Our application image became too large for TF-M and we're investigating the use of PSA Protected Storage without TF-M as described in NCS 2.6.0.
When writing a new slot when the storage size is too small, PSA_ERROR_STORAGE_FAILURE (-146) is returned. After a reset, it looks like all storage space is lost, no space at all anymore.
This is the prj.conf used in the test:
CONFIG_GPIO=y CONFIG_LOG=y CONFIG_LOG_DEFAULT_LEVEL=3 CONFIG_TRUSTED_STORAGE=y CONFIG_SETTINGS=y CONFIG_NVS=y CONFIG_FLASH=y CONFIG_FLASH_MAP=y CONFIG_HW_UNIQUE_KEY=y CONFIG_HW_UNIQUE_KEY_RANDOM=y CONFIG_NRF_SECURITY=y CONFIG_PSA_CRYPTO_DRIVER_CC3XX=n CONFIG_PSA_CRYPTO_DRIVER_OBERON=y CONFIG_MBEDTLS_PSA_CRYPTO_C=y CONFIG_MBEDTLS_ENABLE_HEAP=y CONFIG_MBEDTLS_HEAP_SIZE=16384 CONFIG_MAIN_STACK_SIZE=16384 CONFIG_PSA_PROTECTED_STORAGE=y
The code in src/main.c is the following:
* Copyright (c) 2016 Intel Corporation
#include <zephyr/kernel.h>
#include <zephyr/settings/settings.h>
#include <hw_unique_key.h>
#include <psa/crypto.h>
#ifdef CONFIG_BUILD_WITH_TFM
#include <tfm_crypto_defs.h>
#else /* CONFIG_BUILD_WITH_TFM */
#include <nrf_cc3xx_platform.h>
#endif /* CONFIG_BUILD_WITH_TFM */
#include <psa/storage_common.h>
#include <psa/protected_storage.h>
/* 1000 msec = 1 sec */
#define SLEEP_TIME_MS 200
/* The devicetree node identifier for the "led0" alias. */
#define LED0_NODE DT_ALIAS(led0)
#define TEST_STRING_1 "The quick brown fox jumps over the lazy dog"
#define APP_SUCCESS (0)
#define APP_ERROR (-1)
#define APP_SUCCESS_MESSAGE "Example finished successfully!"
#define APP_ERROR_MESSAGE "Example exited with error!"
LOG_MODULE_REGISTER(app, LOG_LEVEL_DBG);
* A build error on this line means your board is unsupported.
* See the sample documentation for information on how to fix this.
static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
int crypto_init(void)
#if !defined(CONFIG_BUILD_WITH_TFM)
int result = nrf_cc3xx_platform_init();
if (result != NRF_CC3XX_PLATFORM_SUCCESS) {
LOG_INF("nrf_cc3xx_platform_init returned error: %d", result);
return APP_ERROR;
if (!hw_unique_key_are_any_written()) {
LOG_INF("Writing random keys to KMU");
result = hw_unique_key_write_random();
if (result != HW_UNIQUE_KEY_SUCCESS) {
LOG_INF("hw_unique_key_write_random returned error: %d", result);
return APP_ERROR;
LOG_INF("Success!");
#if !defined(HUK_HAS_KMU)
/* Reboot to allow the bootloader to load the key into CryptoCell. */
sys_reboot(0);
#endif /* !defined(HUK_HAS_KMU) */
#endif /* !defined(CONFIG_BUILD_WITH_TFM) */
return APP_SUCCESS;
int ret;
int result = crypto_init();
if (result != APP_SUCCESS) {
LOG_INF(APP_ERROR_MESSAGE);
return APP_ERROR;
if (!device_is_ready(led.port)) {
return -1;
ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE);
if (ret < 0) {
return -1;
int rc = settings_subsys_init();
if (rc) {
printk("settings subsys initialization: fail (err %d)\n", rc);
return -1;
printk("settings subsys initialization: OK.\n");
uint32_t flags = psa_ps_get_support();
LOG_INF("psa_ps_get_support: %x (%d) - %x", flags, flags, PSA_STORAGE_SUPPORT_SET_EXTENDED);
psa_status_t status = PSA_SUCCESS;
int slot = 0;
// IT SEEMS THAT AFTER A REBOOT, WRITING TO SLOT 2 FAILS IMMEDIATELY???
// AFTER A REBOOT WRITING TO SLOT 3 FAILS ... AND SO ON ...
for(slot = 1; ; ++slot) {
char buf[20];
int sz = snprintf (buf, sizeof(buf), "slot: %d", slot);
status = psa_ps_set(slot, strlen(buf), buf, PSA_STORAGE_FLAG_NONE);
if (status != PSA_SUCCESS) {
printk("Failed to store data in slot (%d)! (%d)\n", slot, status);
printk("Toggling the LED ...");
while (1) {
ret = gpio_pin_toggle_dt(&led);
if (ret < 0) {
return -1;
k_msleep(SLEEP_TIME_MS);
The UART logging shows this:
*** Booting nRF Connect SDK v3.5.99-ncs1-1 *** [00:00:00.255,096] <inf> app: Writing random keys to KMU [00:00:00.317,932] <inf> app: Success! [00:00:00.323,669] <inf> fs_nvs: 3 Sectors of 4096 bytes [00:00:00.323,669] <inf> fs_nvs: alloc wra: 0, fe8 [00:00:00.323,669] <inf> fs_nvs: data wra: 0, 0 settings subsys initialization: OK. [00:00:00.323,730] <inf> app: psa_ps_get_support: 0 (0) - 1 Failed to store data in slot (102)! (-146) Toggling the LED ...*** Booting nRF Connect SDK v3.5.99-ncs1-1 *** [00:00:00.307,983] <inf> fs_nvs: 3 Sectors of 4096 bytes [00:00:00.307,983] <inf> fs_nvs: alloc wra: 2, cc0 [00:00:00.308,013] <inf> fs_nvs: data wra: 2, cb0 settings subsys initialization: OK. [00:00:00.308,715] <inf> app: psa_ps_get_support: 0 (0) - 1 Failed to store data in slot (1)! (-146) Toggling the LED ...*** Booting nRF Connect SDK v3.5.99-ncs1-1 *** [00:00:00.302,154] <inf> fs_nvs: 3 Sectors of 4096 bytes [00:00:00.302,154] <inf> fs_nvs: alloc wra: 2, cb0 [00:00:00.302,154] <inf> fs_nvs: data wra: 2, c98 settings subsys initialization: OK. [00:00:00.302,886] <inf> app: psa_ps_get_support: 0 (0) - 1 Failed to store data in slot (2)! (-146) Toggling the LED ...*** Booting nRF Connect SDK v3.5.99-ncs1-1 *** [00:00:00.296,234] <inf> fs_nvs: 3 Sectors of 4096 bytes [00:00:00.296,234] <inf> fs_nvs: alloc wra: 0, cb0 [00:00:00.296,264] <inf> fs_nvs: data wra: 0, c98 settings subsys initialization: OK. [00:00:00.296,966] <inf> app: psa_ps_get_support: 0 (0) - 1 Failed to store data in slot (3)! (-146) Toggling the LED ...
As seen from the logging, initially 101 slots can be written (settings_storage partition is 0x3000 in size in static_pm.yml).
Then after the first reset, not even 1 slot can be written.
Then next reset fails after the 2nd slot.
Then next reset fails after the 3rd slot
etc ...
Is there something wrong with prj.conf? Or something with main.c?
Thank you!
Kind regards, francis
