Non-blocking access to SD Card in nrf connect sdk? (SPIM/DMA/DiskAccess)
Hello!
im trying to write chunks of bytes to an sd card in a non blocking style. One possibility im pursuing is to use SPIM, where the actual writing is done by DMA-Controller and wont block the CPU.
I access the sd card from DiskAccess from zephyr, but this "path" only allows normal spi interactions which will block the CPU.
Question: Is there a possibility to implement SPIM with DiskAccess from zephyr, or is there maybe another way to write data to an sd card without blocking the CPU, or do i have to manually communicate with the SD card via SPI?
Kind regards
Daniel
PS: Im using nRF52833 DK with nRF Connect SDK 2.7
