Cryptocell and usb
I was building the "console" sample code found in zephyr for my custom nrf52840 board and I managed to get it to work. But as soon as cryptocell gets enabled, it doesn't work anymore.
Q1:  Why doesn't the devicetree find "nordic,cryptocell"? I get a warning like this: Unknown node type "nordic,cryptocell"
- This also applies to nrf52840 Dongle and DK.
Q2: Cryptocell is enabled by default in nrf52840 devicetree which gets applied to all the boards (like nrf52840dongle and nrf52840dk and my custom board which uses nrf52840dongle as template). But this breaks the usb communication with the "console" sample on my custom board (It does build though).
- I can't test it with other boards since I only have nrf52dk and it doesn't support usb.
- I'm flashing it through mcuboot so I don't have access to debugger and I'm scared to use the nrf52dk as debugger since it already has bricked 3/5 devices.
Q3: The acl node has also a warning: Address range collides with flash-controller@4001e000 (both start at 0x4001e000)
- But it still works with it enabled.
I'm running Manjaro kde with linux66 kernel, v2.6.1 toolchain with v2.6.1 SDK installed through vscode extension.
This is the configuration which works:
And prj.conf:
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT="Testing"
CONFIG_USB_DEVICE_PID=0x0851
CONFIG_USB_DEVICE_VID=0x884E
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_UART_LINE_CTRL=y
And board defconfig:
CONFIG_SOC_SERIES_NRF52X=y
CONFIG_SOC_NRF52840_QIAA=y
CONFIG_BOARD_NRF52840_CUSTOM=y
CONFIG_BOARD_ENABLE_DCDC=n
# 32K clock
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
# Enable MPU
CONFIG_ARM_MPU=y
# enable GPIO
CONFIG_GPIO=y
# Enable Zephyr application to be booted by MCUboot
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_DISABLE_FLASH_PATCH=y
  • I thought the problem was running the usb console sample with CryptoCell defined in your board files?
    No, the problem is that CC breaks ANY sample code. I remembered that I tested the bluetooth function to work WITH debugger not without.
    And if so, can we start with if you are using MCUboot, NSIB, both, or some custom bootloader?
    Im using MCUboot from the SDK with this config and CC disabled:
    CONFIG_PM=n
    CONFIG_MAIN_STACK_SIZE=10240
    CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
    CONFIG_BOOT_SWAP_SAVE_ENCTLV=n
    CONFIG_BOOT_ENCRYPT_IMAGE=n
    CONFIG_BOOT_UPGRADE_ONLY=n
    CONFIG_BOOT_BOOTSTRAP=n
    ### mbedTLS has its own heap
    # CONFIG_HEAP_MEM_POOL_SIZE is not set
    ### We never want Zephyr's copy of tinycrypt.  If tinycrypt is needed,
    ### MCUboot has its own copy in tree.
    # CONFIG_TINYCRYPT is not set
    # CONFIG_TINYCRYPT_ECC_DSA is not set
    # CONFIG_TINYCRYPT_SHA256 is not set
    CONFIG_FLASH=y
    CONFIG_FPROTECT=y
    ### Various Zephyr boards enable features that we don't want.
    # CONFIG_BT is not set
    # CONFIG_BT_CTLR is not set
    # CONFIG_I2C is not set
    CONFIG_LOG=y
    CONFIG_LOG_MODE_MINIMAL=y # former CONFIG_MODE_MINIMAL
    ### Ensure Zephyr logging changes don't use more resources
    CONFIG_LOG_DEFAULT_LEVEL=0
    ### Use info log level by default
    CONFIG_MCUBOOT_LOG_LEVEL_INF=y
    ### Decrease footprint by ~4 KB in comparison to CBPRINTF_COMPLETE=y
    CONFIG_CBPRINTF_NANO=y
    ### Use the minimal C library to reduce flash usage
    CONFIG_MINIMAL_LIBC=y
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    # IS BOOTLOADER?
    CONFIG_IS_BOOTLOADER=y
    CONFIG_BOOTLOADER_SRAM_SIZE=256
    CONFIG_MCUBOOT_INDICATION_LED=y
    # Required by USB
    CONFIG_MULTITHREADING=y
    # USB
    CONFIG_USB_DFU_CLASS=y
    CONFIG_USB_DEVICE_REMOTE_WAKEUP=n
    #### MAY FUCK UP YOUR DAY
    #CONFIG_USB_DFU_REBOOT=y
    CONFIG_USB_DEVICE_PRODUCT="MCUBOOT"
    CONFIG_USB_DEVICE_VID=0x1915
    CONFIG_USB_DEVICE_PID=0x520F
    CONFIG_BOOT_USB_DFU_GPIO=y
    CONFIG_BOOT_SERIAL_PIN_RESET=y
    # Serial
    CONFIG_CONSOLE=n
    CONFIG_SERIAL=y
    # MCUBoot serial
    CONFIG_GPIO=y
    CONFIG_MCUBOOT_SERIAL=y
    CONFIG_BOOT_SERIAL_CDC_ACM=y
    CONFIG_NORDIC_QSPI_NOR=n
    Also to add here, the same code works with CC disabled and uploaded through MCUboot.
    I see. I misunderstood this to be about USB and CryptoCell (I did not see any samples failing with your your board files, withou or without CryptoCell or debugging or not). But this is related to your MCUBoot configuration it seems? To test that, I took the zephy blinkyt sample from nRF Connect SDK 2.6.1 and did the following changes:
    Added to prj.conf:
    made a child_image/mcuboot.conf where I copy-pasted all configs from your last post. And as I am testing on the nRF52840 DK I modified nrf52840_qalmari.dts so that led0 is gpio P0.14 as that is a LED on the DK.
    So this is your board files (with the led0 pin changed) and your mcuboot configuration. However, the applciation is startd and works as expected. So I am unfortunately still not able to reproduce the issue.
    Can you explain more, and perhaps attach the application (all files including config files, CMakeLists.txt etc) that you are using?
  • Would you be able to test it without 32k clock CONNECTED to mcu?
    The nrf52dk doesnt have full CC and the only difference I can figure out is that you DK board has external 32k clock connected.
    Also I did figure out that the app breaks before EARLY, PRE_KERNEL_1 and PRE_KERNEL_2. I used LEDs as debug in those states.
    I also tried to enable usb logging in APPLICATION state and it worked, but when I enabled it in PRE or POST kernel, then my PRE kernel LED debug flashed really fast. So confirming that the app with CC enabled does not even reach kernel.
    Do you have any ideas if this could be a schematic problem?
    I double checked when I build with your board files, and both the bootloader and application are configured to use the LFRC (boards without crystals is also very common and as long as the LFRC is configured that should not cause problems).
    Regardign this being a HW issue I don't see anythign indicating it, but on the other hand it is difficult to understand this issue, so it could be worth while taking a look if you can shere your schematics (and perhaps also the layout).
  • Welp, I found the problem... Cryptocell HAS to be enabled in bootloader stage in order to have it enabled in app. So if you have mcuboot running without cryptocell you can only run apps without CC enabled in them.
