I cannot get the nrf5340 audio dk kit to work from USB input properly. After a reset, it only works for a fraction of a second and audio stops. Has anyone run into a similar problem? Please see attached video.
Oops, I thought you were recommending 2.6.0 and older.
Yes I am using the default samples and flashing the script as in below.
python3 buildprog.py -c both -b debug -d both -p
The only change I made is to the prj.conf file to enable and disable analog audio input using...
#CONFIG_AUDIO_SOURCE_I2S=y
assegid said:Oops, I thought you were recommending 2.6.0 and older.
Hehe understandably so, I see that I mistyped in my first response there. Sorry about that.
Could you check the log from the gateway, and see if it blames this on anything in particular?
Elfving
