USB MASS sample and partition manager build issues
I have my application code which builds and runs on my nrf5340DK. The project files were based on the zephyr sample for multi-advertising BLE.
Right now I'm building the 'secure' app version (board target nrf5340dk_nrf5340_cpuapp)
I now want to add a file system, in the external flash, and enable USB access to it (objective is to have a way to give files to the application firmware over USB)
I took the code & dts/Kconfig from the USB 'mass' zephyr sample to use as a base for this, however the project will not compile, failing at flashdisk.c in the zephyr installation:
[11/142] Building C object zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
FAILED: zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
C:\ncs\toolchains\cf2149caf2\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPICOLIBC_LONG_LONG_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -IC:/work/dev/nordic_connect/zephyr/include -IC:/work/dev/if-device-nrf53/cc1-med/build/zephyr/include/generated -IC:/work/dev/nordic_connect/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/work/dev/nordic_connect/zephyr/soc/common/nordic_nrf/. -IC:/work/dev/nordic_connect/zephyr/soc/arm/nordic_nrf/common/. -IC:/work/dev/nordic_connect/zephyr/subsys/usb/device -IC:/work/dev/nordic_connect/zephyr/subsys/bluetooth -IC:/work/dev/nordic_connect/zephyr/drivers/usb/common/nrf_usbd_common/. -IC:/work/dev/nordic_connect/nrf/include -IC:/work/dev/nordic_connect/nrf/subsys/app_event_manager/. -IC:/work/dev/nordic_connect/nrf/subsys/app_event_manager_profiler_tracer/. -IC:/work/dev/nordic_connect/nrf/tests/include -IC:/work/dev/nordic_connect/modules/lib/cjson -IC:/work/dev/nordic_connect/nrf/modules/cjson/include -IC:/work/dev/nordic_connect/modules/hal/cmsis/CMSIS/Core/Include -IC:/work/dev/nordic_connect/zephyr/modules/cmsis/. -IC:/work/dev/nordic_connect/modules/hal/nordic/nrfx -IC:/work/dev/nordic_connect/modules/hal/nordic/nrfx/drivers/include -IC:/work/dev/nordic_connect/modules/hal/nordic/nrfx/mdk -IC:/work/dev/nordic_connect/zephyr/modules/hal_nordic/nrfx/. -IC:/work/dev/if-device-nrf53/cc1-med/build/modules/libmetal/libmetal/lib/include -IC:/work/dev/nordic_connect/modules/lib/open-amp/open-amp/lib/include -IC:/work/dev/nordic_connect/modules/crypto/tinycrypt/lib/include -IC:/work/dev/nordic_connect/nrfxlib/softdevice_controller/include -isystem C:/work/dev/nordic_connect/zephyr/lib/libc/common/include -isystem C:/work/dev/nordic_connect/nrfxlib/crypto/nrf_cc312_platform/include -Wshadow -fno-strict-aliasing -Os -imacros C:/work/dev/if-device-nrf53/cc1-med/build/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/work/dev/nordic_connect/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/work/dev/if-device-nrf53/cc1-med=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/work/dev/nordic_connect/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/work/dev/nordic_connect=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -MF zephyr\drivers\disk\CMakeFiles\drivers__disk.dir\flashdisk.c.obj.d -o zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -c C:/work/dev/nordic_connect/zephyr/drivers/disk/flashdisk.c
C:/work/dev/nordic_connect/zephyr/drivers/disk/flashdisk.c:484:1: error: return type defaults to 'int' [-Werror=implicit-int]
484 | PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_CACHE)
C:/work/dev/nordic_connect/zephyr/drivers/disk/flashdisk.c: In function 'PM_FOREACH_AFFILIATED_TO_disk':
C:/work/dev/nordic_connect/zephyr/drivers/disk/flashdisk.c:523:30: error: storage class specified for parameter 'flash_disks'
523 | static struct flashdisk_data flash_disks[] = {
C:/work/dev/nordic_connect/zephyr/drivers/disk/flashdisk.c:523:15: error: parameter 'flash_disks' is initialized
C:/work/dev/nordic_connect/zephyr/drivers/disk/flashdisk.c:524:39: error: 'DEFINE_FLASHDISKS_DEVICE' undeclared (first use in this function)
524 | PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_DEVICE)
etc etc as ever when one of these macros has an issue its very tricky to work out why....
Looking at the flashdisk.c code it seems to be in the USE_PARTITION_MANAGER case, so I guess its not finding some PM config to define the flash disk parameters?
Q: do I need to use the Partition Manager sub system? The DTS files appear to define the partitions required just fine...The mass example does not have a pm.yml either?
If I have to use PM (my reading implies 'yes', because the nrf5340 requires a multi-image hex due to the 2 processors?), where, how to configure its partitions if not in the DTS?
I tried to build the 'mass' sample standalone copied directly from the NCS; but it also fails to compile with this error:
CMake Error at CMakeLists.txt:10 (message):
No disk access settings detected.
Any ideas what I'm doing wrong?
Thanks
Brian
full compile output for 'mass' sample:
C:\work\dev\if-device-nrf53\mass>west build -p
-- Application: C:/work/dev/if-device-nrf53/mass
-- CMake version: 3.21.0
-- Using NCS Toolchain 2.6.20240304.889616714482 for building. (C:/ncs/toolchains/cf2149caf2/cmake)
-- Found Python3: C:/ncs/toolchains/cf2149caf2/opt/bin/python.exe (found suitable version "3.9.13", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/work/dev/nordic_connect/zephyr/.cache
-- Zephyr version: 3.5.99 (C:/work/dev/nordic_connect/zephyr)
-- Board: nrf5340dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.16.5 (C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.5 (C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/cf2149caf2/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/work/dev/nordic_connect/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: C:/work/dev/if-device-nrf53/mass/boards/nrf5340dk_nrf5340_cpuapp.overlay
-- Generated zephyr.dts: C:/work/dev/if-device-nrf53/mass/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/work/dev/if-device-nrf53/mass/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/work/dev/if-device-nrf53/mass/build/zephyr/dts.cmake
Parsing C:/work/dev/if-device-nrf53/mass/Kconfig
Loaded configuration 'C:/work/dev/nordic_connect/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/work/dev/if-device-nrf53/mass/prj.conf'
Configuration saved to 'C:/work/dev/if-device-nrf53/mass/build/zephyr/.config'
Kconfig header saved to 'C:/work/dev/if-device-nrf53/mass/build/zephyr/include/generated/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
CMake Warning at C:/work/dev/nordic_connect/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
CONFIG_USB_DEVICE_VID has default value 0x2FE3.
This value is only for testing and MUST be configured for USB products.
CMake Warning at C:/work/dev/nordic_connect/zephyr/CMakeLists.txt:862 (message):
No SOURCES given to Zephyr library: drivers__disk
Excluding target from build.
See also "C:/work/dev/if-device-nrf53/mass/build/CMakeFiles/CMakeOutput.log".
See also "C:/work/dev/if-device-nrf53/mass/build/CMakeFiles/CMakeError.log".
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\cf2149caf2\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/cf2149caf2/opt/bin/python.exe '-BC:\work\dev\if-device-nrf53\mass\build' -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp '-SC:\work\dev\if-device-nrf53\mass'
  • Instead, lets take a step back and check something that should be verified support for: Could you try to test with APP_MSCC_STORAGE_FLASH_LITTLEFS instead? This
    OK. the 'mass' sample builds ok with
    west build --build-dir mass/build mass --pristine -DCONFIG_APP_MSC_STORAGE_FLASH_LITTLEFS=y
    also with
    west build --build-dir mass/build mass --pristine -DCONFIG_APP_MSC_STORAGE_FLASH_FATFS=y
    BUT not with:
    west build --build-dir mass/build mass --pristine -DCONFIG_APP_MSC_STORAGE_FLASH_LITTLEFS=y -DCONFIG_PM_SINGLE_IMAGE=y
    ie it does NOT work if the partition manager is enabled (which is a must when building for nRF5340 and using bluetooth....)
    So its not a question of using FAT or LittleFS file systems. (btw, FATFS is required as otherwise the PC attached to the USB will not be able to access the FS...)
    For me, the problem is because flashdisk.c in the core zephyr code needs to find a flash partition with the 'disk' affiliation, and this means the PM requires a pm.yml file to define this, yes?
    SO: how do I get PM to pick up my pm.yml file? Putting it in the root dir doesn't work. Putting it in 'child_image' sub folder doesn't work.
    Can you try building the mass sample with PM enabled for a nrf5340DK, using the external flash for the USB mass storage and tell me what is required to get it to build?
    thanks
  • I updated my yml file (called pm_ext_fs.yml) with the fix from that report (make affiliation a list)
    fatfs_storage:
        region: external_flash
        affiliation:
            - disk
        extra_params: {
            disk_name: "NAND",
            disk_cache_size: 4096,
            disk_sector_size: 512,
            disk_read_only: 0
        placement:
            after: [start]
            align: {start: 4096}
        # 2Mb size, external flash is 8Mb total
    To get PM to load it, I added to CMakeList.txt in root of application:
    if(CONFIG_PARTITION_MANAGER_ENABLED)
      ncs_add_partition_manager_config(pm_ext_fatfs.yml)
      message( INFO " Added pm_ext_fatfs.yml to partition manager...")
    endif()
    This passes and I get the log message, but the file contents seem to be ignored by PM : no effect on the generated pm_config.h / Pm.config or partitions.yml files -> still no success.
    Next, I tried renaming it to pm_static.yml in root dir. (found this piece of magic in that bug report also)
    This time the compilation includes the log "-- Found partition manager static configuration: C:/work/dev/if-device-nrf53/cc1-med/pm_static.yml".But it then bombs because it requires an 'address' field....(I tried with the placement before: [end], same result)
    Adding
        address: 0x0
    and everything compiles as it should including the generated partition id for fatfs_storage.
    This means that it works, right?
    If so, great news!
  • This means that it works, right?
    Ah, it compiles! Not quite the same thing....
    When run, I get this logs/error:
    Area 1 at 0x0 on mx25r6435f@0 for 2097152 bytes
    [00:00:00.359,222] <err> fs: fs mount error (-19)
    [00:00:00.364,624] <err> base: Failed to mount filesystem
    which comes from this code (pretty much directly from the mass sample code)
    #define STORAGE_PARTITION       fatfs_storage
    #define STORAGE_PARTITION_ID        FIXED_PARTITION_ID(STORAGE_PARTITION)
    static struct fs_mount_t fs_mnt;
    static int _setup_flash(struct fs_mount_t *mnt)
        int rc = 0;
    #if CONFIG_DISK_DRIVER_FLASH
        unsigned int id;
        const struct flash_area *pfa;
        mnt->storage_dev = (void *)STORAGE_PARTITION_ID;
        id = STORAGE_PARTITION_ID;
        rc = flash_area_open(id, &pfa);
        printk("Area %u at 0x%x on %s for %u bytes\n",
               id, (unsigned int)pfa->fa_off, pfa->fa_dev->name,
               (unsigned int)pfa->fa_size);
        if (rc < 0 && IS_ENABLED(CONFIG_APP_WIPE_STORAGE)) {
            printk("Erasing flash area ... ");
            rc = flash_area_erase(pfa, 0, pfa->fa_size);
            printk("%d\n", rc);
        if (rc < 0) {
            flash_area_close(pfa);
        return rc;
    static int _mount_app_fs(struct fs_mount_t *mnt)
        int rc;
    #if CONFIG_FAT_FILESYSTEM_ELM
        static FATFS fat_fs;
        mnt->type = FS_FATFS;
        mnt->fs_data = &fat_fs;
        mnt->mnt_point = "/flash:";
    #else
        log_warn("no file system type defined in firmware build, no FS mount available.");
        return -1;
        rc = fs_mount(mnt);
        return rc;
    static void _setup_disk(void)
        struct fs_mount_t *mp = &fs_mnt;
        struct fs_dir_t dir;
        struct fs_statvfs sbuf;
        int rc;
        fs_dir_t_init(&dir);
        if (IS_ENABLED(CONFIG_DISK_DRIVER_FLASH)) {
            rc = _setup_flash(mp);
            if (rc < 0) {
                LOG_ERR("Failed to setup flash area");
                return;
        if (!IS_ENABLED(CONFIG_FAT_FILESYSTEM_ELM)) {
            LOG_INF("No file system selected");
            return;
        rc = _mount_app_fs(mp);
        if (rc < 0) {
            LOG_ERR("Failed to mount filesystem");
            return;
    .... etc
    So it finds the partition, and the characteristics seem right. but the mount fails.
    The run continues, including:
    [00:00:00.370,727] <inf> base: USB mass storage mode enabled.
    and from the PC I see the USB mass storage as a new drive, and can create/read files on it...
    So why does the FS mount fail?
    I also don't quite see how the USB mass driver "knows" which partition to expose to the USB? How is this link made? is it looking for a specific partition name or a label (the DTS config from 'mass' had an overlay config for an msc_disk0 node liek this:
    msc_disk0 {
            compatible = "zephyr,flash-disk";
            partition = <&storage_partition>;
            disk-name = "NAND";
            cache-size = <4096>;
    &mx25r64 {
        partitions {
            #address-cells = <1>;
            #size-cells = <1>;
            storage_partition: partition@0 {
                label = "storage";
                reg = <0x00000000 0x00020000>;
    But i have that commented out right now as the flashdisk.c code with PM enabled uses the PM config to find the disk partition...maybe the USB exposed file system is not actually on the fatfs_storage partition but actually using a different partition??
    Any pointers? thanks!
