Mocking Opaque Types
Hi guys, another question here regarding Cmock and opaque types. I am currently trying to mock a function with an argument that contains the type "struct bt_conn". However when building this mock, I get the following error:
In file included from c:\nordicsemi\v2.5.0\test\cmock\vendor\unity\src\unity.h:21,
                 from c:\nordicsemi\v2.5.0\test\cmock\src\cmock_internals.h:10,
                 from c:\nordicsemi\v2.5.0\test\cmock\src\cmock.h:10,
                 from C:/PP_Unit_Tests/twister/ProPatch_test/unity.example_test/mocks/LWservice/cmock_lwl_service_support.c:4:
C:/PP_Unit_Tests/twister/ProPatch_test/unity.example_test/mocks/LWservice/cmock_lwl_service_support.c: In function '__cmock_on_sent':
C:/PP_Unit_Tests/twister/ProPatch_test/unity.example_test/mocks/LWservice/cmock_lwl_service_support.c:187:113: error: invalid application of 'sizeof' to incomplete type 'const struct bt_conn'
  187 |       { UNITY_TEST_ASSERT_EQUAL_MEMORY_ARRAY((void*)(cmock_call_instance->Expected_conn), (void*)(conn), sizeof(const struct bt_conn), cmock_call_instance->Expected_conn_Depth, cmock_line, CMockStringMismatch); }
c:\nordicsemi\v2.5.0\test\cmock\vendor\unity\src\unity_internals.h:941:198: note: in definition of macro 'UNITY_TEST_ASSERT_EQUAL_MEMORY_ARRAY'
  941 | #define UNITY_TEST_ASSERT_EQUAL_MEMORY_ARRAY(expected, actual, len, num_elements, line, message) UnityAssertEqualMemory((UNITY_INTERNAL_PTR)(expected), (UNITY_INTERNAL_PTR)(actual), (UNITY_UINT32)(len), (UNITY_UINT32)(num_elements), (message), (UNITY_LINE_TYPE)(line), UNITY_ARRAY_TO_ARRAY)
 After doing some digging, it looks like struct bt_conn is an opaque type (I know very little about opaque types). Is there any way I can mock this function despite the use of an opaque type?
    Sorry for the delay in responding. I'm also not very familiar with opaque types and Cmock. The log you uploaded indicates there was a build issue because the code attempted to determine the size of a type, const struct bt_conn, which was not fully defined at that point. This problem occurred in the mock function __cmock_on_sent generated by CMock. To potentially resolve issues related to incomplete type definitions, could you try using a pointer to struct bt_conn (struct bt_conn *conn) instead of (struct bt_conn conn)?
    Please let me know if this solution works for you. Otherwise, I will escalate the issue internally to someone with more experience.
    Abhijith
  • Hi Abhijith,
    So the actual function call already calls a pointer. Thats on me for not being specific enough. Here's the function:
    void on_sent(struct bt_conn *conn, void *user_data);
    I have many more functions that I'll need to test later that also call bt_conn as a pointer.
    I tried defining the argument as not a pointer as well, but still get the same issue. When I try defining the type struct bt_conn within my test file, and even give it some meaningless content, the error still persists. When I brought this up on the discord, they suggested making my own mocks of all of the functions and even mocking the struct itself by hand, however I don't believe this will allow me to continue using Unity they way that I already have been. If you could please escalate this ASAP I would greatly appreciate it.
    -Jesse
  • I also came across this post, but I cannot add a fake definition of bt_conn in the autogenerated cmock header that will exist across builds.
  • I've come to a temporary solution by defining the struct bt_conn within my source file, with compiler tags around it so that this definition is only used when I'm testing. I have yet to actually test this, but it at least compiles for now.
    #ifdef TESTING
    typedef struct bt_conn {
        int dummy;
    } bt_conn;
  • Hello Jesse,
    Thanks for providing the update; it's good to hear that you've made some progress. Let me know if I need to escalate this issue to get an expert opinion, as I am not an expert on this topic. Please note that there might be some delay in getting an update due to the summer vacation period in Norway.
    Abhijith
