Cryptocell and usb
I was building the "console" sample code found in zephyr for my custom nrf52840 board and I managed to get it to work. But as soon as cryptocell gets enabled, it doesn't work anymore.
Q1:  Why doesn't the devicetree find "nordic,cryptocell"? I get a warning like this: Unknown node type "nordic,cryptocell"
- This also applies to nrf52840 Dongle and DK.
Q2: Cryptocell is enabled by default in nrf52840 devicetree which gets applied to all the boards (like nrf52840dongle and nrf52840dk and my custom board which uses nrf52840dongle as template). But this breaks the usb communication with the "console" sample on my custom board (It does build though).
- I can't test it with other boards since I only have nrf52dk and it doesn't support usb.
- I'm flashing it through mcuboot so I don't have access to debugger and I'm scared to use the nrf52dk as debugger since it already has bricked 3/5 devices.
Q3: The acl node has also a warning: Address range collides with flash-controller@4001e000 (both start at 0x4001e000)
- But it still works with it enabled.
I'm running Manjaro kde with linux66 kernel, v2.6.1 toolchain with v2.6.1 SDK installed through vscode extension.
This is the configuration which works:
And prj.conf:
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT="Testing"
CONFIG_USB_DEVICE_PID=0x0851
CONFIG_USB_DEVICE_VID=0x884E
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_UART_LINE_CTRL=y
And board defconfig:
CONFIG_SOC_SERIES_NRF52X=y
CONFIG_SOC_NRF52840_QIAA=y
CONFIG_BOARD_NRF52840_CUSTOM=y
CONFIG_BOARD_ENABLE_DCDC=n
# 32K clock
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
# Enable MPU
CONFIG_ARM_MPU=y
# enable GPIO
CONFIG_GPIO=y
# Enable Zephyr application to be booted by MCUboot
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_DISABLE_FLASH_PATCH=y
    Can you elaborate on step 6?
    By clicking "devicetree" button in the vscode extension.
    Device could not be recognized as USB device. I have tested with cryptocell added to the app.overlay. Which modules specifically are you referring to and how did you disable them?
    So you got the same type of error as I got. Did you manage to figure out why? Did you istall the SDK from vscode extension? Which repo did you use? I noticed that the zephyr and the nrf-zephyr differ and especially with cryptocell. All my methods are by using the vscode extension and to replicate these you should use it too.
    Why did you add cryptocell to app.overlay? It should have been enabled by default.
    The modules seen in the devicetree picture! Did uou use the vscode method or cli? You can disable them from the devicetree gui.
    BR
    I have tested building part of the USB console sample in NCS v2.6.1 on nrf52840-dk. I have seen ACL, cryptocell, clock and power warnings. There were address collisions between ACL and flash-controller as well as between power and clock. Did you see the same warnings on nrf52840-dk?
    This can be fixed by adding following lines to the app.overlay file
    &cryptocell {
    	compatible = "arm,cryptocell-310";
    	status = "okay";
    Is USB communication broken when you disable cryptocell in app.overlay?
    &cryptocell {
    	status = "disabled";
    This is the same address collision warning that I have seen on the nrf52840-dk. Can you elaborate on "But it still works with it enabled"?
    Dejan
    This is more of workaround than a fix, but anyway this wasn't the actual problem.
    I have said that the software works when cryptocell is disabled in the board files, meaning theres something wrong with it when enabled. The question is what?
    You got the possible same error as I got so could you help?
    BR
    Regarding the warnings, they should be supressed in the build system pre_dt_board.cmake but probably not in VS Code.
    How did you test on your board that USB communication breaks when cryptocell is enabled?
    Dejan
  • Is this question simulator?? I have already told you these things...
    You replicated the same problem as I got and still refuse to help on it...
