The timer is not working in ble_app_uart.
Hi ,
I am using nRF52810 to start a project that combines BLE app UART and a timer. I found an example BLE app UART project from the directory nRF5_SDK_17.0.2_d674dde\examples\ble_peripheral\ble_app_uart\pca10040e\s112\ses\ble_app_uart_pca10040e_s112. That example project was built in Segger Embedded Studio without any errors. After that, I needed to add a timer part, so I found another working timer example project in the directory nRF5_SDK_17.0.2_d674dde\examples\peripheral\timer\pca10040\blank\ses\timer_pca10040 and copied the contents of the timer example project into the ble_app_uart project.
I made some modifications in the sdk_config.h file with the following changes: TIMER_ENABLED 1, TIMER1_ENABLED 1, APP_TIMER_ENABLED 1, NRFX_TIMER_ENABLED 1. I used the timer instance const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(1); (timer instance 1).
However, I am facing an issue where the added timer part is not working. In the timer example project, the timer interrupt is supposed to trigger and indicate an LED based on a set time in milliseconds. I have set it to 1000 ms. Is there any timer width adjustment needed here? I will include my code for more clarification.
seggar embedded studio version :- 5.42a
sdk version :- 17.0.2
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
//********ADDED_HEADER_FILES********//
#include "nrf_delay.h"
#include "nrf_drv_timer.h"
#include "bsp.h"
#include "app_error.h"
//********END************************//
//***************#DEFINES**********//
#define UART_DEBUG
#define BLUE_LED 12
#define GREEN_LED 11
//****************END***************//
//**************VARIABLE_DECLARATIONS********//
char BLEDataBuff[64];
//**************END*******************//
//***************INSTANCE_DECLEARATIONS*******//
//****************END**************************//
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
    memset(BLEDataBuff,0,sizeof(BLEDataBuff));
        uint32_t err_code;
        printf("Received data from BLE NUS. Writing data on UART.");
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
           BLEDataBuff[i]=(p_evt->params.rx_data.p_data[i]);
            //do
            //    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
            //    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
            //        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            //        printf("Failed receiving NUS message. Error 0x%x. ", err_code);
            //        APP_ERROR_CHECK(err_code);
            //} while (err_code == NRF_ERROR_BUSY);
        //if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
        //    while (app_uart_put('\n') == NRF_ERROR_BUSY);
         #ifdef UART_DEBUG
          int length = strlen(BLEDataBuff);
          printf("\nlength : %d\n",length);
          printf("\nBLEDataBuff : %s\n ",BLEDataBuff);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            printf("Connected");
            NRF_LOG_INFO("Disconnected");
            printf("Disconnected");
            printf("PHY update request.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        printf("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
     printf("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    printf("Ready to send data over BLE NUS");
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
/**@brief Function for processing ble data (test_function)
 * function name :- process_bledata
 * parameter     :- bledata
 * process_bledata function is responsible for checking the data from ble
   if the data matches with certain keywords do led blinking
 * return value :- nill
void process_bledata(char *bledata)
 #ifdef UART_DEBUG
 printf("\n enter in process bledata \n");
 if (strstr(bledata,"BLUE") != NULL)
       printf("RED LED GLOW \n");
       nrf_gpio_pin_set(BLUE_LED);
       nrf_delay_ms(200);
       nrf_gpio_pin_clear(BLUE_LED);
 else if(strstr(bledata,"GREEN") != NULL)
       printf("GREEN LED GLOW \n");
       nrf_gpio_pin_set(GREEN_LED);
       nrf_delay_ms(200);
       nrf_gpio_pin_clear(GREEN_LED);
      printf("unwanted data : %s\n",bledata);
/**@brief Function for led configuration
 * function name :- indication_led_init
 * parameter     :- nill
 * indication_led_init function is responsible for configuring the leds
void indication_led_init()
  nrf_gpio_cfg_output(GREEN_LED);
  nrf_gpio_cfg_output(BLUE_LED);
 * @brief Handler for timer events.
void timer_led_event_handler(nrf_timer_event_t event_type, void* p_context)
    static uint32_t i;
    int j=0;
    uint32_t led_to_invert = ((i++) % LEDS_NUMBER);
    switch (event_type)
        case NRF_TIMER_EVENT_COMPARE0:
            //bsp_board_led_invert(led_to_invert);
            nrf_gpio_pin_toggle(GREEN_LED);
            nrf_gpio_pin_toggle(BLUE_LED);
            //Do nothing.
/**@brief Application main function.
    bool erase_bonds;
    int len1=0;
    uint32_t time_ms = 100; //Time(in miliseconds) between consecutive compare events.
    uint32_t time_ticks;
    uint32_t err_code = NRF_SUCCESS;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    indication_led_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    #ifdef UART_DEBUG
    advertising_start();
    err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer_led_event_handler);
    time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_LED, time_ms);
    nrf_drv_timer_extended_compare(
    &TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    nrf_drv_timer_enable(&TIMER_LED);
    //while(1)
    //len1=strlen(BLEDataBuff);
    //printf("len1 : %d\n",len1);
    //if(len1!=0)
    //  #ifdef UART_DEBUG
    //  printf("\n enter process ble data \n");
    //  #endif
    //  process_bledata(BLEDataBuff);
    //  memset(BLEDataBuff,0,sizeof(BLEDataBuff));
    //nrf_delay_ms(1000);
    // Enter main loop.
    //for (;;)
    //    idle_state_handle();
    while (1)
        __WFI();
    Yes, the TIMER_DEFAULT_CONFIG_BIT_WIDTH must be set to '3' in the sdk_config.h header to prevent the counter register from overflowing when using longer delays. Please also note that HF timers will add about 500 uA to the sleep current if left running. If you want to reduce the current consumption, I recommend creating an app timer instance instead. You can use other ble examples such as ble_app_hrs as a reference for how to enable app timer instances. The app timer library runs of the RTC.
    Vidar
