Hello!
I have an application using MCUboot and a single application slot. I want to use the Retention System to signal to MCUboot wether to boot normally or into serial recovery mode. I can write into the retained memory portion by using bootmode_set(BOOT_MODE_TYPE_NORMAL) or bootmode_set(BOOT_MODE_TYPE_BOOTLOADER). Within the application, this does write in the specified byte and keeps the value (0 or 1) over a sys_reboot().
However, regardless of the value in that memory, the bootloader never enters serial recovery mode but rather always boots normally.
As I am using a nRF52832 DK, I created an overlay for the retention boot mode:
sram@2000FFFF {
compatible = "zephyr,memory-region", "mmio-sram";
reg = <0x2000FFFF 0x1>;
zephyr,memory-region = "RetainedMem";
status = "okay";
retainedmem {
compatible = "zephyr,retained-ram";
status = "okay";
#address-cells = <1>;
#size-cells = <1>;
retention0: retention@0 {
compatible = "zephyr,retention";
status = "okay";
reg = <0x0 0x1>;
chosen {
zephyr,boot-mode = &retention0;
/* Reduce SRAM0 usage by 1 byte to account for non-init area */
&sram0 {
reg = <0x20000000 0xFFFF>;
The MCUboot config in .\child_image\mcuboot includes
CONFIG_SINGLE_APPLICATION_SLOT=y # Enable Serial Recovery Mode to allow for DFU over UART CONFIG_MCUBOOT_SERIAL=y CONFIG_UART_CONSOLE=n CONFIG_MCUBOOT_INDICATION_LED=y # allow rebooting directly into the serial recovery mode CONFIG_BOOT_SERIAL_BOOT_MODE=y # To detect if the bootloader is running CONFIG_BOOT_MGMT_ECHO=y # Will erase slot 0 if signature validation fails CONFIG_BOOT_VALIDATE_SLOT0=y # Will stay in bootloader if no application is found (e.g. erased after image verification) CONFIG_BOOT_SERIAL_NO_APPLICATION=y # Use Retention system CONFIG_RETAINED_MEM=y CONFIG_RETENTION=y CONFIG_RETENTION_BOOT_MODE=y
while the applications prj.conf includes
CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_RETAINED_MEM=y CONFIG_RETENTION=y CONFIG_RETAINED_MEM_ZEPHYR_RAM=y CONFIG_RETENTION_BOOT_MODE=y CONFIG_REBOOT=y
Now I found out, that while compiling, I get warnings in the MCUboot portion of the compile:
warning: BOOT_SERIAL_BOOT_MODE (defined at C:/ncs/v2.6.1/bootloader/mcuboot/boot/zephyr\Kconfig.serial_recovery:166) was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: RETENTION_BOOT_MODE (=n). See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_BOOT_SERIAL_BOOT_MODE and/or look up BOOT_SERIAL_BOOT_MODE in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. warning: RETENTION (defined at subsys/retention/Kconfig:4) was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: DT_HAS_ZEPHYR_RETENTION_ENABLED (=n). See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_RETENTION and/or look up RETENTION in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. warning: RETENTION_BOOT_MODE (defined at subsys/retention/Kconfig:46) was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: RETENTION (=n). See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_RETENTION_BOOT_MODE and/or look up RETENTION_BOOT_MODE in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
These warnings ONLY appear in the MCUboot compile portion, NOT in the application compile portion.
Then, when I look at the build/zephyr/.config and build/mcuboot/zephyr/.config files, I can see that the application config includes the specified configurations, but the mcuboot config is missing all "RETAINED_MEM.." and "RETENTION..." configurations. I believe that this might cause the error, that mcuboot is not booting into the serial recovery mode.
Can you help me out here in any way? Did I miss something?
Thanks for your help!
