many function in samples/subsys/settings fail with return -2
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
*** Settings usage example ***
settings subsys initialization: OK.
subtree <alpha> handler registered: OK
subtree <alpha/beta> has static handler
# iteration 0
basic load and save using registered handlers
load all key-value pairs using registered handlers
loading all settings under <beta> handler is done
loading all settings under <alpha> handler is done
save <alpha/beta/voltage> key directly: fail (err -2)
OK.
load <alpha/beta> key-value pairs using registered handlers
save all key-value pairs using registered handlers
loading subtree to destination provided by the caller
  direct.length = 10071698309120
  direct.length_1 = 30340
  direct.length_2 = -3025
Delete a key-value pair
delete <alpha/length>: fail (err -2)
  Can't to load the <alpha/length> value as expected
Service a key-value pair without dedicated handlers
<gamma> = 0 (default)
save <gamma> key directly: fail (err -2)
# iteration 1
OK.
# iteration 2
OK.
# iteration 3
OK.
# iteration 4
OK.
# iteration 5
OK.
Inject the value to the setting destination in runtime
<alpha/beta/source> = RT
injected <alpha/beta/source>: OK.
  The settings destination off the key <alpha/beta/source> has got value: "RT"
Read a value from the setting destination in runtime
fetched <alpha/beta/source>: OK.
  String value "rtos" was retrieved from the settings destination off the key <alpha/beta/source>
*** THE END  ***
I did not change any code yet.
using SDK 2.6.1
