nRF9161 FOTA + TLS Download Error
We are using `fota_download` library on our nRF9161 design running mfw-nrf91x1_2.0.1 to download a firmware upgrade image from our Amazon AWS server location.
When trying to download with TLS enabled, fota_donwload_start function errors out with errno 122: EMSGSIZE, however everything works fine when TLS is not being used. We are also able to download the image if TLS is setup on our local PC/server.
Our current understanding is that the nRF9161 delegates TLS/socket processing to the modem firmware. Adjusting the fragment size in our firmware to a smaller value hasn't resolved the problem, and error 122 persists.
We’ve looked into modifying the TLS settings on AWS server, however that doesn’t seem to be an option as of now.
Wondering if you have any recommendations on how to work around the problem?
  • Yes, we have set CONFIG_DOWNLOAD_CLIENT_BUF_SIZE to 4096 and tried fragmentation size both 1024 and 2048 however the download still fails.
    We have tried to setup another server and set fragmentation size to 1024 on the server side and found out that download does works for  both CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024 and CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_2048.
    Unfortunately we are unable to change the fragmentation size on the AWS server. Is there any other work around we could try?
  • Reading through your case again, is this the nRF9160 or the nRF9161? Assuming that you see the same issue on both devices?
    Could you also check the Life Cycle Events on AWS server?
    Please add the following to your project to enable more debug information:
    CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_DBG=y
    CONFIG_DOWNLOAD_CLIENT_LOG_HEADERS=y
    Øyvind
  • The file is being downloaded through HTTPS via AWS API Gateway where mTLS is enabled. The link that you sent was to AWS IoT where we do not currently have an issue
  • Thanks for your patience.
    No updates yet to this issue. Still ongoing investigation.
    Could you please try adding the following configs for more debug logs
    CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DBG=y
    CONFIG_NRF_MODEM_LIB_NET_IF_LOG_LEVEL_DBG=y
    CONFIG_NET_CONNECTION_MANAGER_LOG_LEVEL_DBG=y
    CONFIG_NET_LOG=y
    Thanks!
    Øyvind
  • Please see attached the logs with requested configs enabled
    We were not able to find the CONFIG_NRF_MODEM_LIB_NET_IF_LOG_LEVEL_DBG (see below)
    *** Booting nRF Connect SDK v2.5.0 ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, cop
    y_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, c
    opy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Image index: 0, Swap type: none
    I: Bootloader chainload address offset: 0x10000
    D: (0x200163a0): Connection Manager started
    I: LTE Node application v1.0.7
    I: Trace thread ready
    I: Trace level override: 2
    D: Modem library has initialized, ret 0
    D: Modem init callback: 0x2f871
    D: Modem init callback: 0x2eff5
    D: Modem init callback: 0x2f161
    I: IMEI: 1400D8DEC570E
    I: Serial ID: 99999985
    I: Hardware Revision: N/A - nRF 9160 DK
    I: Node config URL: config.api.waites.net/test/no
    de/99999985
    I: Entered state ST_DISCONNECTED
    E: Failed to find pin: 19
    I: Entered state ST_INIT
    D: iface 0x20010fd4 connect
    +CEREG: 2,"3BAF","0D85A206",7
    +CSCON: 1
    +CGEV: ME PDN ACT 0,0
    +CNEC_ESM: 50,0
    +CEREG: 5,"3BAF","0D85A206",7,,,"00000000","10101
    111"
    D: (0x20016190): IPv4 event 3758358529 received o
    n iface 1 (0x20010fd4)
    D: (0x20016190): Iface index 0
    %XTIME: "8A","4270611223508A","01"
    D: (0x20016190): Iface event 3489726466 received
    on iface 1 (0x20010fd4)
    I: L4 Event: Connected
    I: Entered state ST_NETWORK_UP
    I: Entered state ST_CONNECTED
    I: Subscribing to: on-config-changed/n/1400D8DEC5
    70E
    E: Library is in the wrong state (MQTT_STATE_DISC
    ONNECTED), MQTT_STATE_CONNECTED required
    E: Failed to subscribe to topics, err: -95
    I: Connected successfully
    I: Upgrading self with image: https://config.api.
    waites.net/v1/sensor-core/Sensor-IEP-N1_217A7_v1.
    6.0.bin
    D: URI checksums 191005400,1987551763,0,0
    D: state = 1
    I: Downloading: v1/sensor-core/Sensor-IEP-N1_217A
    7_v1.6.0.bin [0]
    > AT+CFUN=1
    D: Protocol not specified, defaulting to HTTP(S)
    D: Port not specified, using default: 443
    D: family: 1, type: 1, proto: 258
    I: Setting up TLS credentials, sec tag count 1
    I: Connecting to config.api.waites.net
    D: fd 0, addrlen 8, fam IPv4, port 443
    D: state = 2
    E: len = 137
    D: HTTP request
    D: 47 45 54 20 2f 76 31 2f |GET /v1/
    D: 73 65 6e 73 6f 72 2d 63 |sensor-c
    D: 6f 72 65 2f 53 65 6e 73 |ore/Sens
    D: 6f 72 2d 49 45 50 2d 4e |or-IEP-N
    D: 31 5f 32 31 37 41 37 5f |1_217A7_
    D: 76 31 2e 36 2e 30 2e 62 |v1.6.0.b
    D: 69 6e 20 48 54 54 50 2f |in HTTP/
    D: 31 2e 31 0d 0a 48 6f 73 |1.1..Hos
    D: 74 3a 20 63 6f 6e 66 69 |t: confi
    D: 67 2e 61 70 69 2e 77 61 |g.api.wa
    D: 69 74 65 73 2e 6e 65 74 |ites.net
    D: 0d 0a 52 61 6e 67 65 3a |..Range:
    D: 20 62 79 74 65 73 3d 30 | bytes=0
    D: 2d 31 30 32 33 0d 0a 43 |-1023..C
    D: 6f 6e 6e 65 63 74 69 6f |onnectio
    D: 6e 3a 20 6b 65 65 70 2d |n: keep-
    D: 61 6c 69 76 65 0d 0a 0d |alive...
    D: 0a                      |.
    D: Receiving up to 4096 bytes at 0x200166e8...
    E: Error in recv(), errno 122
    W: Download socket error. 2 retries left...
    I: Reconnecting...
    E: len = 137
    D: HTTP request
    D: 0a                      |.
    W: Download socket error. 1 retries left...
    I: Reconnecting...
    E: len = 137
    D: HTTP request
    D: 0a                      |.
    E: Download client error
    D: No DFU target was initialized
    D: state = 4
    D: state = 0
    E: Upgrade start failed
    I: Sleeping...
    E: Received error from fota downloadHandler, err:
    1
    D: Connection closed
    +CSCON: 0
    modem_trace_7_16.mtrace
