Intermittent BLE connection
I am working with nRF Connect SDK 2.6.1 on a Central and a Peripheral and I am running the BAP similar to the nRF Audio Example. I am using out of band pairing over UART for the initial secure connection. The OOB pairing works fine.
After connection is established and bonds are saved, the peripheral basically always advertises if bonds exist. The central device is turned on and off and scans when it turns on. I know this is a little different than traditionally, but the Basic Audio Profile forced which devices are the Central and the Peripheral.
If I continuously cycle power to the Central and watch the log output, quite frequently I can see that sometimes it needs multiple attempts to connect. It seems to happen more frequently when the area is a little more ACTIVE in the BLE band.
I'm using Wireshark with the nRF Sniffer to look at the BLE traffic, and it seems like the Peripheral (Slave on the Wireshark log), stops responding to the Centrals (Master) packets. I'm using security level 4 so Wireshark is unable to decrypt the message, but I should still see a response from the Peripheral in order to maintain the connectivity.
It seems quite frequently the peripheral stops responding after it sends the OP Code LL_START_ENC_REQ.  Here's the log of the connection and when the peripheral stops responding.
Here is a successful connection where you can see constant communication between the central and the peripheral:
On my log output on the Central and the Peripheral when the failure occurs I can see the connection occur but then a "Security failed" notification. It then seems to struggle with the disconnection but eventually does, it then starts advertising again and then successfully connects for the most part on the 2nd attempt. Sometimes it takes a couple of attempts but it seems to always reconnect.
-- [00:04:21.230,010] <dbg> event: thread_status_event_supv: Conn evnt
-- [00:04:21.580,444] <wrn> ble_supv: Security failed: level 1 err 9
-- [00:04:21.580,474] <wrn> ble_supv: Failed to disconnect -128
-- [00:04:21.580,718] <dbg> event: thread_status_event_supv: Disc Evnt
-- [00:04:21.640,258] <inf> ble_supv: Advertising to xx:xx:xx:xx:xx:xx (random) started
-- [00:04:25.829,498] <dbg> event: thread_status_event_supv: Conn evnt
I am wondering about the procedure when the Central device is powered down and disconnects. I'm basically just calling the functions to stop streaming and disconnect and then powering down. The peripheral does seem to take a couple of seconds to recognize the disconnection and receive the "disconnect" callback. But even if I ensure to wait for this callback on the peripheral to occur before turning the central back on, I still get the occasional failure. Is there still something hanging up in the peripheral device from the connection that is occuring due to my procedure for the disconnection? What should the procedure be to properly stop streaming and disconnect from a peripheral? Is it possible its somehow using the "conn" handle from the previous connection?
The current BLE disconnection procedure when the central is shut down. There is a little more error checking, but basically if we're streaming, stop the streaming and then disconnect:
if (!bt_content_ctlr_media_state_playing()){
        return 0; // we are already paused
bt_content_ctrl_stop(default_conn);
bt_conn_disconnect(default_conn, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
Its also possible the disconnection procedure has nothing to do with this failure. I'm using whitelisting on the peripheral so it only connects to the bonded device. But I am just using regular advertising rather than directed advertising. I didn't see the need for directed advertising since we're using out of band pairing.
  • Hi adunk,
    I am not familiar with what BAP requires here, but this sound pretty much the same as how a pair of Central and Peripheral would work since Bluetooth 4.x, no? Could I perhaps miss something here?
    But if dwelling in the reasons of the setup is not directly related to the issue, we can skip this part.
    This sound like the Central powering down happen too quick that the call to disconnect didn't actually work on the Central yet. The Peripheral would then just keep waiting for Central packets that stop coming and eventually time out.
    Since you already have a sniffer setup, can you check if that is the case? You could temporarily disable encryption just for this test too.
    Also, how does this power cycle happen? Power cycle usually mean a physical power cut and restore. However, you mentioned the central ending the stream and disconnect, that sounds like software is involved.
    From what you have described here, that can seem to be the case, but there shouldn't be anything like that...
    Let's also look at these logs:
    I assume ble_supv is one of your code module, and the code is based on one of the sample code. In that case, "Failed to disconnect -128" comes from bt_conn_disconnect(), and error 128 means there wasn't a connection.
    This is quite odd. The two modules of the Bluetooth stack involved here are SMP and CONN. Could you please enable these configs to get more logs?
    CONFIG_BT_SMP_LOG_LEVEL_DBG
    CONFIG_BT_CONN_LOG_LEVEL_DBG
    There could be a significant increase in amount of log, so you might also need to configure more buffers for the log module. Please also make sure CONFIG_LOG_MODE_DEFERRED is enabled to minimize the impact of logging to the Bluetooth stack's operations.
    It would be best to wait for a callback confirming the success of an operation before moving on to the next step.
    Right, so this looks like there is no wait for any procedures to complete at all. Still, in an ideal world, the peripheral should be robust enough that it isn't impacted by what the central does.
    Noted.
    Hieu
  • I noticed in the latest SDK release, an issue was fixed in the nRF5340. Is this a symptom of this issue? Is it trying to connect again during the connection process?
  • I have caught up on the previous posts here and have found that I need to forward this issue internally. Thank you again for your patience, and I will update you again by Thursday.
    The connection fails with 0x3D (BTLE_CONN_TERMINATED_DUE_TO_MIC_FAILURE) which indicates incorrect encryption keys. Please do a new test with CONFIG_BT_LOG_SNIFFER_INFO=y and share the sniffer log for a successful and an unsuccessful connection.
    Maria
  • Hello Maria. We have recently discovered an antenna layout issue so its possible this is a legitimate failure to exchange data during the connection process. Once I am given a device with a corrected layout I will attempt to duplicate this failure and post the logs as requested or close the issue. Thanks!
  • We are no longer having the issue since changing our antenna layout.
