Migration to sysbuid - fixed partition is not recognized
Hello !
I recently updated our project SDK from 2.6.0 to 2.7.0 and our custom board to HW v2 layout. Everything went almost seemless until I tried to enable sysbuild option (on NRF52, single image build - application only, no bootloader).
On legacy cmake build, compilation is successfull. But on sysbuild, I get the following build errors (prt error log at the end).
Our storage fixed-partitions are correctly defined in our board DTS, so I assume I miss some SB specific options, but I don't know which ones (I tried SB partition manager but it didn't work)
Could you provide me support with this ?
Thanks !
In file included from C:/workspaces/firmware-ng/zephyr/include/zephyr/sys/util_macro.h:34,
                 from C:/workspaces/firmware-ng/zephyr/include/zephyr/sys/util.h:17,
                 from C:/workspaces/firmware-ng/zephyr/include/zephyr/sys/atomic.h:18,
                 from C:/workspaces/firmware-ng/zephyr/include/zephyr/kernel_includes.h:25,
                 from C:/workspaces/firmware-ng/zephyr/include/zephyr/kernel.h:17,
                 from C:/workspaces/firmware-ng/firmware-zephyr/applications/label/src/subsys/flash/flash_storage.c:2:
C:/workspaces/firmware-ng/firmware-zephyr/applications/label/src/subsys/flash/flash_storage.c: In function 'flash_storage_init':
C:/workspaces/firmware-ng/nrf/include/flash_map_pm.h:52:18: error: 'PM_PM_PM_storage_partition_ID_LABEL_OFFSET' undeclared (first use in this function)
   52 |         UTIL_CAT(PM_, UTIL_CAT(UTIL_CAT(PM_, UTIL_CAT(PM_ID(label), _LABEL)), x))
C:/workspaces/firmware-ng/zephyr/include/zephyr/sys/util_internal.h:105:36: note: in definition of macro 'UTIL_PRIMITIVE_CAT'
  105 | #define UTIL_PRIMITIVE_CAT(a, ...) a##__VA_ARGS__
C:/workspaces/firmware-ng/nrf/include/flash_map_pm.h:52:9: note: in expansion of macro 'UTIL_CAT'
C:/workspaces/firmware-ng/nrf/include/flash_map_pm.h:55:39: note: in expansion of macro 'FIXED_PARTITION_DATA_FIELD'
   55 | #define FIXED_PARTITION_OFFSET(label) FIXED_PARTITION_DATA_FIELD(label, _OFFSET)
C:/workspaces/firmware-ng/firmware-zephyr/applications/label/src/subsys/flash/flash_storage.c:13:45: note: in expansion of macro
FIXED_PARTITION_OFFSET'
   13 | #define STORAGE_PARTITION_OFFSET            FIXED_PARTITION_OFFSET(STORAGE_PARTITION)
C:/workspaces/firmware-ng/firmware-zephyr/applications/label/src/subsys/flash/flash_storage.c:192:32: note: in expansion of macro 'STORAGE_PARTITION_OFFSET'
  192 |     ctx.buffer.config.offset = STORAGE_PARTITION_OFFSET;
C:/workspaces/firmware-ng/nrf/include/flash_map_pm.h:52:18: note: each undeclared identifier is reported only once for each function it appears in
C:/workspaces/firmware-ng/nrf/include/flash_map_pm.h:52:18: error: 'PM_PM_PM_storage_partition_ID_LABEL_SIZE' undeclared (first use in this function)
C:/workspaces/firmware-ng/nrf/include/flash_map_pm.h:58:37: note: in expansion of macro 'FIXED_PARTITION_DATA_FIELD'
   58 | #define FIXED_PARTITION_SIZE(label) FIXED_PARTITION_DATA_FIELD(label, _SIZE)
C:/workspaces/firmware-ng/firmware-zephyr/applications/label/src/subsys/flash/flash_storage.c:14:45: note: in expansion of macro
FIXED_PARTITION_SIZE'
   14 | #define STORAGE_PARTITION_SIZE              FIXED_PARTITION_SIZE(STORAGE_PARTITION)
C:/workspaces/firmware-ng/firmware-zephyr/applications/label/src/subsys/flash/flash_storage.c:193:30: note: in expansion of macro 'STORAGE_PARTITION_SIZE'
  193 |     ctx.buffer.config.size = STORAGE_PARTITION_SIZE;
