Cryptocell and usb
I was building the "console" sample code found in zephyr for my custom nrf52840 board and I managed to get it to work. But as soon as cryptocell gets enabled, it doesn't work anymore.
Q1:  Why doesn't the devicetree find "nordic,cryptocell"? I get a warning like this: Unknown node type "nordic,cryptocell"
- This also applies to nrf52840 Dongle and DK.
Q2: Cryptocell is enabled by default in nrf52840 devicetree which gets applied to all the boards (like nrf52840dongle and nrf52840dk and my custom board which uses nrf52840dongle as template). But this breaks the usb communication with the "console" sample on my custom board (It does build though).
- I can't test it with other boards since I only have nrf52dk and it doesn't support usb.
- I'm flashing it through mcuboot so I don't have access to debugger and I'm scared to use the nrf52dk as debugger since it already has bricked 3/5 devices.
Q3: The acl node has also a warning: Address range collides with flash-controller@4001e000 (both start at 0x4001e000)
- But it still works with it enabled.
I'm running Manjaro kde with linux66 kernel, v2.6.1 toolchain with v2.6.1 SDK installed through vscode extension.
This is the configuration which works:
And prj.conf:
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT="Testing"
CONFIG_USB_DEVICE_PID=0x0851
CONFIG_USB_DEVICE_VID=0x884E
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_UART_LINE_CTRL=y
And board defconfig:
CONFIG_SOC_SERIES_NRF52X=y
CONFIG_SOC_NRF52840_QIAA=y
CONFIG_BOARD_NRF52840_CUSTOM=y
CONFIG_BOARD_ENABLE_DCDC=n
# 32K clock
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
# Enable MPU
CONFIG_ARM_MPU=y
# enable GPIO
CONFIG_GPIO=y
# Enable Zephyr application to be booted by MCUboot
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_DISABLE_FLASH_PATCH=y
    AintMina said:
    I have already told you these things...
    Yes, this is correct. You said that your device no longer gets recognized as a usb serial device and it is not found with NRF Connect or any other serial terminal software. I might have hoped for additional information.
    Did you get any console output from the sample when cryptocell was disabled and when it was enabled?
    AintMina said:
    You replicated the same problem as I got and still refuse to help on it...
    I am not sure if the cause of the problem in our testing is the same. I am not refusing to help you. On the contrary, I am doing further testing and having internal discussion trying to assist you. Are you able to send a software which can be run on nrf52840-dongle that would verify the behavior?
    Dejan
  • As I said, I don't have access to proper debugger, so the first test would be to figure out why you got the same ish problem and try to see if it's the same.
    Notify when you find a solution to the problem.
    BR
    Dejan is out office so I have taken over this case. Reading through this case I have problems understanding the issue. Can you please explain from the beginning the exact issue and how to reproduce it?
    PS: Regarding not having a debugger, that is essential for embedded development. I assume you have at least one as you are able to program it? And using the DK as a debugger should not brick your custom board in any way. If that was the case I suggest a separate thread about that (my guess would be a that you power the board before attacking the debugger with a common ground, but this would then be an issue regardless of which debugger you connected).
  • ...Im tired of explaining this already, read the posts... Build "console", *** works, enable cryptocell, *** no work!
    if you have more questions you have to be more specific
    I have read this thread again and I am unfrortunately not able to understand what the issue is and what you want us to do. Please provide a detailed set of step by step instructions of how to reproduce this issue on a DK if you want us to look more into this. Also please note that I do not try to be difficult, it is just that I am simply not able to understand the issue from reading this thread.
