I use custom board for nrf52840 but i have some problem with the BLE. BLE is advertised but when i want to connect it, it keeps connecting. this is my code.
I use mbed before for my board and it runs perfectly fine, so i dont think the board is the problem.
#include <zephyr/kernel.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/mgmt/mcumgr/transport/smp_bt.h>
#define SLEEP_TIME_MS 1000
#define LED0_NODE DT_ALIAS(led0)
static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
static const struct bt_data sd[] = {
BT_DATA_BYTES(BT_DATA_NAME_COMPLETE, CONFIG_BT_DEVICE_NAME)};
int ret;
printk("Board: %s\n", CONFIG_BOARD);
printk("Build time: " __DATE__ " " __TIME__ "\n");
if (!gpio_is_ready_dt(&led))
return -ENODEV;
ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE);
if (ret < 0)
return -ENODEV;
/* Enable Bluetooth */
ret = bt_enable(NULL);
if (ret < 0)
printk("Bluetooth init failed (err %d)\n", ret);
return ret;
/* Start advertising */
ret = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad),
sd, ARRAY_SIZE(sd));
if (ret < 0)
printk("Advertising failed to start (err %d)\n", ret);
return ret;
while (1)
ret = gpio_pin_toggle_dt(&led);
if (ret < 0)
return -ENODEV;
k_msleep(SLEEP_TIME_MS);
return 0;
