error: 'DT_N_S_pwmleds_S_pwm_led_0_P_gpios_IDX_0_PH_P_label' undeclared
I am trying to use PWM to control two LEDS, one red and one green (referred to as blueled in the code) to produce different colours. I have had a look at the example _fade-led-sample provided by Nordic and based my changes on this. However, I am seeing some errors when I try to build my project in Segger Embedded Studio.
9> zephyr/include/generated/devicetree_unfixed.h:1949:33: error: 'DT_N_S_pwmleds_S_pwm_led_0_P_gpios_IDX_0_PH_P_label' undeclared (first use in this function); did you mean 'DT_N_S_pwmleds_S_pwm_led_0_P_pwms_IDX_0_VAL_channel'?
9> zephyr/include/generated/devicetree_unfixed.h:1949:33: error: 'DT_N_S_pwmleds_S_pwm_led_0_P_gpios_IDX_0_VAL_pin' undeclared (first use in this function); did you mean 'DT_N_S_leds_S_led_0_P_gpios_IDX_0_VAL_pin'?
9> zephyr/include/generated/devicetree_unfixed.h:2002:33: error: 'DT_N_S_pwmleds_S_pwm_led_1_P_gpios_IDX_0_PH_P_label' undeclared (first use in this function); did you mean 'DT_N_S_pwmleds_S_pwm_led_1_P_pwms_IDX_0_PH'?
9> zephyr/include/generated/devicetree_unfixed.h:2002:33: error: 'DT_N_S_pwmleds_S_pwm_led_1_P_gpios_IDX_0_VAL_pin' undeclared (first use in this function); did you mean 'DT_N_S_leds_S_led_1_P_gpios_IDX_0_VAL_pin'?
Note, I am using the following development environment.
- Zephyr OS build v2.6.99-ncs1
- SEGGER Embedded Studio for ARM
  Release 5.60  Build 2021081102.47262
  Nordic Edition
  Windows x64
I am attaching the build error logs, my overlay file and snippets of my C code. The file prj.conf contains the line CONFIG_PWM=y.
Thank you for your help.
0676.nrf52833dk_nrf52833.overlay
#include <stdio.h>
#include <zephyr.h>
#include <arch/cpu.h>
#include <sys/printk.h>
#include <device.h>
#include <devicetree.h>
#include <drivers/gpio.h>
#include <drivers/pwm.h>
#include <drivers/i2c.h>
#include <drivers/spi.h>
#include <drivers/adc.h>
#include <logging/log.h>
#include <logging/log_ctrl.h>
[snip]
#define PWM_OFF                                     (0U)
#define PWM_PERCENTAGE_ORANGE                       (23U)
#define LED_TEST                                    0
#define FADING_TEST                                 1
static result_t io_PWM_initialise (uint8_t percentage);
static void pwm_stop(void);
//static void registers_read(void);
//static void LED_test(void);
static void fading_test(void);
    !GLOBAL VARIABLES
//Leds
const struct device *io_redled_dev;
const struct device *io_blueled_dev;
const struct device *pwm_dev;
[snip]
void io_led_initialise(void)
    uint8_t ret;
    /* Initialise IO ports attached to the LEDs */
    io_redled_dev = device_get_binding( DT_GPIO_LABEL(DT_ALIAS( redled ), gpios ) );
    if ( io_redled_dev )
        ret = gpio_pin_configure( io_redled_dev,
                                  DT_GPIO_PIN( DT_ALIAS( redled ), gpios ),
                                  GPIO_OUTPUT_INACTIVE | DT_GPIO_FLAGS( DT_ALIAS(redled ), gpios ) );
        if ( ret )
            LOG_ERR( "RedLed not configured" );
        LOG_ERR( "RedLed not bound" );
    io_blueled_dev = device_get_binding( DT_GPIO_LABEL( DT_ALIAS( blueled ), gpios ) );
    if ( io_blueled_dev )
        ret = gpio_pin_configure( io_blueled_dev,
                                  DT_GPIO_PIN(DT_ALIAS(blueled), gpios),
                                  GPIO_OUTPUT_INACTIVE | DT_GPIO_FLAGS( DT_ALIAS( blueled ), gpios ) );
        if ( ret )
            LOG_ERR( "Green not configured" );
        LOG_ERR( "GreenLed not bound" );
    #ifdef SALEAE
    io_buzzerP_dev = device_get_binding(DT_GPIO_LABEL(DT_ALIAS(buz_p), gpios));
    if ( io_buzzerP_dev == NULL )
        LOG_ERR( "BuzzerP not bound" );
    gpio_pin_configure(io_buzzerP_dev, DT_GPIO_PIN(DT_ALIAS(buz_p), gpios), GPIO_OUTPUT_INACTIVE | DT_GPIO_FLAGS(DT_ALIAS(buz_p), gpios));
    if ( ret )
        LOG_ERR( "BuzzerP not configured" );
    io_buzzerN_dev = device_get_binding(DT_GPIO_LABEL(DT_ALIAS(buz_n), gpios));
    if ( io_buzzerN_dev == NULL )
        LOG_ERR( "BuzzerN not bound" );
    gpio_pin_configure(io_buzzerN_dev, DT_GPIO_PIN(DT_ALIAS(buz_n), gpios), GPIO_OUTPUT_INACTIVE | DT_GPIO_FLAGS(DT_ALIAS(buz_n), gpios));
    if ( ret )
        LOG_ERR( "BuzzerN not configured" );
void io_led_on(uint8_t colour)
    if ( colour & GREEN_LED )
        io.led.state |= GREEN_LED;
        gpio_pin_set( io_blueled_dev, DT_GPIO_PIN(DT_ALIAS(blueled),gpios), 1 );
    if ( colour & RED_LED )
        io.led.state |= RED_LED;
        gpio_pin_set( io_redled_dev, DT_GPIO_PIN(DT_ALIAS(redled),gpios), 1 );
void io_led_off(uint8_t colour)
        io.led.state &= ~GREEN_LED;
        gpio_pin_set( io_blueled_dev, DT_GPIO_PIN(DT_ALIAS(blueled),gpios), 0 );
        io.led.state &= ~RED_LED;
        gpio_pin_set( io_redled_dev, DT_GPIO_PIN(DT_ALIAS(redled),gpios), 0 );
// New PWM code
#define PWM_LED0_NODE   DT_ALIAS(pwm_led0)
#if DT_NODE_HAS_STATUS(PWM_LED0_NODE, okay)
#define PWM_CTLR    DT_PWMS_CTLR(PWM_LED0_NODE)
#define PWM_CHANNEL DT_PWMS_CHANNEL(PWM_LED0_NODE)
#define PWM_FLAGS   DT_PWMS_FLAGS(PWM_LED0_NODE)
#else
#error "Unsupported board: pwm-led0 devicetree alias is not defined"
#define PWM_CTLR    DT_INVALID_NODE
#define PWM_CHANNEL 0
#define PWM_FLAGS   0
    uint32_t period = 1000;   /* 1000us = 1 ms 1000 Hz */
    uint32_t pwm_percentage ;
    int ret;
    result_t result = RESULT_ERROR;
    static boolean_t initialised = FALSE;
    pwm_dev = DEVICE_DT_GET(PWM_CTLR);
    if (device_is_ready(pwm_dev)) /* Check that the structure in ROM containing settings exists */
        if ( percentage > 100)
            percentage = 100; /* Limit maximum value to 100% */
        pwm_percentage = ( (uint32_t) percentage * period) / 100; /* Scale percentage to 0 to 1000 */
        /* The function pwm_pin_set_usec() is used to setup the PWM and takes 4 arguments:
         * pwm_dev = pointer to structure in ROM containing settings for PWM0 to PWM3
         * PWM_CHANNEL = 0 for PWM0.
         * period = 1000us = 1ms.
         * pwm_percentage = % of time PWM is active, 0 = 0% off 100 = 100% full on.
         * PWM_FLAGS = 0. Not used.
        ret = pwm_pin_set_usec(pwm_dev, PWM_CHANNEL, period, pwm_percentage, PWM_FLAGS);
        if ( ret == 0)
            result = RESULT_OK;
            if ( percentage > 0 )
              initialised = TRUE; /* Running some value of PWM rather than being off */
        if ( percentage == 0 && initialised == TRUE )
            /* Do this after the green LED has been set to 0% and was previously running PWM */
            pwm_stop();  /* Only expecuted if PWM percentage was previously 1% or greater */
        LOG_ERR( "PWM Device not bound" );
    return (result);
void io_led_on( uint8_t colour, uint32_t pulse_width )
    if ( ( pwm_dev == NULL ) || ( pwm_dev == NULL ) )
        return;
        pwm_pin_set_usec( pwm_dev,                              /* Pointer to the Green LED dev struct */
                          DT_PWMS_CHANNEL(DT_ALIAS(blueled)),   /* PWM pin/channel */
                          PERIOD_USEC,                          /* PWM period in USEC */
                          pulse_width,                          /* PWM pulse width in USEC */
                          DT_PWMS_FLAGS(DT_ALIAS(blueled))  );  /* PWM Flags for pin config (polarity)*/
        pwm_pin_set_usec( pwm_dev,                              /* Pointer to the Red LED dev struct */
                          DT_PWMS_CHANNEL(DT_ALIAS(redled)),    /* PWM pin/channel */
                          DT_PWMS_FLAGS(DT_ALIAS(redled))   );  /* PWM Flags for pin config (polarity)*/
void io_led_off( uint8_t colour )
        return;
        pwm_pin_set_usec(pwm_dev, DT_PWMS_CHANNEL(DT_ALIAS(blueled)), PERIOD_USEC,0,0);
        pwm_pin_set_usec(pwm_dev, DT_PWMS_CHANNEL(DT_ALIAS(redled)), PERIOD_USEC,0,0);
*      Fading test. Cycles through all the PWM values from 0% to 100%
/* Used to determine which PWM percentage gives the best orange */
#ifdef FADING_TEST
    static uint8_t counter = 0;
    io_PWM_initialise(counter);
    if ( counter >= 100)
        counter = 0;
        counter++;
*                  New Function to turn off PWM. PTC 82496
 * The original blinky_pwm code did not provide a global function to turn off
 * the PWM. Use low level code to directly write to the PWM_TASKS_STOP register
 * at address 0x4001C004.
 * There is also the PWM0_ENABLE register, but this is best not used as it does
 * not re-enable the next time used.
    registers_read();   /* Check status of PWM registers while running */
    PWM0_TASKS_STOP = TRIGGER_TASK;
    /*  PWM0_ENABLE = DISABLE; Do not use this. Does not re-enable the next time through */
    registers_read();  /* Check status of PWM registers when stopped */
 *  This function needs to be called every 250 ms as was the case in the
 *  Homestation firmware.
void io_update(void)
    [snip]
#if ( LED_TEST )
    LED_test(); /* Test for contention between GPIO and PWM driving LEDS */
#if ( FADING_TEST )
    fading_test();  /* Cycles through PWM percentage between 0% and 100% */
void main( void )
    [snip]
    io_update();
Build_error-1.txt
Kind regards
Mohamed
    NCS v1.7.0 is quite an old version. Please try the latest version v2.7.0 and take a look at this course: Troubleshooting the devicetree
    Amanda H.
  • Thank you Amanda.
    Unfortunately I do not want to update to a more recent version at this stage. I would rather get it to work with v1.7.0.
    Kind regards
    Mohamed
  • Thank you Amanda.
    The line in question can be found at line 142 in the C code I share with you.
    I managed to get the code to build without errors since my last post. But I still have other problems.
    I will share with you the new C code snippets shortly. The overlay file has not changed since yesterday.
    #include <stdio.h>
    #include <zephyr.h>
    #include <device.h>
    [snip]
    #define LED_TEST                                    0
        !GLOBAL VARIABLES
    //Leds
    [snip]
    // New PWM code
    #define PWM_LED1_NODE   DT_ALIAS(pwm_led1)
    #else
    #define PWM_FLAGS   0
    #if DT_NODE_HAS_STATUS(PWM_LED1_NODE, okay)
    #define PWM_CTLR1    DT_PWMS_CTLR(PWM_LED1_NODE)
    #define PWM_CHANNEL1 DT_PWMS_CHANNEL(PWM_LED1_NODE)
    #define PWM_FLAGS1   DT_PWMS_FLAGS(PWM_LED1_NODE)
    #else
    #error "Unsupported board: pwm-led1 devicetree alias is not defined"
    #define PWM_CTLR1    DT_INVALID_NODE
    #define PWM_CHANNEL1 0
    #define PWM_FLAGS1   0
    void io_led_initialise( void )
        /* Initialise PWM ports attached to the LEDs */
    //  io_blueled_dev = device_get_binding( DT_PWMS_CTLR(PWM_LED0_NODE) );
        io_blueled_dev = DEVICE_DT_GET( DT_PWMS_CTLR(PWM_LED0_NODE) );
        if ( io_blueled_dev == NULL )
            LOG_ERR( "Green not bound" );
    //  io_redled_dev = device_get_binding( DT_PWMS_CTLR(PWM_LED1_NODE) );
        io_redled_dev = DEVICE_DT_GET( PWM_CTLR1 );
        if ( io_redled_dev == NULL )
            LOG_ERR( "Red not bound" );
        int ret;
            if ( ret == 0)
                result = RESULT_OK;
        return (result);
            return;
            pwm_pin_set_usec( io_blueled_dev,                       /* Pointer to the Green LED dev struct */
    //                        DT_PWMS_CHANNEL(DT_ALIAS(blueled)),   /* PWM pin/channel */
                              PWM_CHANNEL,                          /* PWM pin/channel */
    //                        DT_PWMS_FLAGS(DT_ALIAS(blueled))  );  /* PWM Flags for pin config (polarity)*/
                              PWM_FLAGS  );                         /* PWM Flags for pin config (polarity)*/
            pwm_pin_set_usec( io_redled_dev,                        /* Pointer to the Red LED dev struct */
    //                        DT_PWMS_CHANNEL(DT_ALIAS(redled)),    /* PWM pin/channel */
                              PWM_CHANNEL1,                         /* PWM pin/channel */
    //                        DT_PWMS_FLAGS(DT_ALIAS(redled))   );  /* PWM Flags for pin config (polarity)*/
                              PWM_FLAGS1  );                        /* PWM Flags for pin config (polarity)*/
            return;
    //      pwm_pin_set_usec(pwm_dev, DT_PWMS_CHANNEL(DT_ALIAS(blueled)), PERIOD_USEC,0,0);
            pwm_pin_set_usec(io_blueled_dev, PWM_CHANNEL, PERIOD_USEC,0,0);
    //      pwm_pin_set_usec(pwm_dev, DT_PWMS_CHANNEL(DT_ALIAS(redled)), PERIOD_USEC,0,0);
            pwm_pin_set_usec(io_redled_dev, PWM_CHANNEL1, PERIOD_USEC,0,0);
    #ifdef FADING_TEST
            counter = 0;
            counter++;
        [snip]
    #if ( LED_TEST )
    #if ( FADING_TEST )
    void main( void )
        [snip]
        io_update();
    The build logs showing errors are below.
    Building ‘C:/Zypher/v1.7.0/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘C:/Zypher/v1.7.0/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/misc/generated/struct_tags.json’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/otype-to-size.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/zephyr_generated_headers’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_app’ from solution ‘build’ in configuration ‘Common’
    Building ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’
    8> Compiling ‘io.c’
    8> C:\Zypher\v1.7.0\toolchain\opt/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.6.99-ncs1 -DKERNEL -DNRF52833_XXAA -DNRF52_SERIES -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/Zypher/v1.7.0/zephyr/include -Izephyr/include/generated -IC:/Zypher/v1.7.0/zephyr/soc/arm/nordic_nrf/nrf52 -IC:/Zypher/v1.7.0/zephyr/subsys/bluetooth -IC:/Zypher/v1.7.0/zephyr/subsys/bluetooth/controller/ll_sw/nordic -IC:/Zypher/v1.7.0/nrf/include -IC:/Zypher/v1.7.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/Zypher/v1.7.0/modules/hal/nordic/nrfx -IC:/Zypher/v1.7.0/modules/hal/nordic/nrfx/drivers/include -IC:/Zypher/v1.7.0/modules/hal/nordic/nrfx/mdk -IC:/Zypher/v1.7.0/zephyr/modules/hal_nordic/nrfx/. -IC:/Zypher/v1.7.0/modules/debug/segger/SEGGER -IC:/Zypher/v1.7.0/modules/debug/segger/Config -IC:/Zypher/v1.7.0/zephyr/modules/segger/. -isystem C:/Zypher/v1.7.0/zephyr/lib/libc/minimal/include -isystem c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -g -Og -imacros C:/Sandbox/HomeBeacon_dev_sb/build_nrf52833dk_nrf52833_console_v157_dbg/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -imacros C:/Zypher/v1.7.0/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/Sandbox/HomeBeacon_dev_sb=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/Zypher/v1.7.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/Zypher/v1.7.0=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MF C:/Sandbox/HomeBeacon_dev_sb/build_nrf52833dk_nrf52833_console_v157_dbg/CMakeFiles\app.dir\src\io.c.obj.d -fno-diagnostics-show-caret -o CMakeFiles/app.dir/src/io.c.obj -c ../src/io.c
    8> ../src/io.c:344:2: error: #error "Unsupported board: pwm-led1 devicetree alias is not defined"
    8> In file included from C:/Zypher/v1.7.0/zephyr/include/toolchain/gcc.h:66,
    8>                  from C:/Zypher/v1.7.0/zephyr/include/toolchain.h:43,
    8>                  from C:/Zypher/v1.7.0/zephyr/lib/libc/minimal/include/stdio.h:12,
    8>                  from ../src/io.c:30:
    8> ../src/io.c: In function 'io_led_initialise':
    8> C:/Zypher/v1.7.0/zephyr/include/device.h:80:39: error: '__device_dts_ord___ORD' undeclared (first use in this function); did you mean '__device_dts_ord_69'?
    8> C:/Zypher/v1.7.0/zephyr/include/device.h:232:37: note: in expansion of macro 'DEVICE_NAME_GET'
    8> C:/Zypher/v1.7.0/zephyr/include/device.h:246:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
    8> ../src/io.c:362:21: note: in expansion of macro 'DEVICE_DT_GET'
    8> C:/Zypher/v1.7.0/zephyr/include/device.h:80:39: note: each undeclared identifier is reported only once for each function it appears in
    Build failed
    I can see how this is done with one LED as illustrated in the two examples provided _fade-led-sample and blinky_pwm but I try to extend the same approach to two LEDs I am running into the problems described above. I am probably misunderstanding how the PWM peripheral works as opposed to GPIO when controlling more than one LED.
    Kind regards
    Mohamed
    Sorry for the late reply. We are currently understaffed due to the summer vacation period, so delayed replies must be expected. I am sorry about any inconvenience this might cause.
    You can use this overlay for nRF52833DK to work with LED PWM to see how to control four LEDs.
    	pwmleds {
    		compatible = "pwm-leds";
    		pwm_led0: pwm_led_0 {
    			pwms = < &pwm0 13 >;
    			status = "okay";
    		pwm_led1: pwm_led_1 {
    			pwms = < &pwm0 14 >;
    			status = "okay";
    		pwm_led2: pwm_led_2 {
    			pwms = < &pwm0 15 >;
    			status = "okay";
    		pwm_led3: pwm_led_3 {
    			pwms = < &pwm0 16 >;
    			status = "okay";
    &pwm0 {
    	status = "okay";
    	ch0-pin = <13>;
    	ch0-inverted;
    	ch1-pin = <14>;
    	ch1-inverted;
    	ch2-pin = <15>;
    	ch2-inverted;
    	ch3-pin = <16>;
    	ch3-inverted;
    &pwm_led0 {
    	status = "okay";
    	pwms = <&pwm0 13>;
    &pwm_led1 {
    	status = "okay";
    	pwms = <&pwm0 14>;
    &pwm_led2 {
    	status = "okay";
    	pwms = <&pwm0 15>;
    &pwm_led3 {
    	status = "okay";
    	pwms = <&pwm0 16>;
    -Amanda H.
