I cannot get the nrf5340 audio dk kit to work from USB input properly. After a reset, it only works for a fraction of a second and audio stops. Has anyone run into a similar problem? Please see attached video.
Thank you Caram5555. I had given up on this hardware a while ago. I am not sure where to make this configuration change, but I will give it a try.
I just checked my setup. Kconfig says the options available are 16k, 24k and 48k, with the default set to 48k. It also says only 48k supports USB and line-in. Where is this file where I can change the hp-sample-rate-hz? I want to try it.
Can you test if the same problem is still there in NCS v2.9.0?
If you still see the issue, please provide complete log.
Dejan
