I have device restart after line:
err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
(k_sys_fatal_error_handler reason 4 or sometimes 3 in debugger)
my prj.conf and main.c in attachments
I could not compile the code you provided.
Can you send the project in zip folder that is compilable? Please do mention the SDK version that you are using.
Naeem
sbox_for_support.zip
I tried compile on sdk 2.6.1,
2.5.3
and 2.7.0
all this same result :(
custom board sat_tech_sbox
Strange, i rearranged the code a bit, now reset (Kernel panic reason 4) at line main:851:
I turned on logging, got <err> os: Fault during interrupt handling - but what causes tis error?
MPSL Assert 112,2165 in nRF Connect SDK when Setting Breakpoints in BLE Stack
So I will investigate issue without running debugger
You can use non-halting_debugging otherwise known as monitor mode debugging for your ble application.
