application nrf5340_audio example packet loss problem
I'm experiencing high packet loss with the application nrf5340_audio example, I'm using nrf5340 audio DK as a unicast server, and then I'm using a Sony phone to connect to it (distance between devices is about 40cm), letting the phone play music, and I've tested the packet loss rate in the air. The packet loss rate in the air is between 10% and 15%. I don't think the result should be so bad, but I wonder if I have overlooked some configuration.
My packet loss rate from the code(https://github.com/nrfconnect/sdk-nrf/blob/v2.6.1/applications/nrf5340_audio/src/audio/le_audio_rx.c#L74).
Currently, I am using SDK version v2.6.1, attached is my configuration file, please let me know if you need more information. Thanks.
5516.config.txt
