trace-2024-07-09T14-18-16.718Z.mtrace
Don't know if this modem trace will help.
What version of the nRF Connect SDK are you working with? What modem FW are you running on your device? I was not able to open the modem trace you provided.
Are you running our MQTT sample or your own custom code? What value is your MQTT keep alive configured to? E.g.
Hi, thank you for your quick response !
I'm currently running nRF Connect SDK version 2.6.1 with Zephyr version 2.6.0. Modem firmware has been updated to 1.3.6.
I'm currently using my custom code, which is based on the examples. Basically, there is one thread that is constantly polling the socket, and another one that is publishing messages.
static void polling_thread( void* unused1, void* unused2, void* unused3 ){
/* While termination has not been requested */
while( 1 ){
/* Handle state */
switch(context.state){
case STATE_INIT:
struct addrinfo *broker_address_result;
struct addrinfo *broker_address_lookup;
struct addrinfo broker_hints = {
.ai_family = AF_INET,
.ai_socktype = SOCK_STREAM
/* Wait for LTE-M network connection */
ltem_mng_wait_for_connection(&net_connected_sem);
__ASSERT(k_sem_take(&net_connected_sem, K_FOREVER) == 0, "Failed to acquire connected semaphore");
/* Initialize client instance */
mqtt_client_init(&context.client);
/* Resolve MQTT broker hostname */
__ASSERT(getaddrinfo(MQTT_BROKER_HOST, NULL, &broker_hints, &broker_address_result) == 0, "Failed to resolve MQTT broker hostname");
/* Look after MQTT broker address */
broker_address_lookup = broker_address_result;
while( broker_address_lookup != NULL ){
/* Found IPv4 address */
if( broker_address_lookup->ai_addrlen == sizeof(struct sockaddr_in) ){
struct sockaddr_in *broker4 = ((struct sockaddr_in *)&context.broker);
char ipv4_addr[NET_IPV4_ADDR_LEN];
broker4->sin_addr.s_addr = ((struct sockaddr_in *)broker_address_lookup->ai_addr)->sin_addr.s_addr;
broker4->sin_family = AF_INET;
broker4->sin_port = htons(MQTT_BROKER_PORT);
inet_ntop(AF_INET, &broker4->sin_addr.s_addr, ipv4_addr, sizeof(ipv4_addr));
LOG_DBG("Broker IPv4 Address found %s", (char *)(ipv4_addr));
else{
LOG_DBG("ai_addrlen = %u should be %u or %u",
(unsigned int)broker_address_lookup->ai_addrlen,
(unsigned int)sizeof(struct sockaddr_in),
(unsigned int)sizeof(struct sockaddr_in6));
broker_address_lookup = broker_address_lookup->ai_next;
/* Free the address result struct */
freeaddrinfo(broker_address_result);
/* Retrieve device IMEI to use it as client id */
char client_id[128] = { 0 };
char device_imei[30] = { 0 };
__ASSERT(ltem_mng_get_device_imei(device_imei, sizeof(device_imei)) == 0, "Failed to get device IMEI");
snprintf(client_id, sizeof(client_id) - 1, "rsibridge_%s", device_imei);
/* Construct every topic names */
for(uint32_t idx = 0; idx < TOPIC_NB; idx++){
snprintf(topic_name[idx], sizeof(topic_name[idx]) - 1, topic_format[idx], device_imei);
/* MQTT client configuration */
context.client.broker = &context.broker;
context.client.evt_cb = mqtt_evt_handler;
context.client.client_id.utf8 = client_id;
context.client.client_id.size = strlen(context.client.client_id.utf8);
context.client.password = NULL;
context.client.user_name = NULL;
context.client.protocol_version = MQTT_VERSION_3_1_1;
context.client.keepalive = config_mng_get_mqtt_keepalive_timeout_s();
/* Set up will topic */
will_topic.topic.utf8 = topic_name[TOPIC_DT_CONNECTION];
will_topic.topic.size = strlen(topic_name[TOPIC_DT_CONNECTION]);
will_topic.qos = 1;
context.client.will_topic = &will_topic;
context.client.will_message = &will_message;
/* MQTT buffers configuration */
context.client.rx_buf = context.client_rx_buffer;
context.client.rx_buf_size = sizeof(context.client_rx_buffer);
context.client.tx_buf = context.client_tx_buffer;
context.client.tx_buf_size = sizeof(context.client_tx_buffer);
/* Not using TLS for now */
context.client.transport.type = MQTT_TRANSPORT_NON_SECURE;
/* Set state */
context.state = STATE_CONNECT;
case STATE_CONNECT:
/* Try to connnect to MQTT broker */
int32_t err = mqtt_connect(&context.client);
if( err ){
LOG_ERR("Error in mqtt_connect: %d", err);
/* Indicate error occured */
error_mng_send_error(ERROR_BROKER_CONNECTION_FAILED, err);
LOG_WRN("Retrying connection in 2seconds..");
k_msleep(2000);
/* Set state */
context.state = STATE_INIT;
else{
/* Get MQTT socket to periodically poll it */
if( context.client.transport.type == MQTT_TRANSPORT_NON_SECURE ){
context.socket_fds.fd = context.client.transport.tcp.sock;
else{
__ASSERT_NO_MSG(0); /* TLS not implemented now */
context.socket_fds.events = POLLIN;
/* Set state */
context.state = STATE_IDLE;
case STATE_IDLE:
int32_t error = 0;
/* Poll the socket for incoming packets with MQTT keepalive timeout */
error = poll(&context.socket_fds, 1, mqtt_keepalive_time_left(&context.client));
if( error < 0 ){
LOG_ERR("Polling error: %d", errno);
/* End communication */
end_communication();
error_mng_send_error(ERROR_POLLING_FAILED, error);
/* Set state */
/* Ping MQTT broker to keep connection alive */
error = mqtt_live(&context.client);
if( (error != 0) && (error != -EAGAIN) ) {
LOG_ERR("mqtt_live error %d", error);
error_mng_send_error(ERROR_BROKER_PING_FAILED, error);
/* Set state */
/* If socket poll gave POLLIN event, run MQTT */
if( (context.socket_fds.revents & POLLIN) == POLLIN ){
error = mqtt_input(&context.client);
if( error != 0 ){
LOG_ERR("mqtt_input error: %d", error);
error_mng_send_error(ERROR_MQTT_PROCESS_FAILED, error);
/* Set state */
/* Error during polling */
if( ((context.socket_fds.revents & POLLERR) == POLLERR)
|| ((context.socket_fds.revents & POLLNVAL) == POLLNVAL) ){
LOG_ERR("Error during polling");
error_mng_send_error(ERROR_BROKER_CONNECTION_TERMINATED, error);
/* Set state */
/* Nothing to do here */
/* Yield to let other threads run */
k_yield();
Here is the polling thread. The other one is just "mqtt_publish" calls, nothing fancy.
MQTT keepalive has been set to 3600seconds.
Very difficult to tell what is going on. Could you please share your project with us? Will need to discuss this internally.
Thanks.
Øyvind
I went down this path recently - contacting different brokers (HiveMQ, AWS, nrfCloud). While the broker may support keepalive times past 12 hours, the limitation is the load balancers and other underlying TCP connection settings. This limits MQTT KA to something like 30 minutes for practical usage (for all major brokers I talked to) unless you set up your own custom broker hosted on a machine that won't break the TCP connection. Try backing off to a keepalive time of ~1700 seconds maximum.
