undefined reference to `nrf_drv_twi_init'
I am trying to program nrf52840 to print acceleration from mpu6050. But when I build the project, I get the error - undefined reference to `nrf_drv_twi_init'. Here is the main.c file.
#include <stdbool.h>
#include <stdio.h>
#include <stdint.h>
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf.h"
// I2C (TWI) configuration
#define TWI_INSTANCE_ID     0
#define MPU6050_ADDR        0x68  // MPU6050 I2C address
#define MPU6050_REG_PWR_MGMT_1   0x6B
#define MPU6050_REG_ACCEL_XOUT_H 0x3B
#define MPU6050_REG_GYRO_XOUT_H  0x43
// TWI instance
static const nrf_drv_twi_t twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
// Function prototypes
void twi_init(void);
void mpu6050_init(void);
void mpu6050_write_byte(uint8_t reg, uint8_t data);
void mpu6050_read_bytes(uint8_t reg, uint8_t *data, uint8_t len);
void twi_init(void) {
    nrf_drv_twi_config_t twi_config = {
       .scl                = 22,
       .sda                = 23,
       .frequency          = NRF_DRV_TWI_FREQ_400K,
       .clear_bus_init     = false
    nrf_drv_twi_init(&twi, &twi_config, NULL, NULL);
    nrf_drv_twi_enable(&twi);
void mpu6050_write_byte(uint8_t reg, uint8_t data) {
    uint8_t buffer[2] = {reg, data};
    nrf_drv_twi_tx(&twi, MPU6050_ADDR, buffer, sizeof(buffer), false);
void mpu6050_read_bytes(uint8_t reg, uint8_t *data, uint8_t len) {
    nrf_drv_twi_tx(&twi, MPU6050_ADDR, &reg, 1, true);
    nrf_drv_twi_rx(&twi, MPU6050_ADDR, data, len);
void mpu6050_init(void) {
    mpu6050_write_byte(MPU6050_REG_PWR_MGMT_1, 0x00); // Wake up sensor
int main(void) {
    twi_init();
    mpu6050_init();
    uint8_t accel_data[6];
    uint8_t gyro_data[6];
    int16_t ax, ay, az, gx, gy, gz;
    while (true) {
        mpu6050_read_bytes(MPU6050_REG_ACCEL_XOUT_H, accel_data, 6);
        mpu6050_read_bytes(MPU6050_REG_GYRO_XOUT_H, gyro_data, 6);
        //printf("accel data = %d %d %d %d %d %d\n",accel_data[0],accel_data[1],accel_data[2],accel_data[3],accel_data[4],accel_data[5],accel_data[6]);
        ax = (int16_t)((accel_data[0] << 8) | accel_data[1]);
        ay = (int16_t)((accel_data[2] << 8) | accel_data[3]);
        az = (int16_t)((accel_data[4] << 8) | accel_data[5]);
        gx = (int16_t)((gyro_data[0] << 8) | gyro_data[1]);
        gy = (int16_t)((gyro_data[2] << 8) | gyro_data[3]);
        gz = (int16_t)((gyro_data[4] << 8) | gyro_data[5]);
        printf("Accel: X=%d, Y=%d, Z=%d; Gyro: X=%d, Y=%d, Z=%d\n", ax, ay, az, gx, gy, gz);
        nrf_delay_ms(1000);
This is the error I am getting.
Executing task: nRF Connect: Build: fund_less6_exer1_solution/build (active)
Building fund_less6_exer1_solution
west build --build-dir /home/akshat/Downloads/ncs-fund-main/v2.x.x/lesson6/fund_less6_exer1_solution/build /home/akshat/Downloads/ncs-fund-main/v2.x.x/lesson6/fund_less6_exer1_solution
[3/7] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/akshat/Downloads/ncs-fund-main/v2.x.x/lesson6/fund_less6_exer1_solution/build/zephyr/zephyr_pre0.map
: && ccache /home/akshat/ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/akshat/Downloads/ncs-fund-main/v2.x.x/lesson6/fund_less6_exer1_solution/build/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/picolibc/liblib__libc__picolibc.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/nrf52840/libsoc__nordic.a  zephyr/drivers/adc/libdrivers__adc.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/i2c/libdrivers__i2c.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/home/akshat/ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp"  -L/home/akshat/Downloads/ncs-fund-main/v2.x.x/lesson6/fund_less6_exer1_solution/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -mtp=soft  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  -DPICOLIBC_DOUBLE_PRINTF_SCANF  /home/akshat/ncs/v2.7.0-rc3/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_platform_0.9.19.a  --specs=picolibc.specs  -lc  -lgcc && cd /home/akshat/Downloads/ncs-fund-main/v2.x.x/lesson6/fund_less6_exer1_solution/build/zephyr && /home/akshat/ncs/toolchains/2be090971e/usr/local/bin/cmake -E true
/home/akshat/ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `twi_init':
/home/akshat/Downloads/ncs-fund-main/v2.x.x/lesson6/fund_less6_exer1_solution/src/main.c:36: undefined reference to `nrf_drv_twi_init'
collect2: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: /home/akshat/ncs/toolchains/2be090971e/usr/local/bin/cmake --build /home/akshat/Downloads/ncs-fund-main/v2.x.x/lesson6/fund_less6_exer1_solution/build
 *  The terminal process terminated with exit code: 1.
This is the nrf_drv_twi.c file where the funtion is defined at line 161.
 * Copyright (c) 2017 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
#include <hal/nrf_gpio.h>
#ifdef TWIM_PRESENT
#define INSTANCE_COUNT   TWIM_COUNT
#else
#define INSTANCE_COUNT   TWI_COUNT
#define SCL_PIN_INIT_CONF                                     \
    ( (GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos) \
    | (GPIO_PIN_CNF_DRIVE_S0D1     << GPIO_PIN_CNF_DRIVE_Pos) \
    | (GPIO_PIN_CNF_PULL_Pullup    << GPIO_PIN_CNF_PULL_Pos)  \
    | (GPIO_PIN_CNF_INPUT_Connect  << GPIO_PIN_CNF_INPUT_Pos) \
    | (GPIO_PIN_CNF_DIR_Input      << GPIO_PIN_CNF_DIR_Pos))
#define SDA_PIN_INIT_CONF        SCL_PIN_INIT_CONF
#define SDA_PIN_UNINIT_CONF                                     \
    | (GPIO_PIN_CNF_DRIVE_H0H1       << GPIO_PIN_CNF_DRIVE_Pos) \
    | (GPIO_PIN_CNF_PULL_Disabled    << GPIO_PIN_CNF_PULL_Pos)  \
    | (GPIO_PIN_CNF_INPUT_Disconnect << GPIO_PIN_CNF_INPUT_Pos) \
#define SCL_PIN_UNINIT_CONF      SDA_PIN_UNINIT_CONF
#define SCL_PIN_INIT_CONF_CLR                                 \
    | (GPIO_PIN_CNF_DIR_Output     << GPIO_PIN_CNF_DIR_Pos))
#define SDA_PIN_INIT_CONF_CLR    SCL_PIN_INIT_CONF_CLR
static nrf_drv_twi_evt_handler_t m_handlers[INSTANCE_COUNT];
static void *                    m_contexts[INSTANCE_COUNT];
static void twi_clear_bus(nrf_drv_twi_config_t const * p_config)
    NRF_GPIO->PIN_CNF[p_config->scl] = SCL_PIN_INIT_CONF;
    NRF_GPIO->PIN_CNF[p_config->sda] = SDA_PIN_INIT_CONF;
    nrf_gpio_pin_set(p_config->scl);
    nrf_gpio_pin_set(p_config->sda);
    NRF_GPIO->PIN_CNF[p_config->scl] = SCL_PIN_INIT_CONF_CLR;
    NRF_GPIO->PIN_CNF[p_config->sda] = SDA_PIN_INIT_CONF_CLR;
    nrf_delay_us(4);
    for (int i = 0; i < 9; i++)
        if (nrf_gpio_pin_read(p_config->sda))
            if (i == 0)
                return;
        nrf_gpio_pin_clear(p_config->scl);
        nrf_delay_us(4);
        nrf_delay_us(4);
    nrf_gpio_pin_clear(p_config->sda);
    nrf_delay_us(4);
#ifdef TWIM_PRESENT
static void twim_evt_handler(nrfx_twim_evt_t const * p_event,
                             void *                  p_context)
    uint32_t inst_idx = (uint32_t)p_context;
    nrf_drv_twi_evt_t const event =
        .type = (nrf_drv_twi_evt_type_t)p_event->type,
        .xfer_desc =
            .type = (nrf_drv_twi_xfer_type_t)p_event->xfer_desc.type,
            .address          = p_event->xfer_desc.address,
            .primary_length   = p_event->xfer_desc.primary_length,
            .secondary_length = p_event->xfer_desc.secondary_length,
            .p_primary_buf    = p_event->xfer_desc.p_primary_buf,
            .p_secondary_buf  = p_event->xfer_desc.p_secondary_buf,
    m_handlers[inst_idx](&event, m_contexts[inst_idx]);
#endif // TWIM_PRESENT
#ifdef TWI_PRESENT
static void twi_evt_handler(nrfx_twi_evt_t const * p_event,
                            void *                 p_context)
        .xfer_desc =
#endif // TWI_PRESENT
ret_code_t nrf_drv_twi_init(nrf_drv_twi_t const *        p_instance,
                            nrf_drv_twi_config_t const * p_config,
                            nrf_drv_twi_evt_handler_t    event_handler,
                            void *                       p_context)
    uint32_t inst_idx = p_instance->inst_idx;
    m_handlers[inst_idx] = event_handler;
    m_contexts[inst_idx] = p_context;
    if(p_config->clear_bus_init)
        /* Send clocks (max 9) until slave device back from stuck mode */
        twi_clear_bus(p_config);
    ret_code_t result = 0;
    if (NRF_DRV_TWI_USE_TWIM)
        result = nrfx_twim_init(&p_instance->u.twim,
                                (nrfx_twim_config_t const *)p_config,
                                event_handler ? twim_evt_handler : NULL,
                                (void *)inst_idx);
    else if (NRF_DRV_TWI_USE_TWI)
        result = nrfx_twi_init(&p_instance->u.twi,
                               (nrfx_twi_config_t const *)p_config,
                               event_handler ? twi_evt_handler : NULL,
                               (void *)inst_idx);
    return result;
can you please help me with this error and guide me on how to correct this.
