to enable USB");
    			return err;
    	rx = k_malloc(sizeof(*rx));
    	if (rx) {
    		rx->len = 0;
    	} else {
    		return -ENOMEM;
    	k_work_init_delayable(&uart_work, uart_work_handler);
    	if (IS_ENABLED(CONFIG_BT_NUS_UART_ASYNC_ADAPTER) && !uart_test_async_api(uart)) {
    		/* Implement API adapter */
    		uart_async_adapter_init(async_adapter, uart);
    		uart = async_adapter;
    	err = uart_callback_set(uart, uart_cb, NULL);
    	if (err) {
    		k_free(rx);
    		LOG_ERR("Cannot initialize UART callback");
    		return err;
    	if (IS_ENABLED(CONFIG_UART_LINE_CTRL)) {
    		LOG_INF("Wait for DTR");
    		while (true) {
    			uint32_t dtr = 0;
    			uart_line_ctrl_get(uart, UART_LINE_CTRL_DTR, &dtr);
    			if (dtr) {
    			/* Give CPU resources to low priority threads. */
    			k_sleep(K_MSEC(100));
    		LOG_INF("DTR set");
    		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DCD, 1);
    		if (err) {
    			LOG_WRN("Failed to set DCD, ret code %d", err);
    		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DSR, 1);
    		if (err) {
    			LOG_WRN("Failed to set DSR, ret code %d", err);
    	tx = k_malloc(sizeof(*tx));
    	if (tx) {
    		pos = snprintf(tx->data, sizeof(tx->data),
    			       "Starting Nordic UART service example\r\n");
    		if ((pos < 0) || (pos >= sizeof(tx->data))) {
    			k_free(rx);
    			k_free(tx);
    			LOG_ERR("snprintf returned %d", pos);
    			return -ENOMEM;
    		tx->len = pos;
    	} else {
    		k_free(rx);
    		return -ENOMEM;
    	err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
    	if (err) {
    		k_free(rx);
    		k_free(tx);
    		LOG_ERR("Cannot display welcome message (err: %d)", err);
    		return err;
    	err = uart_rx_enable(uart, rx->data, sizeof(rx->data), UART_WAIT_FOR_RX);
    	if (err) {
    		LOG_ERR("Cannot enable uart reception (err: %d)", err);
    		/* Free the rx buffer only because the tx buffer will be handled in the callback */
    		k_free(rx);
    	return err;
    	if (err) {
    		LOG_ERR("Connection failed (err %u)", err);
    		return;
    	dk_set_led_on(CON_STATUS_LED);
    	if (auth_conn) {
    		bt_conn_unref(auth_conn);
    		auth_conn = NULL;
    	if (current_conn) {
    		bt_conn_unref(current_conn);
    		current_conn = NULL;
    		dk_set_led_off(CON_STATUS_LED);
    #ifdef CONFIG_BT_NUS_SECURITY_ENABLED
    static void security_changed(struct bt_conn *conn, bt_security_t level,
    			     enum bt_security_err err)
    	if (!err) {
    		LOG_INF("Security changed: %s level %u", addr, level);
    	} else {
    		LOG_WRN("Security failed: %s level %u err %d", addr,
    			level, err);
    BT_CONN_CB_DEFINE(conn_callbacks) = {
    	.security_changed = security_changed,
    #if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
    #else
    static struct bt_conn_auth_cb conn_auth_callbacks;
    static struct bt_conn_auth_info_cb conn_auth_info_callbacks;
    static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data, uint16_t len){
    	//	void (*received)(struct bt_conn *conn,const uint8_t *const data, uint16_t len);
    	int err;
    	for (uint16_t pos = 0; pos != len;) {
    		struct uart_data_t *tx = k_malloc(sizeof(*tx));
    		if (!tx) {
    			LOG_WRN("Not able to allocate UART send data buffer");
    			return;
    		/* Keep the last byte of TX buffer for potential LF char. */
    		size_t tx_data_size = sizeof(tx->data) - 1;
    		if ((len - pos) > tx_data_size) {
    			tx->len = tx_data_size;
    		} else {
    			tx->len = (len - pos);
    		memcpy(tx->data, &data[pos], tx->len);
    		pos += tx->len;
    		if ((pos == len) && (data[len - 1] == '\r')) {
    			tx->data[tx->len] = '\n';
    			tx->len++;
    		if (err) {
    			k_fifo_put(&fifo_uart_tx_data, tx);
    static struct bt_nus_cb nus_cb = {   //	void (*received)(struct bt_conn *conn,const uint8_t *const data, uint16_t len);
    void error(void)
    	dk_set_leds_state(DK_ALL_LEDS_MSK, DK_NO_LEDS_MSK);
    	while (true) {
    		/* Spin for ever */
    static void num_comp_reply(bool accept)
    	if (accept) {
    		bt_conn_auth_passkey_confirm(auth_conn);
    		LOG_INF("Numeric Match, conn %p", (void *)auth_conn);
    	} else {
    		bt_conn_auth_cancel(auth_conn);
    		LOG_INF("Numeric Reject, conn %p", (void *)auth_conn);
    	auth_conn = NULL;
    void button_changed(uint32_t button_state, uint32_t has_changed)
    	uint32_t buttons = button_state & has_changed;
    	if (auth_conn) {
    		if (buttons & KEY_PASSKEY_ACCEPT) {
    			num_comp_reply(true);
    		if (buttons & KEY_PASSKEY_REJECT) {
    			num_comp_reply(false);
    #endif /* CONFIG_BT_NUS_SECURITY_ENABLED */
    static void configure_gpio(void)
    	int err;
    		err = dk_buttons_init(button_changed);
    		if (err) {
    			LOG_ERR("Cannot init buttons (err: %d)", err);
    	err = dk_leds_init();
    	if (err) {
    		LOG_ERR("Cannot init LEDs (err: %d)", err);
    	int blink_status = 0;
    	int err = 0;
    	configure_gpio();
    	err = uart_init();
    	if (err) {
    		error();
    	LOG_INF("////////////////////////////////////////////////////////////////////");
    	printk("Dasdaadssssssssssssssssssssssssss\n");
    	if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
    		//페어링 과정에서 발생하는 다양한 인증 이벤트(예: 패스키 표시, 패스키 확인, Out Of Band (OOB) 데이터 처리) 처리하기 위한 함수 포인터
    		if (err) {
    			printk("Failed to register authorization callbacks.\n");
    			return 0;
    		//페어링 과정의 결과(예: 페어링 완료 또는 실패 이벤트)를 처리하기 위한 함수 포인터
    		if (err) {
    			printk("Failed to register authorization info callbacks.\n");
    			return 0;
    	if (err) {
    		error();
    	LOG_INF("Bluetooth initialized");
    		settings_load();
    	err = bt_nus_init(&nus_cb);  //nus_cb: callback
    	if (err) {
    		LOG_ERR("Failed to initialize UART service (err: %d)", err);
    		return 0;
    	if (err) {
    		LOG_ERR("Advertising failed to start (err %d)", err);
    		return 0;
    	for (;;) {
    		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
    		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
    	/* Don't go any further until BLE is initialized */
    	for (;;) {
    		/* Wait indefinitely for data to be sent over bluetooth */
    		struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data, K_FOREVER);
    		if (bt_nus_send(NULL, buf->data, buf->len)) {
    			LOG_WRN("Failed to send data over BLE connection");
    		k_free(buf);
    - here is prj.conf:
    # Copyright (c) 2018 Nordic Semiconductor
    CONFIG_SERIAL=y
    CONFIG_GPIO=y
    CONFIG_CONSOLE=y
    CONFIG_BT=y
    CONFIG_BT_DEVICE_NAME="Nordic_UART_Service"
    CONFIG_BT_NUS=y
    # Enable bonding
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    # Enable DK LED and Buttons library
    CONFIG_DK_LIBRARY=y
    # Config logger
    #CONFIG_LOG=y
    #CONFIG_USE_SEGGER_RTT=y
    #CONFIG_LOG_BACKEND_RTT=y
    #CONFIG_LOG_BACKEND_UART=n
    #CONFIG_LOG_PRINTK=n
    CONFIG_ASSERT=y
    #  CONFIG_LOG=y
    # CONFIG_USE_SEGGER_RTT=y
    # CONFIG_LOG_BACKEND_RTT=y
    # CONFIG_LOG_BACKEND_UART=n
    # CONFIG_LOG_PRINTK=n
    CONFIG_LOG=y
    CONFIG_LOG_MODE_IMMEDIATE=y
    CONFIG_LOG_PRINTK=y
    I have a few additional questions. Above are the main.c and prj.conf for Bluetooth: Peripheral UART. However, I notice that the debug output stops in RTT.
    *** Booting nRF Connect SDK v3.5.99-ncs1 ***
    [00:00:00.001,129] <inf> peripheral_uart: ////////////////////////////////////////////////////////////////////
    [00:00:00.008,666] <inf> fs_nvs: 8 Sectors of 4096 bytes
    [00:00:00.008,972] <inf> fs_nvs: alloc wra: 0, f50
    [00:00:00.009,277] <inf> fs_nvs: data wra: 0, 144
    [00:00:00.009,765] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                                36 f0 e5 0e 87 68 48 fb  02 fd 9f 82 cc 32 e5 7b |6....hH. .....2.{
                                                91 b1 5c ed                                      |..\.
    [00:00:00.015,014] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.015,411] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:00.015,747] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
    [00:00:00.016,876] <in*** Booting nRF Connect SDK v3.5.99-ncs1 ***
                                                91 b1 5c ed                                      |..\.
    [00:00:00.015,777] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
    1. I'm curious about the mechanism behind this issue. Could you recommend a website where I can learn the basics(logging system)? (If I understand the basic concepts, I think I can better understand the 'Logging in nRF Connect SDK' Kconfig option.)
    2. Do the contents of the log buffer get destroyed when they are output to RTT, or are they preserved? (I think they are likely destroyed.)
    Apologies for the delay as I was away on sick leave.
    I would suggest you to take a look at the nRF Connect SDK Fundamentals course in the Devacademy which might be of help.
    Also, the contents in the RTT operate in a first in first out basis, so if the buffer if full, and you attempt to write again, the oldest log will be cleared to make space for the latest log.
    Hope this helps.
    Priyanka
  • oh..I hope you get well soon...
    nRF Connect SDK Fundamentals is too basic. I’ll need to get additional information on my own through RTT and by Googling.
    thank you!
