Problem implementing sleep mode, nrf_pwr_mgmt.h
We are connecting nrf boards to solar charged batteries for power consumption. We will be remotely deploying the boards on field. The boards are connected to sensors, from which we will be recording data periodically. We are sending data through thread network, via the command udp send. The board should work for long time. As solar is not guaranteed to work in cloudy days, or other weather constraints. So we want the board to switch off between each transmission to save maximum energy.
We tried to implement sleep mode in the code below, but the board never seems to sleep, or go in low power mode. we want to save as much power as we can between two data transfers. Please correct our code, or suggest a different approach to solve our problem.
power_manage() is the function we are using for implementing sleep mode. We are also using the nrf_pwr_mgmt.h header file.
Thanks and regards.
#include "app_scheduler.h"
#include "app_timer.h"
#include "bsp_thread.h"
#include "nrf_log_ctrl.h"
#include "nrf_log.h"
#include "nrf_delay.h"
#include "thread_utils.h"
#include <openthread/cli.h>
#include <openthread/thread.h>
#include <openthread/udp.h>
#include "dht11.h"
#include "bsp.h"
#include "nrfx_saadc.h"
#include "nrf_saadc.h"
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "boards.h"
#include "nrf_pwr_mgmt.h"
//#include "nrf_sdh.h"
//#include "nrf_sdh_soc.h"
#define SCHED_QUEUE_SIZE      32
#define SCHED_EVENT_DATA_SIZE APP_TIMER_SCHED_EVENT_DATA_SIZE
#define SAADC_CHANNEL1 0
#define SAADC_CHANNEL2 1
#define SAADC_CHANNEL3 2
#define timer_delay 15000
#define receiverIpV6Addr "fdde:ad00:beef:0:fcfc:2b1d:5870:1d1f"
#define boardID "n7"
char mystr[10] = "";
static void bsp_event_handler(bsp_event_t event);
APP_TIMER_DEF(m_our_char_timer_id);
#include "nrf_nvmc.h"
// Non-volatile memory address for storing power-fail flag
#define POWER_FAIL_FLAG_ADDR    (NRF_UICR->CUSTOMER[0])
// Power-fail flag value
#define POWER_FAIL_FLAG_VALUE   0xA5A5A5A5
static void timer_start_on_power_restore(void)
    if (POWER_FAIL_FLAG_ADDR == POWER_FAIL_FLAG_VALUE)
        // Power failure occurred, start the timer
        timer_start();
        // Clear the flag in non-volatile memory
        nrf_nvmc_write_word(POWER_FAIL_FLAG_ADDR, 0);
void saadc_init(void)
    ret_code_t err_code;
    nrf_saadc_channel_config_t channel1_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    nrf_saadc_channel_config_t channel2_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
    nrf_saadc_channel_config_t channel3_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel1_config);
    err_code = nrf_drv_saadc_channel_init(1, &channel2_config);
    err_code = nrf_drv_saadc_channel_init(2, &channel3_config);
nrf_saadc_value_t sample1;
nrf_saadc_value_t sample2;
nrf_saadc_value_t sample3;
void read_rain(int *samp1, int *samp2, int *samp3)
    nrfx_saadc_sample_convert(SAADC_CHANNEL1, &sample1);
    nrfx_saadc_sample_convert(SAADC_CHANNEL2, &sample2);
    nrfx_saadc_sample_convert(SAADC_CHANNEL3, &sample3);
    *samp1 = sample1;
    *samp2 = sample2;
    *samp3 = sample3;
static void thread_state_changed_callback(uint32_t flags, void *p_context)
    NRF_LOG_INFO("State changed! Flags: 0x%08x Current role: %d\r\n",
                 flags, otThreadGetDeviceRole(p_context));
static void timer_init(void)
    uint32_t err_code = app_timer_init();
///@brief Function for initializing the LEDs.
static void leds_init(void)
    LEDS_CONFIGURE(LEDS_MASK);
    LEDS_OFF(LEDS_MASK);
///@brief Function for initializing the nrf log module.
static void log_init(void)
///@brief Function for initializing the Thread Stack.
static void thread_instance_init(void)
    thread_configuration_t thread_configuration =
        .radio_mode = THREAD_RADIO_MODE_RX_ON_WHEN_IDLE,
        .autocommissioning = true,
        .autostart_disable = false,
    thread_init(&thread_configuration);
    thread_cli_init();
    thread_state_changed_callback_set(thread_state_changed_callback);
    uint32_t err_code = bsp_thread_init(thread_ot_instance_get());
///@brief Function for initializing scheduler module.
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
 * @section Main
int count=0;
bool udp=true;
void allCommands(){
    if (udp){
        char command2[] = "udp open\n";
        otCliConsoleInputLine(command2, strlen(command2));
        char command3[] = "udp bind :: 1234\n";
        otCliConsoleInputLine(command3, strlen(command3));
        udp = false;
void udp_send(const char *destAddr, const char *data)
    char command[256];
    sprintf(command, "udp send %s 1234 %s\n", destAddr, data);
    otCliConsoleInputLine(command, strlen(command));
static void timer_timeout_handler(void * p_context)
    NRF_LOG_FLUSH();
    if (udp) {
        allCommands();
    read_rain(&sample1, &sample2, &sample3);
    char myrain[50];
    sprintf(myrain, "%i:%i:%i:%s", sample1, sample2, sample3, ":t2");
    const char *receiverAddr = "fdde:ad00:beef:0:fcfc:2b1d:5870:1d1f";
    // replace with actual receiver address
    udp_send(receiverAddr, myrain);
    NRF_LOG_FLUSH();
void timer_start()
    err_code = app_timer_start(m_our_char_timer_id, APP_TIMER_TICKS(timer_delay), NULL);
void timer_stop()
    app_timer_stop(m_our_char_timer_id);
    switch (event)
    case BSP_EVENT_KEY_0:
        timer_start();
    case BSP_EVENT_KEY_1:
        timer_stop();
        timer_start();
        return; // no implementation needed
static void power_manage(void)
    LEDS_OFF(BSP_LED_0_MASK); // Turn off LED to indicate sleep mode
    // Enter System ON sleep mode
    __WFE();
    __SEV();
    __WFE();
    LEDS_ON(BSP_LED_0_MASK); // Turn on LED to indicate wake up
int main(int argc, char *argv[])
    log_init();
    saadc_init();
    scheduler_init();
    timer_init();
    leds_init();
    nrf_pwr_mgmt_init();
    uint32_t err_code = bsp_init(BSP_INIT_BUTTONS, bsp_event_handler);
    thread_instance_init();
    app_timer_create(&m_our_char_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
    timer_start();
    while (true)
        // Process Thread stack and application scheduler events
        thread_process();
        app_sched_execute();
        // Process logs
            power_manage();
