Hello, I built a matter-over-thread firmware for nrf52840 on the Matter SDK 1.3-sve branch and NCS 2.5.0 version. It work well with Apple, Google and chip-tool, but commissioning fails with Amazon Alexa. For comparison, I built a 1.3-sve lighting-app example for testing and observed the same issue.
I found some suggestions in Amazon Developer and try to enable CHIP_ENABLE_ROTATING_DEVICE_ID, but it didn't work.
The logs of the device are provided as attachments
[13:24:12.176]收←◆ uart:~$ *** Booting nRF Connect SDK v2.5.0 *** I: Init CHIP stack [13:24:12.300]收←◆I: 216 [DL]BLE address: F5:4D:11:82:91:AE I: 225 [DL]OpenThread started: OK I: 228 [DL]Setting OpenThread device type to ROUTER I: 234 [SVR]Subscription persistence not supported I: 238 [SVR]Server initializing... I: 241 [TS]Last Known Good Time: [unknown] I: 245 [TS]Setting Last Known Good Time to firmware build time 2023-10-14T01:16:48 I: 257 [DMG]AccessControl: initializing I: 261 [DMG]Examples::AccessControlDelegate::Init I: 265 [DMG]AccessControl: setting I: 268 [DMG]DefaultAclStorage: initializing I: 272 [DMG]DefaultAclStorage: 0 entries loaded D: 276 [IN]UDP::Init bind&listen port=5540 E: 280 [IN]SO_REUSEPORT failed: 109 D: 283 [IN]UDP::Init bound to port=5540 D: 287 [IN]BLEBase::Init - setting/overriding transport D: 292 [IN]TransportMgr initialized D: 303 [DL]Using Thread extended MAC for hostname. I: 312 [ZCL]Using ZAP configuration... I: 322 [DMG]AccessControlCluster: initializing I: 327 [ZCL]Initiating Admin Commissioning cluster. D: 331 [DL]Boot reason: 6 E: 334 [ZCL]DeviceInfoProvider is not registered E: 338 [ZCL]Trying to write invalid Calendar Type E: 343 [ZCL]Failed to write calendar type with error: 0x87 I: 348 [ZCL]Endpoint 1 On/off already set to new value I: 357 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1 D: 376 [IN]SecureSession[0x20002e08]: Allocated Type:1 LSID:41090 D: 382 [DL]CHIPoBLE advertising set to on I: 386 [DIS]Updating services using commissioning mode 1 E: 391 [DIS]Failed to remove advertised services: 3 D: 396 [DL]Using Thread extended MAC for hostname. I: 401 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 cp=0 E: 410 [DIS]Failed to advertise commissionable node: 3 E: 415 [DIS]Failed to finalize service update: 3 I: 419 [DIS]Updating services using commissioning mode 1 E: 424 [DIS]Failed to remove advertised services: 3 D: 429 [DL]Using Thread extended MAC for hostname. I: 433 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 cp=0 E: 443 [DIS]Failed to advertise commissionable node: 3 E: 447 [DIS]Failed to finalize service update: 3 I: 452 [IN]CASE Server enabling CASE session setups D: 457 [IN]SecureSession[0x20002ed8]: Allocated Type:2 LSID:41091 I: 462 [SVR]Joining Multicast groups I: 466 [SVR]Server Listening... I: 469 [DL]Device Configuration: I: 472 [DL] Serial Number: 11223344556677889900 I: 476 [DL] Vendor Id: 65521 (0xFFF1) I: 479 [DL] Product Id: 32773 (0x8005) I: 483 [DL] Product Name: not-specified I: 487 [DL] Hardware Version: 0 I: 490 [DL] Setup Pin Code (0 for UNKNOWN/ERROR): 20202021 I: 495 [DL] Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00) I: 501 [DL] Manufacturing Date: 2022-01-01 I: 505 [DL] Device Type: 65535 (0xFFFF) I: 509 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00] I: 513 [SVR]Copy/paste the below URL in a browser to see the QR Code: I: 520 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A6FCJ142C00KA0648G00 I: 529 [SVR]Manual pairing code: [34970112332] I: 533 [DL]CHIP task running I: 538 [DL]CHIPoBLE advertising started I: 553 [ZCL]Cluster OnOff: attribute OnOff set to 0 I: 558 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254 I: 564 [DL]NFC Tag emulation started [13:24:42.620]收←◆I: 30541 [DL]CHIPoBLE advertising mode changed to slow I: 30549 [DL]CHIPoBLE advertising started [13:24:48.070]收←◆I: 35998 [DL]BLE connection established (ConnId: 0x00) I: 36003 [DL]Current number of connections: 1/1 I: 36007 [DL]CHIPoBLE advertising stopped I: 36011 [DL]NFC Tag emulation stopped [13:24:48.478]收←◆D: 36397 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 36404 [BLE]local and remote recv w [13:24:48.509]收←◆indow sizes = 5 I: 36409 [BLE]selected BTP version 4 I: 36413 [BLE]using BTP fragment sizes rx 244 / tx 244. D: 36418 [DL]ConnId: 0x00, New CCCD value: 0x0002 D: 36423 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6) D: 36431 [IN]BLE EndPoint 0x2000fe70 Connection Complete I: 36436 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247) [13:24:48.548]收←◆D: 36457 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 36465 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 36472 [EM]>>> [E:30615r S:0 M:6318620] (U) Msg RX from 0:22D8BFE7E44A60DD [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) I: 36485 [EM]<<< [E:30615r S:0 M:222745862] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) D: 36498 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 159) I: 36506 [SVR]Commissioning session establishment step started D: 36532 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:24:48.684]收←◆D: 36608 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 36615 [EM]>>> [E:30615r S:0 M:6318621] (U) Msg RX from 0:22D8BFE7E44A60DD [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1) [13:24:50.361]收←◆I: 38287 [EM]<<< [E:30615r S:0 M:222745863] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2) D: 38299 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132) E: 38307 [DL]Long dispatch time: 1700 ms, for event type 16388 [13:24:50.439]收←◆D: 38362 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:24:50.579]收←◆D: 38497 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 38505 [EM]>>> [E:30615r S:0 M:6318622] (U) Msg RX from 0:22D8BFE7E44A60DD [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3) I: 38517 [EM]<<< [E:30615r S:0 M:222745864] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport) D: 38529 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35) I: 38537 [SC]SecureSession[0x20002e08, LSID:41090]: State change 'kEstablishing' --> 'kActive' D: 38546 [IN]SecureSession[0x20002e08]: Activated - Type:1 LSID:41090 D: 38552 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:41090 PSID:62749! I: 38561 [SVR]Commissioning completed session establishment step I: 38567 [DIS]Updating services using commissioning mode 0 E: 38572 [DIS]Failed to remove advertised services: 3 E: 38577 [DIS]Failed to finalize service update: 3 D: 38581 [DL]CHIPoBLE advertising set to off I: 38585 [SVR]Device completed Rendezvous process D: 38591 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 38598 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 38606 [EM]>>> [E:30616r S:41090 M:86087612] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 38619 [FS]GeneralCommissioning: Received ArmFailSafe (80s) I: 38626 [EM]<<< [E:30616r S:41090 M:186276308] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 38638 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) [13:24:50.799]收←◆D: 38722 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 38730 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 38738 [EM]>>> [E:30617r S:41090 M:86087613] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 38749 [IM]Received Read request I: 38754 [EM]<<< [E:30617r S:41090 M:186276309] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 38765 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72) [13:24:50.940]收←◆D: 38857 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 38865 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 38873 [EM]>>> [E:30618r S:41090 M:86087614] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 38884 [IM]Received Read request I: 38889 [EM]<<< [E:30618r S:41090 M:186276310] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 38900 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) [13:24:51.065]收←◆D: 38992 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 39000 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 39008 [EM]>>> [E:30619r S:41090 M:86087615] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 39019 [IM]Received Read request I: 39028 [EM]<<< [E:30619r S:41090 M:186276311] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 39040 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) [13:24:51.206]收←◆D: 39127 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 39135 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 39143 [EM]>>> [E:30620r S:41090 M:86087616] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 39161 [EM]<<< [E:30620r S:41090 M:186276312] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 39173 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) [13:24:51.331]收←◆D: 39262 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 39270 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 39278 [EM]>>> [E:30621r S:41090 M:86087617] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 39290 [ZCL]OpCreds: Certificate Chain request received for DAC I: 39299 [EM]<<< [E:30621r S:41090 M:186276313] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 39312 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) [13:24:51.567]收←◆D: 39486 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 39494 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) [13:24:51.661]收←◆D: 39577 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 39584 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 77) [13:24:51.739]收←◆D: 39667 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 39675 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 39683 [EM]>>> [E:30622r S:41090 M:86087618] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 39695 [ZCL]OpCreds: Certificate Chain request received for PAI I: 39704 [EM]<<< [E:30622r S:41090 M:186276314] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 39717 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) [13:24:51.881]收←◆D: 39802 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 39809 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) [13:24:51.975]收←◆D: 39892 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 39899 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 48) [13:24:52.053]收←◆D: 39982 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 39990 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 39998 [EM]>>> [E:30623r S:41090 M:86087619] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 40010 [ZCL]OpCreds: Received an AttestationRequest command [13:24:52.131]收←◆I: 40050 [ZCL]OpCreds: AttestationRequest successful. I: 40059 [EM]<<< [E:30623r S:41090 M:186276315] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 40071 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) [13:24:52.241]收←◆D: 40162 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 40169 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) [13:24:52.335]收←◆D: 40252 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 40260 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 237) [13:24:52.413]收←◆D: 40342 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:24:52.866]收←◆D: 40792 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 40800 [EM]>>> [E:30624r S:41090 M:86087620] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 40813 [FS]GeneralCommissioning: Received ArmFailSafe (300s) I: 40820 [EM]<<< [E:30624r S:41090 M:186276316] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 40832 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) [13:24:53.054]收←◆D: 40972 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:24:55.571]收←◆D: 43492 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:24:58.071]收←◆D: 45999 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:24:58.134]收←◆D: 46057 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:24:59.400]收←◆D: 47317 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 47326 [EM]>>> [E:30625r S:41090 M:86087621] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 47338 [ZCL]OpCreds: Received a CSRRequest command [13:24:59.588]收←◆I: 47511 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded [13:24:59.635]收←◆I: 47551 [ZCL]OpCreds: CSRRequest successful. I: 47557 [EM]<<< [E:30625r S:41090 M:186276317] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 47569 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) E: 47577 [DL]Long dispatch time: 260 ms, for event type 16388 [13:24:59.713]收←◆D: 47632 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 47639 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 138) [13:24:59.792]收←◆D: 47722 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:00.918]收←◆D: 48849 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:01.012]收←◆D: 48937 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 48947 [EM]>>> [E:30626r S:41090 M:86087622] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 48959 [ZCL]OpCreds: Received an AddTrustedRootCertificate command [13:25:01.106]收←◆I: 49028 [ZCL]OpCreds: AddTrustedRootCertificate successful. I: 49034 [EM]<<< [E:30626r S:41090 M:186276318] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 49046 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68) E: 49054 [DL]Long dispatch time: 117 ms, for event type 16388 [13:25:01.199]收←◆D: 49116 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 49125 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:01.293]收←◆D: 49209 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:01.371]收←◆D: 49298 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 49309 [EM]>>> [E:30627r S:41090 M:86087623] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 49321 [ZCL]OpCreds: Received an AddNOC command I: 49328 [FP]Validating NOC chain [13:25:01.528]收←◆I: 49456 [FP]NOC chain validation successful I: 49460 [FP]Added new fabric at index: 0x1 I: 49464 [FP]Assigned compressed fabric ID: 0xE24B3D6E44BC5B31, node ID: 0x036176B7CD5FA7E0 I: 49472 [TS]Last Known Good Time: 2023-10-14T01:16:48 I: 49477 [TS]New proposed Last Known Good Time: 2024-07-04T04:25:01 I: 49483 [TS]Updating pending Last Known Good Time to 2024-07-04T04:25:01 [13:25:01.606]收←◆I: 49522 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0xFFFFFFFD0011002A D: 49531 [DL]Using Thread extended MAC for hostname. I: 49536 [DIS]Advertise operational node E24B3D6E44BC5B31-036176B7CD5FA7E0 I: 49542 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC I: 49550 [EM]<<< [E:30627r S:41090 M:186276319] (S) Msg TX to 1:FFFFFFFB00000000 [5B31] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 49562 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) E: 49569 [DL]Long dispatch time: 271 ms, for event type 16388 [13:25:01.732]收←◆D: 49656 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 49665 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 49673 [EM]>>> [E:30628r S:41090 M:86087624] (S) Msg RX from 1:FFFFFFFB00000000 [5B31] --- Type 0001:08 (IM:InvokeCommandRequest) E: 49685 [DMG]Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0000 status 0x85 (no additional context) I: 49695 [EM]<<< [E:30628r S:4109 [13:25:01.794]收←◆0 M:186276320] (S) Msg TX to 1:FFFFFFFB00000000 [5B31] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 49708 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68) [13:25:01.873]收←◆D: 49792 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:04.351]收←◆D: 52266 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:06.859]收←◆D: 54774 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:25:06.907]收←◆D: 54832 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:09.378]收←◆D: 57306 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:11.898]收←◆D: 59814 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:25:11.945]收←◆D: 59872 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:14.419]收←◆D: 62346 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:16.936]收←◆D: 64854 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:25:16.983]收←◆D: 64911 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:19.469]收←◆D: 67386 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:21.970]收←◆D: 69893 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:25:22.032]收←◆D: 69951 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:24.503]收←◆D: 72426 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:27.018]收←◆D: 74933 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:25:27.071]收←◆D: 74991 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:29.536]收←◆D: 7746 [13:25:29.560]收←◆6 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:32.050]收←◆D: 79973 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:25:32.110]收←◆D: 80031 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:34.591]收←◆D: 82506 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:37.093]收←◆D: 85013 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:25:37.154]收←◆D: 85071 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:39.631]收←◆D: 87546 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:42.130]收←◆D: 90054 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:25:42.192]收←◆D: 90111 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:44.670]收←◆D: 92586 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:47.166]收←◆D: 95094 [D [13:25:47.189]收←◆L]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:25:47.227]收←◆D: 95151 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:49.709]收←◆D: 97626 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:52.206]收←◆D: 100134 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:25:52.270]收←◆D: 100191 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:54.741]收←◆D: 102666 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:25:57.251]收←◆D: 105174 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:25:57.312]收←◆D: 105231 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:25:59.789]收←◆D: 107706 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:26:02.291]收←◆D: 110214 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:26:02.354]收←◆D: 110271 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:26:04.824]收←◆D: 112746 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:26:07.325]收←◆D: 115254 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:26:07.387]收←◆D: 115311 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:26:09.858]收←◆D: 117786 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:26:12.378]收←◆D: 120293 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:26:12.425]收←◆D: 120351 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:26:14.896]收←◆D: 12 [13:26:14.927]收←◆2826 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:26:17.418]收←◆D: 125333 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:26:17.468]收←◆D: 125391 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:26:19.951]收←◆D: 127866 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:26:22.452]收←◆D: 130373 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:26:22.514]收←◆D: 130431 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:26:24.985]收←◆D: 132905 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:26:27.488]收←◆D: 135413 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) [13:26:27.550]收←◆D: 135471 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) [13:26:30.024]收←◆D: 137945 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) [13:26:32.533]收←◆D: 140453 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 140466 [DL]ConnId: 0x00, New CCCD value: 0x0000 D: 140470 [IN]Clearing BLE pending packets. I: 140474 [BLE]Releasing end point's BLE connection back to application. I: 140481 [DL]Closing BLE GATT connection (ConnId 00) D: 140511 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) E: 140518 [BLE]no endpoint for BLE sent data ack [13:26:32.685]收←◆I: 140600 [DL]BLE GAP connection terminated (reason 0x16) I: 140605 [DL]Current number of connections: 0/1
