Hi:
My environment is: nRF5_SDK_17.1.0_ddde560, keil, s113_nrf52_7.2.0_softdevice
When using usbd_cdc, I found that DTR must be set to start communication. Is there any way to not use DTR, because some software does not operate DTR.
Regards
Hi:
Regards
To remove the dependency on DTR I'm afraid you only option is to patch the USB implementation. There aren't exposed any configuration settings to disable it.
Here are some other posts about this which I think may be relevant:
nRF52 DK - USB CDC ACM Example not working with HTerm/Qt
Vidar
Hi ,
Thanks for your suggestion, I have realized this function by changing the SDK code.
When USB is turned on, setup_req_class_out
will be called. Here, p_cdc_acm_ctx->line_state |= APP_USBD_CDC_ACM_LINE_STATE_DTR|APP_USBD_CDC_ACM_LINE_STATE_RTS;
; can realize automatic opening of DTR. Although this may not be a good way, it can meet my needs.
