Hello Team,
I am using nrf52840 board which supports ZIGBEE .
Setup Details:
Zigbee_LIGHT_BULB (nRF52840 DK)
Zigbee_LIGHT_SWITCH(nRF52840 DK)
Light Bulb Example
I am currently implementing the Temperature Measurement Cluster in the Light Bulb example. I want to send the temperature measurement value to the Light Switch example. On the bulb side, I am using the report attribute to send the temperature value but switch is not receiving the temperature report why?
LIGHT_BULB EXAMPLE CODE (TEMPERATURE MEASUREMENT)
/** @file
* @brief TODO: Write actual implementation details here
#include <zephyr/types.h>
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <soc.h>
#include <zephyr/drivers/pwm.h>
#include <dk_buttons_and_leds.h>
#include <zephyr/settings/settings.h>
#include <zboss_api.h>
#include <zboss_api_addons.h>
#include <zb_mem_config_med.h>
#include <zigbee/zigbee_app_utils.h>
#include <zigbee/zigbee_error_handler.h>
#include <zigbee/zigbee_zcl_scenes.h>
#include <zb_nrf_platform.h>
#include "zb_dimmable_light.h"
#include "zb_zcl_time.h"
#include "zb_zcl_temp_measurement.h"
#include "zcl/zb_zcl_temp_measurement_addons.h"
#include <time.h>
#include <stdlib.h>
#include "stdint.h"
#include <limits.h>
#include "zcl/zb_zcl_reporting.h"
#include "zboss_api_core.h"
// Define RAND_MAX if not already defined
#ifndef RAND_MAX
#define RAND_MAX INT_MAX
#define RUN_STATUS_LED DK_LED1
#define RUN_LED_BLINK_INTERVAL 1000
/* Device endpoint, used to receive light controlling commands. */
#define LEVEL_CONTROL_ENDPOINT 11
/* Version of the application software (1 byte). */
#define BULB_INIT_BASIC_APP_VERSION 01
/* Version of the implementation of the Zigbee stack (1 byte). */
#define BULB_INIT_BASIC_STACK_VERSION 10
/* Version of the hardware of the device (1 byte). */
#define BULB_INIT_BASIC_HW_VERSION 11
/* Manufacturer name (32 bytes). */
#define BULB_INIT_BASIC_MANUF_NAME "Nordic"
/* Model number assigned by manufacturer (32-bytes long string). */
#define BULB_INIT_BASIC_MODEL_ID "light_v0.1"
/* First 8 bytes specify the date of manufacturer of the device
* in ISO 8601 format (YYYYMMDD). The rest (8 bytes) are manufacturer specific.
#define BULB_INIT_BASIC_DATE_CODE "20230404"
/* Type of power sources available for the device.
* For possible values see section 3.2.2.2.8 of ZCL specification.
#define BULB_INIT_BASIC_POWER_SOURCE ZB_ZCL_BASIC_POWER_SOURCE_DC_SOURCE
/* Describes the physical location of the device (16 bytes).
* May be modified during commissioning process.
#define BULB_INIT_BASIC_LOCATION_DESC "Office desk"
/* Describes the type of physical environment.
* For possible values see section 3.2.2.2.10 of ZCL specification.
#define BULB_INIT_BASIC_PH_ENV ZB_ZCL_BASIC_ENV_UNSPECIFIED
/* LED indicating that light switch successfully joind Zigbee network. */
#define ZIGBEE_NETWORK_STATE_LED DK_LED3
/* LED immitaing light bulb - define for informational
* purposes only.
#define BULB_LED DK_LED4
/* Button used to enter the Bulb into the Identify mode. */
#define IDENTIFY_MODE_BUTTON DK_BTN4_MSK
/* Use onboard led4 to act as a light bulb.
* The app.overlay file has this at node label "pwm_led3" in /pwmleds.
#define PWM_DK_LED4_NODE DT_NODELABEL(pwm_led3)
/* Led PWM period, calculated for 100 Hz signal - in microseconds. */
#define LED_PWM_PERIOD_US (USEC_PER_SEC / 100U)
#ifndef ZB_ROUTER_ROLE
#error Define ZB_ROUTER_ROLE to compile router source code.
/* Button to start Factory Reset */
#define FACTORY_RESET_BUTTON IDENTIFY_MODE_BUTTON
#if DT_NODE_HAS_STATUS(PWM_DK_LED4_NODE, okay)
static const struct pwm_dt_spec led_pwm = PWM_DT_SPEC_GET(PWM_DK_LED4_NODE);
#else
#error "Choose supported PWM driver"
/*Register the logging module with a specific log level */
LOG_MODULE_REGISTER(app, LOG_LEVEL_INF);
/* Attribute Values for temperature measurement */
static int16_t measuredValue = 0; // Default to 0 (0.00°C)
static const int16_t minMeasuredValue = -27315; // -273.15°C in MeasuredValue format
static const int16_t maxMeasuredValue = 32767; // 327.67°C in MeasuredValue format
static uint16_t tolerance = 0; // Default tolerance
/* Seed for the linear congruential generator (LCG) */
static uint32_t lcg_seed = 1;
/* Function to seed the random number generator */
void srand(unsigned int seed) {
lcg_seed = seed;
/* Function to generate a random number using LCG algorithm */
int rand(void) {
lcg_seed = (lcg_seed * 1664525 + 1013904223) % 0xFFFFFFFF;
return (int)(lcg_seed & RAND_MAX);
static struct k_timer temperature_timer;
static bool bulb_on = false;
/* Main application customizable context.
* Stores all settings and static values.
typedef struct {
zb_zcl_basic_attrs_ext_t basic_attr;
zb_zcl_identify_attrs_t identify_attr;
zb_zcl_scenes_attrs_t scenes_attr;
zb_zcl_groups_attrs_t groups_attr;
zb_zcl_on_off_attrs_t on_off_attr;
zb_zcl_level_control_attrs_t level_control_attr;
zb_zcl_time_attrs_t time_attr;
zb_zcl_temp_measurement_attrs_t temp_measurement_attr;
} bulb_device_ctx_t;
/* Zigbee device application context storage. */
static bulb_device_ctx_t dev_ctx;
/* Declare attribute lists for different Zigbee clusters */
/* Identify cluster attributes additions data */
ZB_ZCL_DECLARE_IDENTIFY_ATTRIB_LIST(
identify_attr_list,
&dev_ctx.identify_attr.identify_time);
/* Groups cluster attributes additions data */
ZB_ZCL_DECLARE_GROUPS_ATTRIB_LIST(
groups_attr_list,
&dev_ctx.groups_attr.name_support);
/* Scenes cluster attributes additions data */
ZB_ZCL_DECLARE_SCENES_ATTRIB_LIST(
scenes_attr_list,
&dev_ctx.scenes_attr.scene_count,
&dev_ctx.scenes_attr.current_scene,
&dev_ctx.scenes_attr.current_group,
&dev_ctx.scenes_attr.scene_valid,
&dev_ctx.scenes_attr.name_support);
/* Basic cluster attributes additions data */
ZB_ZCL_DECLARE_BASIC_ATTRIB_LIST_EXT(
basic_attr_list,
&dev_ctx.basic_attr.zcl_version,
&dev_ctx.basic_attr.app_version,
&dev_ctx.basic_attr.stack_version,
&dev_ctx.basic_attr.hw_version,
dev_ctx.basic_attr.mf_name,
dev_ctx.basic_attr.model_id,
dev_ctx.basic_attr.date_code,
&dev_ctx.basic_attr.power_source,
dev_ctx.basic_attr.location_id,
&dev_ctx.basic_attr.ph_env,
dev_ctx.basic_attr.sw_ver);
/* On/Off cluster attributes additions data */
ZB_ZCL_DECLARE_ON_OFF_ATTRIB_LIST(
on_off_attr_list,
&dev_ctx.on_off_attr.on_off);
/* Level Control cluster attributes additions data */
ZB_ZCL_DECLARE_LEVEL_CONTROL_ATTRIB_LIST(
level_control_attr_list,
&dev_ctx.level_control_attr.current_level,
&dev_ctx.level_control_attr.remaining_time);
/* Time cluster attributes additions data */
ZB_ZCL_DECLARE_TIME_ATTRIB_LIST(
time_attr_list,
&dev_ctx.time_attr.dst_end,
&dev_ctx.time_attr.dst_shift,
&dev_ctx.time_attr.dst_start,
&dev_ctx.time_attr.last_set_time,
&dev_ctx.time_attr.local_time,
&dev_ctx.time_attr.standard_time,
&dev_ctx.time_attr.time,
&dev_ctx.time_attr.time_status,
&dev_ctx.time_attr.time_zone,
&dev_ctx.time_attr.valid_until_time);
/* Temperature Measurement cluster attributes additions data */
ZB_ZCL_DECLARE_TEMP_MEASUREMENT_ATTRIB_LIST(
temp_measurement_attr_list,
&dev_ctx.temp_measurement_attr.max_measure_value,
&dev_ctx.temp_measurement_attr.measure_value,
&dev_ctx.temp_measurement_attr.min_measure_value,
&dev_ctx.temp_measurement_attr.tolerance);
/* Declare Zigbee endpoint and cluster list for on/off light*/
ZB_DECLARE_ON_OFF_LIGHT_CLUSTER_LIST(
on_off_light_clusters,
basic_attr_list,
identify_attr_list,
groups_attr_list,
scenes_attr_list,
on_off_attr_list,
time_attr_list,
temp_measurement_attr_list);
ZB_DECLARE_LEVEL_CONTROL_EP(
level_control_ep,
LEVEL_CONTROL_ENDPOINT,
on_off_light_clusters);
ZBOSS_DECLARE_DEVICE_CTX_1_EP(
on_off_light_ctx,
level_control_ep);
/**@brief Starts identifying the device.
* @param bufid Unused parameter, required by ZBOSS scheduler API.
static void start_identifying(zb_bufid_t bufid)
ZVUNUSED(bufid);
if (ZB_JOINED()) {
/* Check if endpoint is in identifying mode,
* if not, put desired endpoint in identifying mode.
if (dev_ctx.identify_attr.identify_time ==
ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE) {
zb_ret_t zb_err_code = zb_bdb_finding_binding_target(
LEVEL_CONTROL_ENDPOINT);
if (zb_err_code == RET_OK) {
LOG_INF("Enter identify mode");
} else if (zb_err_code == RET_INVALID_STATE) {
LOG_WRN("RET_INVALID_STATE - Cannot enter identify mode");
} else {
ZB_ERROR_CHECK(zb_err_code);
} else {
LOG_INF("Cancel identify mode");
zb_bdb_finding_binding_target_cancel();
} else {
LOG_WRN("Device not in a network - cannot enter identify mode");
/**@brief Callback for button events.
* @param[in] button_state Bitmask containing the state of the buttons.
* @param[in] has_changed Bitmask containing buttons that have changed their state.
static void button_changed(uint32_t button_state, uint32_t has_changed)
if (IDENTIFY_MODE_BUTTON & has_changed) {
if (IDENTIFY_MODE_BUTTON & button_state) {
/* Button changed its state to pressed */
reset_temperature_data();
} else {
/* Button changed its state to released */
if (was_factory_reset_done()) {
/* The long press was for Factory Reset */
LOG_DBG("After Factory Reset - ignore button release");
} else {
/* Button released before Factory Reset */
/* Start identification mode */
ZB_SCHEDULE_APP_CALLBACK(start_identifying, 0);
check_factory_reset_button(button_state, has_changed);
// Function to reset temperature data
void reset_temperature_data() {
// Reset the seed for the random number generator
srand(time(NULL));
// ... (Clear any other temperature-related data if needed)
LOG_INF("Temperature data reset!");
/**@brief Function for initializing additional PWM leds. */
static void pwm_led_init(void)
if (!device_is_ready(led_pwm.dev)) {
LOG_ERR("Error: PWM device %s is not ready",
led_pwm.dev->name);
/**@brief Function for initializing LEDs and Buttons. */
static void configure_gpio(void)
int err;
err = dk_buttons_init(button_changed);
if (err) {
LOG_ERR("Cannot init buttons (err: %d)", err);
err = dk_leds_init();
if (err) {
LOG_ERR("Cannot init LEDs (err: %d)", err);
pwm_led_init();
/**@brief Sets brightness of bulb luminous executive element
* @param[in] brightness_level Brightness level, allowed values 0 ... 255,
* 0 - turn off, 255 - full brightness.
static void light_bulb_set_brightness(zb_uint8_t brightness_level)
uint32_t pulse = brightness_level * LED_PWM_PERIOD_US / 255U;
if (pwm_set_dt(&led_pwm, PWM_USEC(LED_PWM_PERIOD_US), PWM_USEC(pulse))) {
LOG_ERR("Pwm led 4 set fails:\n");
return;
LOG_INF("Level value is %d", brightness_level);
/**@brief Function for setting the light bulb brightness.
* @param[in] new_level Light bulb brightness value.
static void level_control_set_value(zb_uint16_t new_level)
LOG_INF("Set level value: %i", new_level);
ZB_ZCL_SET_ATTRIBUTE(
ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL,
ZB_ZCL_CLUSTER_SERVER_ROLE,
ZB_ZCL_ATTR_LEVEL_CONTROL_CURRENT_LEVEL_ID,
(zb_uint8_t *)&new_level,
ZB_FALSE);
light_bulb_set_brightness(new_level);
void temperature_timer_handler(struct k_timer *dummy)
if (!bulb_on) {
return; // Stop updating temperature if bulb is off
int16_t new_temperature = 2200 + (rand() % 50);/* Read or simulate new temperature */
update_temperature_measurement(new_temperature);
static const char* get_formatted_temperature(void) {
static char temp_str[16];
int16_t temp_value = dev_ctx.temp_measurement_attr.measure_value;
snprintf(temp_str, sizeof(temp_str), "%d.%02d°C", temp_value / 100, temp_value % 100);
return temp_str;
/**@brief Function for turning ON/OFF the light bulb.
* @param[in] on Boolean light bulb state.
static void on_off_set_value(zb_bool_t on)
LOG_INF("Set ON/OFF value: %i", on);
const char* temp_str = get_formatted_temperature();
ZB_ZCL_CLUSTER_ID_ON_OFF,
ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID,
(zb_uint8_t *)&on,
ZB_FALSE);
// if (on) {
// LOG_INF("bulb is ON. \t Current temperature : %s ", temp_str);
// }else {
// LOG_INF("Bulb is OFF. \t Current Temperature : %s ", temp_str);
if (on) {
bulb_on = true;
/* Start periodic temperature measurement updates */
//k_timer_init(&temperature_timer, temperature_timer_handler, NULL);
//k_timer_start(&temperature_timer, K_SECONDS(5), K_SECONDS(5));
dk_set_led_on(DK_LED4);
LOG_INF("Light ON - current temperature measurement: %s", temp_str);
} else {
bulb_on = false;
//k_timer_stop(&temperature_timer);
dk_set_led_off(DK_LED4);
LOG_INF("Light OFF - current temperature measurement: %s", temp_str);
/**@brief Function to handle identify notification events on the first endpoint.
static void identify_cb(zb_bufid_t bufid)
zb_ret_t zb_err_code;
if (bufid) {
/* Schedule a self-scheduling function that will toggle the LED. */
//ZB_SCHEDULE_APP_CALLBACK(toggle_identify_led, bufid);
} else {
/* Cancel the toggling function alarm and restore current Zigbee LED state. */
//zb_err_code = ZB_SCHEDULE_APP_ALARM_CANCEL(toggle_identify_led, ZB_ALARM_ANY_PARAM);
ZVUNUSED(zb_err_code);
/**@brief Function for initializing all clusters attributes.
static void bulb_clusters_attr_init(void)
/* Basic cluster attributes data */
dev_ctx.basic_attr.zcl_version = ZB_ZCL_VERSION;
dev_ctx.basic_attr.app_version = BULB_INIT_BASIC_APP_VERSION;
dev_ctx.basic_attr.stack_version = BULB_INIT_BASIC_STACK_VERSION;
dev_ctx.basic_attr.hw_version = BULB_INIT_BASIC_HW_VERSION;
ZB_ZCL_SET_STRING_VAL(
BULB_INIT_BASIC_MANUF_NAME,
ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_MANUF_NAME));
BULB_INIT_BASIC_MODEL_ID,
ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_MODEL_ID));
BULB_INIT_BASIC_DATE_CODE,
ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_DATE_CODE));
dev_ctx.basic_attr.power_source = BULB_INIT_BASIC_POWER_SOURCE;
BULB_INIT_BASIC_LOCATION_DESC,
ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_LOCATION_DESC));
dev_ctx.basic_attr.ph_env = BULB_INIT_BASIC_PH_ENV;
/* Identify cluster attributes data. */
ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE;
/* Groups cluster attributes data. */
dev_ctx.groups_attr.name_support = ZB_ZCL_ATTR_GROUPS_NAME_SUPPORT_ID;
/* Scenes cluster attributes data. */
dev_ctx.scenes_attr.current_group = ZB_ZCL_ATTR_SCENES_CURRENT_GROUP_ID;
dev_ctx.scenes_attr.current_scene = ZB_ZCL_ATTR_SCENES_CURRENT_SCENE_ID;
dev_ctx.scenes_attr.name_support = ZB_ZCL_ATTR_SCENES_NAME_SUPPORT_ID;
dev_ctx.scenes_attr.scene_count = ZB_ZCL_ATTR_SCENES_SCENE_COUNT_ID;
dev_ctx.scenes_attr.scene_valid = ZB_ZCL_ATTR_SCENES_SCENE_VALID_ID;
/* On/Off cluster attributes data. */
dev_ctx.on_off_attr.on_off = (zb_bool_t)ZB_ZCL_ON_OFF_IS_ON;
/* Level Control Cluster attributes data. */
dev_ctx.level_control_attr.current_level =
ZB_ZCL_LEVEL_CONTROL_LEVEL_MAX_VALUE;
dev_ctx.level_control_attr.remaining_time =
ZB_ZCL_LEVEL_CONTROL_REMAINING_TIME_DEFAULT_VALUE;
/* Temperature Measurement cluster attributes data. */
dev_ctx.temp_measurement_attr.max_measure_value = ZB_ZCL_ATTR_TEMP_MEASUREMENT_MAX_VALUE_ID;
dev_ctx.temp_measurement_attr.measure_value = ZB_ZCL_ATTR_TEMP_MEASUREMENT_VALUE_ID;
dev_ctx.temp_measurement_attr.min_measure_value = ZB_ZCL_ATTR_TEMP_MEASUREMENT_MIN_VALUE_ID;
dev_ctx.temp_measurement_attr.tolerance = ZB_ZCL_ATTR_TEMP_MEASUREMENT_TOLERANCE_ID;
(zb_uint8_t *)&dev_ctx.on_off_attr.on_off,
ZB_FALSE);
(zb_uint8_t *)&dev_ctx.level_control_attr.current_level,
ZB_FALSE);
ZB_ZCL_CLUSTER_ID_TEMP_MEASUREMENT,
ZB_ZCL_ATTR_TEMP_MEASUREMENT_VALUE_ID,
(zb_uint8_t *)&dev_ctx.temp_measurement_attr.measure_value,
ZB_FALSE);
ZB_ZCL_ATTR_TEMP_MEASUREMENT_MIN_VALUE_ID,
(zb_uint8_t *)&dev_ctx.temp_measurement_attr.min_measure_value,
ZB_FALSE);
ZB_ZCL_ATTR_TEMP_MEASUREMENT_MAX_VALUE_ID,
(zb_uint8_t *)&dev_ctx.temp_measurement_attr.max_measure_value,
ZB_FALSE);
ZB_ZCL_ATTR_TEMP_MEASUREMENT_TOLERANCE_ID,
(zb_uint8_t *)&dev_ctx.temp_measurement_attr.tolerance,
ZB_FALSE);
// // Function to initialize the random number generator
void initialize_random() {
srand(gmtime(NULL)); // Seed the random number generator with the current time
// Function to read temperature from the sensor (simulated here)
int16_t read_temperature_sensor(void) {
static int counter = 0;
counter++;
return 2200 + (rand() % 50); // Simulate temperature change
// Function to configure temperature reporting
void configure_temperature_reporting() {
zb_zcl_reporting_info_t temp_rep_info;
memset(&temp_rep_info, 0, sizeof(temp_rep_info));
// Set up reporting configuration (adjust values as needed)
temp_rep_info.direction = ZB_ZCL_CONFIGURE_REPORTING_SEND_REPORT;
temp_rep_info.ep = LEVEL_CONTROL_ENDPOINT;
temp_rep_info.cluster_id = ZB_ZCL_CLUSTER_ID_TEMP_MEASUREMENT;
temp_rep_info.cluster_role = ZB_ZCL_CLUSTER_SERVER_ROLE;
temp_rep_info.attr_id = ZB_ZCL_ATTR_TEMP_MEASUREMENT_VALUE_ID;
temp_rep_info.dst.profile_id = ZB_AF_HA_PROFILE_ID;
temp_rep_info.u.send_info.min_interval = 30; // 30 seconds
temp_rep_info.u.send_info.max_interval = 300; // 5 minutes
temp_rep_info.u.send_info.delta.s16 = 0x0032; // 0.5 degrees
zb_ret_t ret = zb_zcl_put_reporting_info(&temp_rep_info, ZB_TRUE);
if (ret == RET_OK) {
LOG_INF("Temperature reporting configured successfully.\n");
} else {
LOG_ERR("Failed to configure temperature reporting.\n");
// Function to start attribute reporting
void start_reporting() {
zb_ret_t ret = zb_zcl_start_attr_reporting(LEVEL_CONTROL_ENDPOINT,
ZB_ZCL_ATTR_TEMP_MEASUREMENT_VALUE_ID);
LOG_INF("Temperature reporting started successfully.\n");
} else {
LOG_ERR("Failed to start temperature reporting.\n");
// Function to update the temperature measurement attribute and trigger a report
void update_temperature_measurement() {
int16_t new_temperature = read_temperature_sensor();
// Update the attribute and trigger a report
(zb_uint8_t *)&new_temperature,
ZB_FALSE);
LOG_INF("Reported temperature: %d.%02d°C", new_temperature / 100, new_temperature % 100);
/**@brief Callback function for handling ZCL commands.
* @param[in] bufid Reference to Zigbee stack buffer
* used to pass received data.
static void zcl_device_cb(zb_bufid_t bufid)
zb_uint8_t cluster_id;
zb_uint8_t attr_id;
zb_zcl_device_callback_param_t *device_cb_param =
ZB_BUF_GET_PARAM(bufid, zb_zcl_device_callback_param_t);
LOG_INF("%s id %hd", __func__, device_cb_param->device_cb_id);
/* Set default response value. */
device_cb_param->status = RET_OK;
switch (device_cb_param->device_cb_id) {
case ZB_ZCL_LEVEL_CONTROL_SET_VALUE_CB_ID:
LOG_INF("Level control setting to %d",
device_cb_param->cb_param.level_control_set_value_param
.new_value);
.new_value);
case ZB_ZCL_SET_ATTR_VALUE_CB_ID:
cluster_id = device_cb_param->cb_param.
set_attr_value_param.cluster_id;
attr_id = device_cb_param->cb_param.
set_attr_value_param.attr_id;
if (cluster_id == ZB_ZCL_CLUSTER_ID_ON_OFF) {
uint8_t value =
device_cb_param->cb_param.set_attr_value_param
.values.data8;
LOG_INF("on/off attribute setting to %hd", value);
if (attr_id == ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID) {
on_off_set_value((zb_bool_t)value);
// int16_t new_temperature = 2200 + (rand() % 50);/* Read or simulate new temperature */;
// update_temperature_measurement(new_temperature);
if(value == 1) {
} else {
} else {
/* Other clusters can be processed here */
LOG_INF("Unhandled cluster attribute id: %d",
cluster_id);
device_cb_param->status = RET_NOT_IMPLEMENTED;
if (zcl_scenes_cb(bufid) == ZB_FALSE) {
LOG_INF("%s status: %hd", __func__, device_cb_param->status);
/**@brief Zigbee stack event handler.
* @param[in] bufid Reference to the Zigbee stack buffer
* used to pass signal.
void zboss_signal_handler(zb_bufid_t bufid)
/* Update network status LED. */
zigbee_led_status_update(bufid, ZIGBEE_NETWORK_STATE_LED);
/* No application-specific behavior is required.
* Call default signal handler.
ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid));
/* All callbacks should either reuse or free passed buffers.
* If bufid == 0, the buffer is invalid (not passed).
if (bufid) {
zb_buf_free(bufid);
void main(void)
int blink_status = 0;
int err;
LOG_INF("Starting On Off Cluster Example");
/* Initialize */
configure_gpio();
err = settings_subsys_init();
if (err) {
LOG_ERR("settings initialization failed");
register_factory_reset_button(FACTORY_RESET_BUTTON);
/* Register callback for handling ZCL commands. */
ZB_ZCL_REGISTER_DEVICE_CB(zcl_device_cb);
/* Register on off switch device context (endpoints). */
ZB_AF_REGISTER_DEVICE_CTX(&on_off_light_ctx);
bulb_clusters_attr_init();
LOG_INF("after cluster initialization");
level_control_set_value(dev_ctx.level_control_attr.current_level);
/* Register handler to identify notifications. */
ZB_AF_SET_IDENTIFY_NOTIFICATION_HANDLER(LEVEL_CONTROL_ENDPOINT, identify_cb);
/* Initialize ZCL scene table */
zcl_scenes_init();
/* Settings should be loaded after zcl_scenes_init */
err = settings_load();
if (err) {
LOG_ERR("settings loading failed");
/* Start Zigbee default thread */
zigbee_enable();
LOG_INF("On off cluster example started");
while (1) {
// Update temperature and trigger a report
update_temperature_measurement();
k_sleep(K_SECONDS(5)); // Update every 5 seconds (adjust as needed)
Light Switch Example
In the Light Switch example, how can I receive the temperature value?
Is a Bind Request required? If so, on which side do I need to implement bind_and_configuring_reporting?
Can you please help me with this? I am getting confused. Additionally, can you please let me know whether the implementation of the code on both sides is correct?
In switch side i wrote functions
LIGHT_SWITCH EXAMPLE (TEMPERATURE MEASUREMENT)
* Copyright (c) 2020 Nordic Semiconductor ASA
/** @file
* @brief Dimmer switch for HA profile implementation.
#include <ram_pwrdn.h>
#include "zb_mem_config_custom.h"
#include "zb_dimmer_switch.h"
#include "zb_zcl_commands.h"
#include "zb_zcl_common.h"
//#include "zb_zcl_common.h"
// #include "zcl/zb_zcl_common.h"
#include <stdio.h>
#include "zboss_api_zcl.h"
#include "zboss_api_nwk.h"
#if CONFIG_ZIGBEE_FOTA
#include <zigbee/zigbee_fota.h>
#include <zephyr/sys/reboot.h>
#include <zephyr/dfu/mcuboot.h>
/* LED indicating OTA Client Activity. */
#define OTA_ACTIVITY_LED DK_LED2
#endif /* CONFIG_ZIGBEE_FOTA */
#if CONFIG_BT_NUS
#include "nus_cmd.h"
/* LED which indicates that Central is connected. */
#define NUS_STATUS_LED DK_LED1
/* UART command that will turn on found light bulb(s). */
#define COMMAND_ON "n"
/**< UART command that will turn off found light bulb(s). */
#define COMMAND_OFF "f"
/**< UART command that will turn toggle found light bulb(s). */
#define COMMAND_TOGGLE "t"
/**< UART command that will increase brightness of found light bulb(s). */
#define COMMAND_INCREASE "i"
/**< UART command that will decrease brightness of found light bulb(s). */
#define COMMAND_DECREASE "d"
#endif /* CONFIG_BT_NUS */
/* Source endpoint used to control light bulb. */
#define LIGHT_SWITCH_ENDPOINT 1
/* Delay between the light switch startup and light bulb finding procedure. */
#define MATCH_DESC_REQ_START_DELAY K_SECONDS(2)
/* Timeout for finding procedure. */
#define MATCH_DESC_REQ_TIMEOUT K_SECONDS(5)
/* Find only non-sleepy device. */
#define MATCH_DESC_REQ_ROLE ZB_NWK_BROADCAST_RX_ON_WHEN_IDLE
/* Do not erase NVRAM to save the network parameters after device reboot or
* power-off. NOTE: If this option is set to ZB_TRUE then do full device erase
* for all network devices before running other samples.
#define ERASE_PERSISTENT_CONFIG ZB_FALSE
/* LED used for device identification. */
#define IDENTIFY_LED ZIGBEE_NETWORK_STATE_LED
/* LED indicating that light witch found a light bulb to control. */
#define BULB_FOUND_LED DK_LED4
/* Button ID used to switch on the light bulb. */
#define BUTTON_ON DK_BTN1_MSK
/* Button ID used to switch off the light bulb. */
#define BUTTON_OFF DK_BTN2_MSK
/* Dim step size - increases/decreses current level (range 0x000 - 0xfe). */
#define DIMM_STEP 15
/* Button ID used to enable sleepy behavior. */
#define BUTTON_SLEEPY DK_BTN3_MSK
#define FACTORY_RESET_BUTTON DK_BTN4_MSK
/* Button used to enter the Identify mode. */
/* Transition time for a single step operation in 0.1 sec units.
* 0xFFFF - immediate change.
#define DIMM_TRANSACTION_TIME 2
/* Time after which the button state is checked again to detect button hold,
* the dimm command is sent again.
#define BUTTON_LONG_POLL_TMO K_MSEC(500)
#if !defined ZB_ED_ROLE
#error Define ZB_ED_ROLE to compile light switch (End Device) source code.
// Simulated temperature value
static int16_t temperatureValue = 2350; // 23.50°C
struct bulb_context {
zb_uint8_t endpoint;
zb_uint16_t short_addr;
struct k_timer find_alarm;
struct buttons_context {
uint32_t state;
atomic_t long_poll;
struct k_timer alarm;
struct zb_device_ctx {
zb_zcl_basic_attrs_t basic_attr;
static struct bulb_context bulb_ctx;
static struct buttons_context buttons_ctx;
static struct zb_device_ctx dev_ctx;
static zb_bool_t ready_to_bind = 0;
/* Declare attribute list for Basic cluster (server). */
ZB_ZCL_DECLARE_BASIC_SERVER_ATTRIB_LIST(
basic_server_attr_list,
&dev_ctx.basic_attr.power_source);
/* Declare attribute list for Identify cluster (client). */
ZB_ZCL_DECLARE_IDENTIFY_CLIENT_ATTRIB_LIST(
identify_client_attr_list);
/* Declare attribute list for Identify cluster (server). */
ZB_ZCL_DECLARE_IDENTIFY_SERVER_ATTRIB_LIST(
identify_server_attr_list,
/* Declare attribute list for Scenes cluster (client). */
ZB_ZCL_DECLARE_SCENES_CLIENT_ATTRIB_LIST(
scenes_client_attr_list);
/* Declare attribute list for Groups cluster (client). */
ZB_ZCL_DECLARE_GROUPS_CLIENT_ATTRIB_LIST(
groups_client_attr_list);
/* Declare attribute list for On/Off cluster (client). */
ZB_ZCL_DECLARE_ON_OFF_CLIENT_ATTRIB_LIST(
on_off_client_attr_list);
/* Declare attribute list for Level control cluster (client). */
ZB_ZCL_DECLARE_LEVEL_CONTROL_CLIENT_ATTRIB_LIST(
level_control_client_attr_list);
ZB_ZCL_DECLARE_TEMP_MEASUREMENT_SERVER_ATTRIB_LIST(
temp_measurement_server_attr_list,
ZB_ZCL_DECLARE_TEMP_MEASUREMENT_CLIENT_ATTRIB_LIST(
temp_measurement_client_attr_list);
/* Declare cluster list for Dimmer Switch device. */
ZB_DECLARE_DIMMER_SWITCH_CLUSTER_LIST(
dimmer_switch_clusters,
identify_client_attr_list,
scenes_client_attr_list,
groups_client_attr_list,
on_off_client_attr_list,
level_control_client_attr_list,
/* Declare endpoint for Dimmer Switch device. */
ZB_DECLARE_DIMMER_SWITCH_EP(
dimmer_switch_ep,
LIGHT_SWITCH_ENDPOINT,
dimmer_switch_clusters);
/* Declare application's device context (list of registered endpoints)
* for Dimmer Switch device.
#ifndef CONFIG_ZIGBEE_FOTA
ZBOSS_DECLARE_DEVICE_CTX_1_EP(dimmer_switch_ctx, dimmer_switch_ep);
#else
#if LIGHT_SWITCH_ENDPOINT == CONFIG_ZIGBEE_FOTA_ENDPOINT
#error "Light switch and Zigbee OTA endpoints should be different."
extern zb_af_endpoint_desc_t zigbee_fota_client_ep;
ZBOSS_DECLARE_DEVICE_CTX_2_EP(dimmer_switch_ctx,
zigbee_fota_client_ep,
dimmer_switch_ep);
/* Forward declarations. */
static void light_switch_button_handler(struct k_timer *timer);
static void find_light_bulb_alarm(struct k_timer *timer);
static void find_light_bulb(zb_bufid_t bufid);
static void light_switch_send_on_off(zb_bufid_t bufid, zb_uint16_t on_off);
ZVUNUSED(bufid);
if (ZB_JOINED()) {
zb_ret_t zb_err_code = zb_bdb_finding_binding_target(LIGHT_SWITCH_ENDPOINT);
} else {
} else {
} else {
* @param[in] button_state Bitmask containing buttons state.
* @param[in] has_changed Bitmask containing buttons that has
* changed their state.
static void button_handler(uint32_t button_state, uint32_t has_changed)
zb_uint16_t cmd_id;
/* Inform default signal handler about user input at the device. */
user_input_indicate();
if (bulb_ctx.short_addr == 0xFFFF) {
LOG_DBG("No bulb found yet.");
return;
switch (has_changed) {
case BUTTON_ON:
LOG_DBG("ON - button changed");
cmd_id = ZB_ZCL_CMD_ON_OFF_ON_ID;
case BUTTON_OFF:
LOG_DBG("OFF - button changed");
cmd_id = ZB_ZCL_CMD_ON_OFF_OFF_ID;
case IDENTIFY_MODE_BUTTON:
} else {
} else {
return;
LOG_DBG("Unhandled button");
return;
switch (button_state) {
case BUTTON_ON:
case BUTTON_OFF:
LOG_DBG("Button pressed");
buttons_ctx.state = button_state;
/* Alarm can be scheduled only once. Next alarm only resets
* counting.
k_timer_start(&buttons_ctx.alarm, BUTTON_LONG_POLL_TMO,
K_NO_WAIT);
case 0:
LOG_DBG("Button released");
k_timer_stop(&buttons_ctx.alarm);
if (atomic_set(&buttons_ctx.long_poll, ZB_FALSE) == ZB_FALSE) {
/* Allocate output buffer and send on/off command. */
zb_err_code = zb_buf_get_out_delayed_ext(
light_switch_send_on_off, cmd_id, 0);
int err;
err = dk_buttons_init(button_handler);
if (err) {
if (err) {
static void alarm_timers_init(void)
k_timer_init(&buttons_ctx.alarm, light_switch_button_handler, NULL);
k_timer_init(&bulb_ctx.find_alarm, find_light_bulb_alarm, NULL);
/**@brief Function for initializing all clusters attributes. */
static void app_clusters_attr_init(void)
/* Basic cluster attributes data. */
dev_ctx.basic_attr.power_source = ZB_ZCL_BASIC_POWER_SOURCE_UNKNOWN;
dev_ctx.identify_attr.identify_time = ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE;
* @brief Configures attribute reporting for temperature measurement.
* @param[in] bufid Reference to Zigbee stack buffer used for communication.
void configure_attr_reporting(zb_bufid_t bufid)
zb_uint8_t * cmd_ptr;
// Initialize configure reporting request
ZB_ZCL_GENERAL_INIT_CONFIGURE_REPORTING_CLI_REQ(bufid,
cmd_ptr,
ZB_ZCL_ENABLE_DEFAULT_RESPONSE);
// Add request to configure reporting for temperature attribute
ZB_ZCL_GENERAL_ADD_RECV_REPORT_CONFIGURE_REPORTING_REQ(cmd_ptr,
0);
// Send configure reporting request to the specified endpoint
ZB_ZCL_GENERAL_SEND_CONFIGURE_REPORTING_REQ(bufid,
cmd_ptr,
bulb_ctx.short_addr,
ZB_APS_ADDR_MODE_16_ENDP_PRESENT,
bulb_ctx.endpoint,
ZB_AF_HA_PROFILE_ID,
NULL);
LOG_INF("Attribute reporting configured");
/**@brief Simulates receiving a temperature report and handles it.
* @param[in] temperature Temperature value to handle.
void handle_temperature_measurement(int16_t temperature)
// Update device context with the new temperature value
dev_ctx.temp_measurement_attr.measure_value = temperature;
// Implement logic to handle temperature value as needed
LOG_INF("Received temperature measurement: %d", temperature);
// Trigger attribute reporting configuration
zb_bufid_t bufid = zb_buf_get_out();
configure_attr_reporting(bufid);
/**@brief Function to toggle the identify LED.
static void toggle_identify_led(zb_bufid_t bufid)
static int blink_status;
dk_set_led(IDENTIFY_LED, (++blink_status) % 2);
ZB_SCHEDULE_APP_ALARM(toggle_identify_led, bufid, ZB_MILLISECONDS_TO_BEACON_INTERVAL(100));
if (bufid) {
} else {
/* Cancel the toggling function alarm and turn off LED. */
/* Update network status/idenitfication LED. */
if (ZB_JOINED()) {
dk_set_led_on(ZIGBEE_NETWORK_STATE_LED);
} else {
dk_set_led_off(ZIGBEE_NETWORK_STATE_LED);
/**@brief Function for sending ON/OFF requests to the light bulb.
* @param[in] bufid Non-zero reference to Zigbee stack buffer that will be
* used to construct on/off request.
* @param[in] cmd_id ZCL command id.
static void light_switch_send_on_off(zb_bufid_t bufid, zb_uint16_t cmd_id)
LOG_INF("Send ON/OFF command: %d", cmd_id);
ZB_ZCL_ON_OFF_SEND_REQ(bufid,
bulb_ctx.endpoint,
ZB_ZCL_DISABLE_DEFAULT_RESPONSE,
cmd_id,
NULL);
/**@brief Function for sending step requests to the light bulb.
* will be used to construct step request.
static void light_switch_send_step(zb_bufid_t bufid, zb_uint16_t cmd_id)
LOG_INF("Send step level command: %d", cmd_id);
ZB_ZCL_LEVEL_CONTROL_SEND_STEP_REQ(bufid,
bulb_ctx.endpoint,
NULL,
cmd_id,
DIMM_STEP,
DIMM_TRANSACTION_TIME);
* @brief Callback function for handling ZDO bind response.
* @param[in] bufid Reference to Zigbee stack buffer containing response.
static void zb_bind_callback(zb_bufid_t bufid)
zb_zdo_bind_resp_t * p_resp = (zb_zdo_bind_resp_t *)zb_buf_begin(bufid);
if (p_resp->status == ZB_ZDP_STATUS_SUCCESS)
LOG_INF("Bind ok");
else {
// Log error if binding modification failed
LOG_INF("Error: Unable to modify binding. Status %d", p_resp->status);
* @brief Initiates a ZDO bind request.
* @param[in] bufid Reference to Zigbee stack buffer for the request.
static void bind_req(zb_bufid_t bufid)
zb_ieee_addr_t src_nwk_addr;
zb_zdo_bind_req_param_t * p_req;
zb_osif_get_ieee_eui64(src_nwk_addr);
// Initialize bind request parameters
p_req = ZB_BUF_GET_PARAM(bufid, zb_zdo_bind_req_param_t);
ZB_MEMCPY(p_req->src_address, ZB_PIBCACHE_NETWORK_ADDRESS(), sizeof(zb_ieee_addr_t));
p_req->src_endp = LIGHT_SWITCH_ENDPOINT;
p_req->cluster_id = ZB_ZCL_CLUSTER_ID_TEMP_MEASUREMENT;
p_req->dst_addr_mode = ZB_BIND_DST_ADDR_MODE_64_BIT_EXTENDED;
ZB_MEMCPY(p_req->dst_address.addr_long, src_nwk_addr, sizeof(zb_ieee_addr_t));
p_req->dst_endp = bulb_ctx.endpoint;
p_req->req_dst_addr = bulb_ctx.short_addr;
// Send the bind request
zb_err_code = zb_zdo_bind_req(bufid, zb_bind_callback);
/**@brief Callback function receiving finding procedure results.
* @param[in] bufid Reference to Zigbee stack buffer used to pass
* received data.
static void find_light_bulb_cb(zb_bufid_t bufid)
/* Get the beginning of the response. */
zb_zdo_match_desc_resp_t *resp =
(zb_zdo_match_desc_resp_t *) zb_buf_begin(bufid);
/* Get the pointer to the parameters buffer, which stores APS layer
* response.
zb_apsde_data_indication_t *ind = ZB_BUF_GET_PARAM(bufid,
zb_apsde_data_indication_t);
zb_uint8_t *match_ep;
if ((resp->status == ZB_ZDP_STATUS_SUCCESS) &&
(resp->match_len > 0) &&
(bulb_ctx.short_addr == 0xFFFF)) {
/* Match EP list follows right after response header. */
match_ep = (zb_uint8_t *)(resp + 1);
/* We are searching for exact cluster, so only 1 EP
* may be found.
bulb_ctx.endpoint = *match_ep;
bulb_ctx.short_addr = ind->src_addr;
LOG_INF("Found bulb addr: %d ep: %d",
bulb_ctx.endpoint);
k_timer_stop(&bulb_ctx.find_alarm);
dk_set_led_on(BULB_FOUND_LED);
} else {
LOG_INF("Bulb not found, try again");
if (bufid) {
zb_buf_free(bufid);
ready_to_bind = 1;
/**@brief Find bulb allarm handler.
* @param[in] timer Address of timer.
ZB_ERROR_CHECK(zb_buf_get_out_delayed(find_light_bulb));
/**@brief Function for sending ON/OFF and Level Control find request.
* @param[in] bufid Reference to Zigbee stack buffer that will be used to
* construct find request.
zb_zdo_match_desc_param_t *req;
zb_uint8_t tsn = ZB_ZDO_INVALID_TSN;
/* Initialize pointers inside buffer and reserve space for
* zb_zdo_match_desc_param_t request.
req = zb_buf_initial_alloc(bufid,
sizeof(zb_zdo_match_desc_param_t) + (1) * sizeof(zb_uint16_t));
req->nwk_addr = MATCH_DESC_REQ_ROLE;
req->addr_of_interest = MATCH_DESC_REQ_ROLE;
req->profile_id = ZB_AF_HA_PROFILE_ID;
/* We are searching for 2 clusters: On/Off and Level Control Server. */
req->num_in_clusters = 2;
req->num_out_clusters = 0;
req->cluster_list[0] = ZB_ZCL_CLUSTER_ID_ON_OFF;
req->cluster_list[1] = ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL;
/* Set 0xFFFF to reset short address in order to parse
* only one response.
bulb_ctx.short_addr = 0xFFFF;
tsn = zb_zdo_match_desc_req(bufid, find_light_bulb_cb);
/* Free buffer if failed to send a request. */
if (tsn == ZB_ZDO_INVALID_TSN) {
zb_buf_free(bufid);
LOG_ERR("Failed to send Match Descriptor request");
/**@brief Callback for detecting button press duration.
zb_uint16_t cmd_id;
if (dk_get_buttons() & buttons_ctx.state) {
atomic_set(&buttons_ctx.long_poll, ZB_TRUE);
if (buttons_ctx.state == BUTTON_ON) {
cmd_id = ZB_ZCL_LEVEL_CONTROL_STEP_MODE_UP;
} else {
cmd_id = ZB_ZCL_LEVEL_CONTROL_STEP_MODE_DOWN;
/* Allocate output buffer and send step command. */
zb_err_code = zb_buf_get_out_delayed_ext(light_switch_send_step,
cmd_id,
0);
if (!zb_err_code) {
LOG_WRN("Buffer is full");
K_NO_WAIT);
} else {
atomic_set(&buttons_ctx.long_poll, ZB_FALSE);
#ifdef CONFIG_ZIGBEE_FOTA
static void confirm_image(void)
if (!boot_is_img_confirmed()) {
int ret = boot_write_img_confirmed();
if (ret) {
LOG_ERR("Couldn't confirm image: %d", ret);
} else {
LOG_INF("Marked image as OK");
static void ota_evt_handler(const struct zigbee_fota_evt *evt)
switch (evt->id) {
case ZIGBEE_FOTA_EVT_PROGRESS:
dk_set_led(OTA_ACTIVITY_LED, evt->dl.progress % 2);
case ZIGBEE_FOTA_EVT_FINISHED:
LOG_INF("Reboot application.");
/* Power on unused sections of RAM to allow MCUboot to use it. */
if (IS_ENABLED(CONFIG_RAM_POWER_DOWN_LIBRARY)) {
power_up_unused_ram();
sys_reboot(SYS_REBOOT_COLD);
break;// // Simulate receiving a temperature report
// int16_t simulatedTemperature = 2350; // Simulated temperature data
// handleIncomingMessage(&simulatedTemperature);
case ZIGBEE_FOTA_EVT_ERROR:
LOG_ERR("OTA image transfer failed.");
if (device_cb_param->device_cb_id == ZB_ZCL_OTA_UPGRADE_VALUE_CB_ID) {
zigbee_fota_zcl_cb(bufid);
} else {
zb_zdo_app_signal_hdr_t *sig_hndler = NULL;
zb_zdo_app_signal_type_t sig = zb_get_app_signal(bufid, &sig_hndler);
zb_ret_t status = ZB_GET_APP_SIGNAL_STATUS(bufid);
/* Pass signal to the OTA client implementation. */
zigbee_fota_signal_handler(bufid);
switch (sig) {
case ZB_BDB_SIGNAL_DEVICE_REBOOT:
/* fall-through */
case ZB_BDB_SIGNAL_STEERING:
/* Call default signal handler. */
if (status == RET_OK) {
/* Check the light device address. */
k_timer_start(&bulb_ctx.find_alarm,
MATCH_DESC_REQ_START_DELAY,
MATCH_DESC_REQ_TIMEOUT);
case ZB_ZDO_SIGNAL_LEAVE:
/* If device leaves the network, reset bulb short_addr. */
zb_zdo_signal_leave_params_t *leave_params =
ZB_ZDO_SIGNAL_GET_PARAMS(sig_hndler, zb_zdo_signal_leave_params_t);
if (leave_params->leave_type == ZB_NWK_LEAVE_TYPE_RESET) {
ZB_ERROR_CHECK(zigbee_default_signal_handler// // Simulate receiving a temperature report
(bufid));
if (bufid) {
zb_buf_free(bufid);
#if CONFIG_BT_NUS
static void turn_on_cmd(struct k_work *item)
ARG_UNUSED(item);
zb_buf_get_out_delayed_ext(light_switch_send_on_off,
ZB_ZCL_CMD_ON_OFF_ON_ID, 0);
static void turn_off_cmd(struct k_work *item)
ARG_UNUSED(item);
ZB_ZCL_CMD_ON_OFF_OFF_ID, 0);
static void toggle_cmd(struct k_work *item)
ARG_UNUSED(item);
ZB_ZCL_CMD_ON_OFF_TOGGLE_ID, 0);void
static void increase_cmd(struct k_work *item)
ARG_UNUSED(item);
ZB_ZCL_LEVEL_CONTROL_STEP_MODE_UP, 0);
static void decrease_cmd(struct k_work *item)
ARG_UNUSED(item);
ZB_ZCL_LEVEL_CONTROL_STEP_MODE_DOWN, 0);
static void on_nus_connect(struct k_work *item)
ARG_UNUSED(item);
dk_set_led_on(NUS_STATUS_LED);
static void on_nus_disconnect(struct k_work *item)
ARG_UNUSED(item);
dk_set_led_off(NUS_STATUS_LED);
static struct nus_entry commands[] = {
NUS_COMMAND(COMMAND_ON, turn_on_cmd),
NUS_COMMAND(COMMAND_OFF, turn_off_cmd),
NUS_COMMAND(COMMAND_TOGGLE, toggle_cmd),
NUS_COMMAND(COMMAND_INCREASE, increase_cmd),
NUS_COMMAND(COMMAND_DECREASE, decrease_cmd),
NUS_COMMAND(NULL, NULL),
void main(void)
//zb_ret_t zb_err_code;
zb_ieee_addr_t ieee_addr;
static zb_bool_t bind_on = 0;
static zb_bool_t reporting_configured = 0;
LOG_INF("Starting ZBOSS Light Switch example");
/* Initialize. */
configure_gpio();
alarm_timers_init();
zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG);
zb_set_ed_timeout(ED_AGING_TIMEOUT_64MIN);
zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000));
/* Set default bulb short_addr. */
/* If "sleepy button" is defined, check its state during Zigbee
* initialization and enable sleepy behavior at device if defined button
* is pressed.
#if defined BUTTON_SLEEPY
if (dk_get_buttons() & BUTTON_SLEEPY) {
zigbee_configure_sleepy_behavior(true);
/* Power off unused sections of RAM to lower device power consumption. */
power_down_unused_ram();
/* Initialize Zigbee FOTA download service. */
zigbee_fota_init(ota_evt_handler);
/* Mark the current firmware as valid. */
confirm_image();
/* Register dimmer switch device context (endpoints). */
ZB_AF_REGISTER_DEVICE_CTX(&dimmer_switch_ctx);
app_clusters_attr_init();
/* Register handlers to identify notifications */
ZB_AF_SET_IDENTIFY_NOTIFICATION_HANDLER(LIGHT_SWITCH_ENDPOINT, identify_cb);
ZB_AF_SET_IDENTIFY_NOTIFICATION_HANDLER(CONFIG_ZIGBEE_FOTA_ENDPOINT, identify_cb);
/* Start Zigbee default thread. */
zigbee_enable();
#if CONFIG_BT_NUS
/* Initialize NUS command service. */
nus_cmd_init(on_nus_connect, on_nus_disconnect, commands);
LOG_INF("ZBOSS Light Switch example started");
// Example of handling incoming temperature measurement
handle_temperature_measurement(simulatedTemperature);
while (1) {
// k_sleep(K_FOREVER);
zboss_main_loop_iteration();
if (ready_to_bind && !bind_on) {
LOG_INF("Ready to bind");
zb_buf_get_out_delayed(bind_req);
bind_on = 1;
else if (bind_on && !reporting_configured)
LOG_INF("Ready to configure reporting");
zb_buf_get_out_delayed(configure_attr_reporting);
reporting_configured = 1;
As I am new to this, please help here get the above information.
Thanks a lot !!!
Best Regards,
Deepika B
