1. What is the antenna output of the DECT NR+? Is it the same pin as CAT-M/NBIoT antenna output? (i.e. pin 35)
2. In Section 8.3 of OPS document about DECT NR+, it mentioned: "Note: While running DECT NR+ firmware, the nRF9151 SiP does not support LTE modem....". So, is it possible to run DECT NR+ and Cat-M/NBIoT at the same time in a single firmware? If no, can we switch between DECT NR+ and Cat-M/NBIoT in a single firmware?
