nrfutil tool fails to read the .zip DFU package
Hello . I saw this issue raised previously but with no resolution so here it is again
I built the smp-svr sample in VSCode with Zephyr SDK 2.6.1 which produced  a DFU package dfu_application.zip
I can successfully  update my device over BLE  with the Device Manager mobile app but nrfutil fails with the following error
./nrfutil.exe dfu ble -pkg /c/vd/samples/smp_svr/build-nrfdk/zephyr/dfu_application-.zip -ic NRF52 -p COM6 -a "EA:55:B0:DF:A9:6A"
File "nordicsemi\__main__.py", line 1555, in <module>
File "click\core.py", line 1137, in __call__
File "click\core.py", line 1062, in main
File "click\core.py", line 1668, in invoke
File "click\core.py", line 1404, in invoke
File "click\core.py", line 763, in invoke
File "nordicsemi\__main__.py", line 1209, in ble
File "nordicsemi\dfu\dfu.py", line 69, in __init__
File "nordicsemi\dfu\package.py", line 671, in unpack_package
File "nordicsemi\dfu\manifest.py", line 200, in from_json
KeyError: 'manifest'
[37460] Failed to execute script '__main__' due to unhandled exception!
I tried
./nrfutil-6_12.exe pkg display /c/vd/samples/smp_svr/build-nrfdk/zephyr/dfu_application.zip with the same error
So appears that nrfutil fails to read the package
Looking through the forums I found one post that suggested to use the previous version of nrfutil. Tried 6.12 without success
Any ideas?
Thank you
    Could you please let me know which version of nrfUtil you were using initially (before downgrading)? I recommend using version 7.0.
    I am not entirely sure, but are you trying to perform BLE DFU with the generated dfu_package.zip inside the build/zephyr folder? If so, the error might be due to the manifest file within the dfu_application.zip file.
    I recommend generating the zip file using the command nrfutil pkg generate. Please follow the instructions on this page for generating the zip file and then proceed with the steps outlined in the "Performing a DFU" section.
    Abhijith
  • Yes, initially I was using the latest nrfutil tool from your website. It has version 7.13.0
    Yes, I am trying to perform BLE DFU with the dfu_application.zip file that was generated as part of the smp_svr sample build. This package is recognized by the Device Manager mobile app and I was able to run BLE DFU successfully  with it.  Are you saying nrfutil does not support the  manifest format generated by the Zephyr build?
    Here is the manifest from dfu_application.zip
        "format-version": 0,
        "time": 1720621221,
        "files": [
                "load_address": 49664,
                "version_MCUBOOT": "1.2.3+0",
                "type": "application",
                "board": "nrf52840_custom_3_1_2",
                "soc": "nRF52840_QIAA",
                "size": 390926,
                "file": "app_update.bin",
                "modtime": 1720621221
        "name": "smp_svr",
        "firmware": {
            "zephyr": {
                "revision": null
            "nrf": {
                "revision": "eef645c4a31201df353fdff5447262d7675fa1c1"
    I believe the issue may be due to the format of the manifest.json files generated by Zephyr build and nrfutil. I tested this to confirm by examining the manifest generated by nrfutil, and it appears different from the dfu_application.zip manifest. I am attaching the generated zip file here. Please note that I did not include the key for signing during package generation, so it is not present in the generated manifest. I recommend trying to generate the package using nrfutil and using that package for DFU
    dfu_application_util.zip
    Kind Regards,
    Abhijith
  • Thank you for verifying. Could a ticket be opened to fix this going forward?
