Intermittent BLE connection
I am working with nRF Connect SDK 2.6.1 on a Central and a Peripheral and I am running the BAP similar to the nRF Audio Example. I am using out of band pairing over UART for the initial secure connection. The OOB pairing works fine.
After connection is established and bonds are saved, the peripheral basically always advertises if bonds exist. The central device is turned on and off and scans when it turns on. I know this is a little different than traditionally, but the Basic Audio Profile forced which devices are the Central and the Peripheral.
If I continuously cycle power to the Central and watch the log output, quite frequently I can see that sometimes it needs multiple attempts to connect. It seems to happen more frequently when the area is a little more ACTIVE in the BLE band.
I'm using Wireshark with the nRF Sniffer to look at the BLE traffic, and it seems like the Peripheral (Slave on the Wireshark log), stops responding to the Centrals (Master) packets. I'm using security level 4 so Wireshark is unable to decrypt the message, but I should still see a response from the Peripheral in order to maintain the connectivity.
It seems quite frequently the peripheral stops responding after it sends the OP Code LL_START_ENC_REQ.  Here's the log of the connection and when the peripheral stops responding.
Here is a successful connection where you can see constant communication between the central and the peripheral:
On my log output on the Central and the Peripheral when the failure occurs I can see the connection occur but then a "Security failed" notification. It then seems to struggle with the disconnection but eventually does, it then starts advertising again and then successfully connects for the most part on the 2nd attempt. Sometimes it takes a couple of attempts but it seems to always reconnect.
-- [00:04:21.230,010] <dbg> event: thread_status_event_supv: Conn evnt
-- [00:04:21.580,444] <wrn> ble_supv: Security failed: level 1 err 9
-- [00:04:21.580,474] <wrn> ble_supv: Failed to disconnect -128
-- [00:04:21.580,718] <dbg> event: thread_status_event_supv: Disc Evnt
-- [00:04:21.640,258] <inf> ble_supv: Advertising to xx:xx:xx:xx:xx:xx (random) started
-- [00:04:25.829,498] <dbg> event: thread_status_event_supv: Conn evnt
I am wondering about the procedure when the Central device is powered down and disconnects. I'm basically just calling the functions to stop streaming and disconnect and then powering down. The peripheral does seem to take a couple of seconds to recognize the disconnection and receive the "disconnect" callback. But even if I ensure to wait for this callback on the peripheral to occur before turning the central back on, I still get the occasional failure. Is there still something hanging up in the peripheral device from the connection that is occuring due to my procedure for the disconnection? What should the procedure be to properly stop streaming and disconnect from a peripheral? Is it possible its somehow using the "conn" handle from the previous connection?
The current BLE disconnection procedure when the central is shut down. There is a little more error checking, but basically if we're streaming, stop the streaming and then disconnect:
if (!bt_content_ctlr_media_state_playing()){
        return 0; // we are already paused
bt_content_ctrl_stop(default_conn);
bt_conn_disconnect(default_conn, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
Its also possible the disconnection procedure has nothing to do with this failure. I'm using whitelisting on the peripheral so it only connects to the bonded device. But I am just using regular advertising rather than directed advertising. I didn't see the need for directed advertising since we're using out of band pairing.
