Custom board Bluetooth Initialization Error
I have a custom board based on the nrf5340 and I am attempting to get bluetooth working.
void ble_gatt_start()
	int err;
	LOG_INF("Starting Ble Gatt Server \n");
	err = bt_enable(NULL);
	if (err) {
		LOG_ERR("Bluetooth init failed (err %d)\n", err);
		return;
	bt_conn_cb_register(&connection_callbacks);
	/* Pass application callback functions stored in app_callbacks to the MY LBS service */
    err = my_custom_characteristics_init(&app_callbacks);
	if(err){
		LOG_ERR("failed to init Gatt server (err: %d)", err);
		return;
	LOG_INF("Bluetooth initialized\n");
	err = bt_le_adv_start(adv_param, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
	if (err) {
		LOG_ERR("Advertising failed to start (err %d)\n", err);
		return;
	LOG_INF("Advertising successfully started\n");
The problem lies in the bluetooth initialization step with bt_enable. When I step through the debugger it fails at:
k_thread_create(&tx_thread_data, tx_thread_stack,
K_KERNEL_STACK_SIZEOF(tx_thread_stack),
hci_tx_thread, NULL, NULL, NULL,
K_PRIO_COOP(CONFIG_BT_HCI_TX_PRIO),
0, K_NO_WAIT);
in the bt_enable routine in hci_core.c. No error happens when I check the RTT and the whole debugger just freezes indefinitely.
/* Give cmd_sem allowing to send first HCI_Reset cmd, the only
	 * exception is if the controller requests to wait for an
	 * initial Command Complete for NOP.
	if (!IS_ENABLED(CONFIG_BT_WAIT_NOP)) {
		k_sem_init(&bt_dev.ncmd_sem, 1, 1);
	} else {
		k_sem_init(&bt_dev.ncmd_sem, 0, 1);
	k_fifo_init(&bt_dev.cmd_tx_queue);
	/* TX thread */
			0, K_NO_WAIT);
	k_thread_name_set(&tx_thread_data, "BT TX");
What could be the issue?
I am including relevant info from my config and dts files:
prj.conf:
CONFIG_I2C=y
CONFIG_BT=y
CONFIG_BT_DEVICE_NAME="BT_TEST"
CONFIG_PWM=y
CONFIG_UART_ASYNC_API=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
# STEP 12 - Update Data Length and MTU
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_HCI=y
# Increase stack size for the main thread and System Workqueue
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=16384
CONFIG_MAIN_STACK_SIZE=16384
CONFIG_HW_STACK_PROTECTION=y
CONFIG_BT_RX_STACK_SIZE=6000
CONFIG_IDLE_STACK_SIZE=8096
CONFIG_ISR_STACK_SIZE=8096
CONFIG_NRF53_SYNC_RTC=n
CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_LF_ALWAYS_ON=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
CONFIG_DEBUG=y
CONFIG_NO_OPTIMIZATIONS=y
dts:
	chosen {
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_ns_partition;
		zephyr,console = &uart2;
		zephyr,shell-uart = &uart2;
		zephyr,bt-uart = &uart2;
		zephyr,bt-mon-uart = &uart2;
		zephyr,bt-c2h-uart = &uart2;
		zephyr,bt-hci-ipc = &ipc0;
defconfig:
CONFIG_SOC_SERIES_NRF53X=y
CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
CONFIG_BOARD_ATREIDES=y
# Enable MPU
CONFIG_ARM_MPU=y
# Enable hardware stack protection
# Enable TrustZone-M
CONFIG_ARM_TRUSTZONE_M=y
# This Board implies building Non-Secure firmware
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
# enable GPIO
CONFIG_GPIO=y
# enable PINCTRL
CONFIG_PINCTRL=y
# Enable uart driver
CONFIG_SERIAL=y
# enable console
CONFIG_UART_CONSOLE=n
CONFIG_CONSOLE=y
# Enable RTT
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG=y
CONFIG_LOG_PRINTK=y
CONFIG_PRINTK=y
CONFIG_I2C=y
CONFIG_SENSOR=y
CONFIG_DISK_ACCESS=y
CONFIG_LOG=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_SPI=y
CONFIG_DISK_DRIVER_SDMMC=y
CONFIG_FS_FATFS_EXFAT=y
CONFIG_FS_FATFS_MOUNT_MKFS=y
CONFIG_PRINTK=y
CONFIG_NCS_INCLUDE_RPMSG_CHILD_IMAGE=y
I also followed other recommendations from other questions to configure the internal oscillator on the network core by creating a conf file in a child_image folder in my source directory.I had no luck with this as well.
