USB MASS sample and partition manager build issues
I have my application code which builds and runs on my nrf5340DK. The project files were based on the zephyr sample for multi-advertising BLE.
Right now I'm building the 'secure' app version (board target nrf5340dk_nrf5340_cpuapp)
I now want to add a file system, in the external flash, and enable USB access to it (objective is to have a way to give files to the application firmware over USB)
I took the code & dts/Kconfig from the USB 'mass' zephyr sample to use as a base for this, however the project will not compile, failing at flashdisk.c in the zephyr installation:
[11/142] Building C object zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
FAILED: zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
C:\ncs\toolchains\cf2149caf2\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPICOLIBC_LONG_LONG_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -IC:/work/dev/nordic_connect/zephyr/include -IC:/work/dev/if-device-nrf53/cc1-med/build/zephyr/include/generated -IC:/work/dev/nordic_connect/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/work/dev/nordic_connect/zephyr/soc/common/nordic_nrf/. -IC:/work/dev/nordic_connect/zephyr/soc/arm/nordic_nrf/common/. -IC:/work/dev/nordic_connect/zephyr/subsys/usb/device -IC:/work/dev/nordic_connect/zephyr/subsys/bluetooth -IC:/work/dev/nordic_connect/zephyr/drivers/usb/common/nrf_usbd_common/. -IC:/work/dev/nordic_connect/nrf/include -IC:/work/dev/nordic_connect/nrf/subsys/app_event_manager/. -IC:/work/dev/nordic_connect/nrf/subsys/app_event_manager_profiler_tracer/. -IC:/work/dev/nordic_connect/nrf/tests/include -IC:/work/dev/nordic_connect/modules/lib/cjson -IC:/work/dev/nordic_connect/nrf/modules/cjson/include -IC:/work/dev/nordic_connect/modules/hal/cmsis/CMSIS/Core/Include -IC:/work/dev/nordic_connect/zephyr/modules/cmsis/. -IC:/work/dev/nordic_connect/modules/hal/nordic/nrfx -IC:/work/dev/nordic_connect/modules/hal/nordic/nrfx/drivers/include -IC:/work/dev/nordic_connect/modules/hal/nordic/nrfx/mdk -IC:/work/dev/nordic_connect/zephyr/modules/hal_nordic/nrfx/. -IC:/work/dev/if-device-nrf53/cc1-med/build/modules/libmetal/libmetal/lib/include -IC:/work/dev/nordic_connect/modules/lib/open-amp/open-amp/lib/include -IC:/work/dev/nordic_connect/modules/crypto/tinycrypt/lib/include -IC:/work/dev/nordic_connect/nrfxlib/softdevice_controller/include -isystem C:/work/dev/nordic_connect/zephyr/lib/libc/common/include -isystem C:/work/dev/nordic_connect/nrfxlib/crypto/nrf_cc312_platform/include -Wshadow -fno-strict-aliasing -Os -imacros C:/work/dev/if-device-nrf53/cc1-med/build/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/work/dev/nordic_connect/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/work/dev/if-device-nrf53/cc1-med=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/work/dev/nordic_connect/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/work/dev/nordic_connect=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -MF zephyr\drivers\disk\CMakeFiles\drivers__disk.dir\flashdisk.c.obj.d -o zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -c C:/work/dev/nordic_connect/zephyr/drivers/disk/flashdisk.c
C:/work/dev/nordic_connect/zephyr/drivers/disk/flashdisk.c:484:1: error: return type defaults to 'int' [-Werror=implicit-int]
484 | PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_CACHE)
C:/work/dev/nordic_connect/zephyr/drivers/disk/flashdisk.c: In function 'PM_FOREACH_AFFILIATED_TO_disk':
C:/work/dev/nordic_connect/zephyr/drivers/disk/flashdisk.c:523:30: error: storage class specified for parameter 'flash_disks'
523 | static struct flashdisk_data flash_disks[] = {
C:/work/dev/nordic_connect/zephyr/drivers/disk/flashdisk.c:523:15: error: parameter 'flash_disks' is initialized
C:/work/dev/nordic_connect/zephyr/drivers/disk/flashdisk.c:524:39: error: 'DEFINE_FLASHDISKS_DEVICE' undeclared (first use in this function)
524 | PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_DEVICE)
etc etc as ever when one of these macros has an issue its very tricky to work out why....
Looking at the flashdisk.c code it seems to be in the USE_PARTITION_MANAGER case, so I guess its not finding some PM config to define the flash disk parameters?
Q: do I need to use the Partition Manager sub system? The DTS files appear to define the partitions required just fine...The mass example does not have a pm.yml either?
If I have to use PM (my reading implies 'yes', because the nrf5340 requires a multi-image hex due to the 2 processors?), where, how to configure its partitions if not in the DTS?
I tried to build the 'mass' sample standalone copied directly from the NCS; but it also fails to compile with this error:
CMake Error at CMakeLists.txt:10 (message):
No disk access settings detected.
Any ideas what I'm doing wrong?
Thanks
Brian
full compile output for 'mass' sample:
C:\work\dev\if-device-nrf53\mass>west build -p
-- Application: C:/work/dev/if-device-nrf53/mass
-- CMake version: 3.21.0
-- Using NCS Toolchain 2.6.20240304.889616714482 for building. (C:/ncs/toolchains/cf2149caf2/cmake)
-- Found Python3: C:/ncs/toolchains/cf2149caf2/opt/bin/python.exe (found suitable version "3.9.13", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/work/dev/nordic_connect/zephyr/.cache
-- Zephyr version: 3.5.99 (C:/work/dev/nordic_connect/zephyr)
-- Board: nrf5340dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.16.5 (C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.5 (C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/cf2149caf2/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/work/dev/nordic_connect/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: C:/work/dev/if-device-nrf53/mass/boards/nrf5340dk_nrf5340_cpuapp.overlay
-- Generated zephyr.dts: C:/work/dev/if-device-nrf53/mass/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/work/dev/if-device-nrf53/mass/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/work/dev/if-device-nrf53/mass/build/zephyr/dts.cmake
Parsing C:/work/dev/if-device-nrf53/mass/Kconfig
Loaded configuration 'C:/work/dev/nordic_connect/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/work/dev/if-device-nrf53/mass/prj.conf'
Configuration saved to 'C:/work/dev/if-device-nrf53/mass/build/zephyr/.config'
Kconfig header saved to 'C:/work/dev/if-device-nrf53/mass/build/zephyr/include/generated/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
CMake Warning at C:/work/dev/nordic_connect/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
CONFIG_USB_DEVICE_VID has default value 0x2FE3.
This value is only for testing and MUST be configured for USB products.
CMake Warning at C:/work/dev/nordic_connect/zephyr/CMakeLists.txt:862 (message):
No SOURCES given to Zephyr library: drivers__disk
Excluding target from build.
See also "C:/work/dev/if-device-nrf53/mass/build/CMakeFiles/CMakeOutput.log".
See also "C:/work/dev/if-device-nrf53/mass/build/CMakeFiles/CMakeError.log".
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\cf2149caf2\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/cf2149caf2/opt/bin/python.exe '-BC:\work\dev\if-device-nrf53\mass\build' -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp '-SC:\work\dev\if-device-nrf53\mass'
  • I tried to build the 'mass' sample standalone copied directly from the NCS; but it also fails to compile with this error:
    Ok, so this error is due to not giving the  -DCONFIG_APP_MSC_STORAGE_FLASH_FATFS=y option on the build line (which only works if you build from the parent directory as
    west build --build-dir mass/build mass --pristine=auto -DCONFIG_APP_MSC_STORAGE_FLASH_FATFS=y
    as otherwise the -D... is taken as the application name).
    And this builds ok as the PM is NOT enabled - if I force the PM with
    CONFIG_PM_SINGLE_IMAGE=y
    then it fails to compile also....
    I understand that this is complex and there is quite a few configuration options to navigate through..
    A couple of thoughts here:
    1.  APP_MSC_STORAGE_FLASH_FATFS != APP_MSC_STORAGE_FLASH_LITTLEFS, while our pm.yml.file_system concerns littlefs
    2. Partition manager does not seem to have out of the box support for that specific FAT filesystem
    3. As you've stated you're already attempting, you'll have to use static partitioning
    Instead, lets take a step back and check something that should be verified support for: Could you try to test with APP_MSCC_STORAGE_FLASH_LITTLEFS instead? This
    Andreas
  • This means that it works, right?
    Ah, it compiles! Not quite the same thing....
    When run, I get this logs/error:
    Area 1 at 0x0 on mx25r6435f@0 for 2097152 bytes
    [00:00:00.359,222] <err> fs: fs mount error (-19)
    [00:00:00.364,624] <err> base: Failed to mount filesystem
    which comes from this code (pretty much directly from the mass sample code)
    #define STORAGE_PARTITION       fatfs_storage
    #define STORAGE_PARTITION_ID        FIXED_PARTITION_ID(STORAGE_PARTITION)
    static struct fs_mount_t fs_mnt;
    static int _setup_flash(struct fs_mount_t *mnt)
        int rc = 0;
    #if CONFIG_DISK_DRIVER_FLASH
        unsigned int id;
        const struct flash_area *pfa;
        mnt->storage_dev = (void *)STORAGE_PARTITION_ID;
        id = STORAGE_PARTITION_ID;
        rc = flash_area_open(id, &pfa);
        printk("Area %u at 0x%x on %s for %u bytes\n",
               id, (unsigned int)pfa->fa_off, pfa->fa_dev->name,
               (unsigned int)pfa->fa_size);
        if (rc < 0 && IS_ENABLED(CONFIG_APP_WIPE_STORAGE)) {
            printk("Erasing flash area ... ");
            rc = flash_area_erase(pfa, 0, pfa->fa_size);
            printk("%d\n", rc);
        if (rc < 0) {
            flash_area_close(pfa);
        return rc;
    static int _mount_app_fs(struct fs_mount_t *mnt)
        int rc;
    #if CONFIG_FAT_FILESYSTEM_ELM
        static FATFS fat_fs;
        mnt->type = FS_FATFS;
        mnt->fs_data = &fat_fs;
        mnt->mnt_point = "/flash:";
    #else
        log_warn("no file system type defined in firmware build, no FS mount available.");
        return -1;
        rc = fs_mount(mnt);
        return rc;
    static void _setup_disk(void)
        struct fs_mount_t *mp = &fs_mnt;
        struct fs_dir_t dir;
        struct fs_statvfs sbuf;
        int rc;
        fs_dir_t_init(&dir);
        if (IS_ENABLED(CONFIG_DISK_DRIVER_FLASH)) {
            rc = _setup_flash(mp);
            if (rc < 0) {
                LOG_ERR("Failed to setup flash area");
                return;
        if (!IS_ENABLED(CONFIG_FAT_FILESYSTEM_ELM)) {
            LOG_INF("No file system selected");
            return;
        rc = _mount_app_fs(mp);
        if (rc < 0) {
            LOG_ERR("Failed to mount filesystem");
            return;
    .... etc
    So it finds the partition, and the characteristics seem right. but the mount fails.
    The run continues, including:
    [00:00:00.370,727] <inf> base: USB mass storage mode enabled.
    and from the PC I see the USB mass storage as a new drive, and can create/read files on it...
    So why does the FS mount fail?
    I also don't quite see how the USB mass driver "knows" which partition to expose to the USB? How is this link made? is it looking for a specific partition name or a label (the DTS config from 'mass' had an overlay config for an msc_disk0 node liek this:
    msc_disk0 {
            compatible = "zephyr,flash-disk";
            partition = <&storage_partition>;
            disk-name = "NAND";
            cache-size = <4096>;
    &mx25r64 {
        partitions {
            #address-cells = <1>;
            #size-cells = <1>;
            storage_partition: partition@0 {
                label = "storage";
                reg = <0x00000000 0x00020000>;
    But i have that commented out right now as the flashdisk.c code with PM enabled uses the PM config to find the disk partition...maybe the USB exposed file system is not actually on the fatfs_storage partition but actually using a different partition??
    Any pointers? thanks!
  • Some proress;
    1/ ELM FAT can only mount o certain volume names -> can' t use "/flash"
    Changed to "/NAND:", now I get a EIO error
    00:00:00.367,767] <inf> base: Flash USB mass storage opened : area 1 at 0x0 on mx25r6435f@0 for 2097152 bytes
    [00:00:00.378,295] <err> fs: fs mount error (-5)
    [00:00:00.383,575] <err> base: Failed to mount filesystem on /NAND:
    2/ USB mass storage driver finds the flash partition using the KConfig line in prj.conf:
    CONFIG_MASS_STORAGE_DISK_NAME="EXT_FAT_FS"
    as defined in the pm _static.yml extra_params section:
           disk_name: "EXT_FAT_FS",
    But I can't now work out why I get the EIO error when mounting the FS?
  • 2/ USB mass storage driver finds the flash partition using the KConfig line in prj.conf:
    Solved - turns out that although the USB mass driver can find the flash partition, ELM FAT FS requires that the partition 'disk_name' must also be in its restricted list of volume names!
    It would have been nice had this been documented somewhere, eg in comments in the 'mass' sample code?
    Summary of what I've learned:
    for nrf5340, PartitionManager is (currently) required if using 'multi-image' eg a networking stack. When using PM:
    - you can add add specific partitions using a 'pm_static.yml' file in the root dir of the application
    - DTS partition definitions are not required (ignored?)
    For external flash type FAT FS ELM:
    - in pm_static.yml, ensure affiliation attribute is a list with 'disk' eg
    fatfs_storage:
        region: external_flash
        affiliation:
            - disk
        extra_params: {
            disk_name: "NAND",
            disk_cache_size: 4096,
            disk_sector_size: 512,
            disk_read_only: 0
        placement:
            after: [start]
            align: {start: 4096}
        # 2Mb size, external flash is 8Mb total
        address: 0x0
    (note: I called the partition "fatfs_storage", so in the code to find its partition id (which is in the generated file buiid/zephyr/include/generated/pm_config.h) the defines are:
    - in the DTS overlay, you need to map the flash driver with the chosen for the nordic,pm-ext-flash set to the correct driver node eg:
        chosen {
            nordic,pm-ext-flash = &mx25r64;
    - have fs_mount use mount point "/NAND:", KConfig has CONFIG_MASS_STORAGE_DISK_NAME="NAND" and the pm_static.yml has disk_name="NAND" or it won't mount... (or one of the other volume name strings from list in fs.h)
  • Good job figuring this out!
    And thanks a lot for summarizing, it will help future people for sure!
    Is it okay for you if I mark your last reply as Verified and close the ticket?
  • s it okay for you if I mark your last reply as Verified and close the ticket?
    Sure.
    A final couple of notes:
    - if you change the size of the partition _after_ FAT FS has formatted it, it won't be taken into account and you need to re-format it (I did this by explicitly asking the flash driver to erase the partition at boot, and having
    CONFIG_FS_FATFS_MOUNT_MKFS=y
    (so that FAT FS rebuilt it after.that.
    It might also be possible to ask the windows PC to format it - YMMV..
    - probably useful to enable 'long file names'
    CONFIG_FS_FATFS_LFN=y
    as the old 8.3 format is very nasty...
    I couldn't find the KConfig flag however to enable 'relative directory navigation' (FF_FS_RPATH >= 1, as per this page: http://elm-chan.org/fsw/ff/doc/filename.html#:~:text=In%20the%20generic%20FAT%20filesystems,characters%20%5Cx80%20to%20%5CxFF.) which would have been nice...
