Configuring settings module with NVS (nRF5340 Audio application)
i need to store few configuration bytes in non volatile memory. I found out there is settings module that can be enabled in Kconfig GUI (SETTINGS option).
My use is very basic so it seems using file system is overkill and NVS should be the right choice.
I enable NVS option.
Than I think i should configure the settings module to use NVS but the option is not available.
This is what i see when i search for the option SETTINGS_NVS:
I also have some possibly related issues with not being able to enable CONFIG_BT_CTLR_PHY_CODED in the application, maybe it is related??
I than plan to use settings_load/settings_save api.
Is this the correct way to save application data and if yes how should I enable it correctly?
Thank You
