I'm working on a project in which we are adding FOTA functionality based on application_update example. As soon as I add
CONFIG_BOOTLOADER_MCUBOOT=y
Changed board to secure xxxyyyyzzz_nrf9160 (NOT NS)
in the build log, and soon after that these warnings:
warning: NRF_MODEM_LIB_NET_IF (defined at /opt/nordic/ncs/v2.6.1/nrf/lib/nrf_modem_lib/lte_net_if/Kconfig:6) was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: NET_SOCKETS_OFFLOAD (=n), NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC (=n), NRF_MODEM_LIB (=n). See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NRF_MODEM_LIB_NET_IF and/or look up NRF_MODEM_LIB_NET_IF in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. warning: AT_HOST_LIBRARY (defined at /opt/nordic/ncs/v2.6.1/nrf/lib/at_host/Kconfig:7) was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: NRF_MODEM_LIB (=n). See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_AT_HOST_LIBRARY and/or look up AT_HOST_LIBRARY in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. warning: MODEM_KEY_MGMT (defined at /opt/nordic/ncs/v2.6.1/nrf/lib/modem_key_mgmt/Kconfig:7) was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: NRF_MODEM_LIB (=n). See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MODEM_KEY_MGMT and/or look up MODEM_KEY_MGMT in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. warning: NET_SOCKETS_OFFLOAD (defined at subsys/net/lib/sockets/Kconfig:219) was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: NET_SOCKETS (=n), NETWORKING (=n). See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NET_SOCKETS_OFFLOAD and/or look up NET_SOCKETS_OFFLOAD in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. warning: The choice symbol NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC (defined at /opt/nordic/ncs/v2.6.1/nrf/lib/nrf_modem_lib/Kconfig.modemlib:213) was selected (set =y), but no symbol ended up as the choice selection. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC and/or look up NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
These warnings do not appear without CONFIG_BOOTLOADER_MCUBOOT=y configuration.
Th build does not fail, but the application seems not to boot.
I have searched for similar problems, like
https://devzone.nordicsemi.com/f/nordic-q-a/107303/config_bootloader_mcuboot-on-custom-nrf9160-board
but haven't succeeded to solve the issue.
Any ideas what might be wrong?
