DFU Process
nrf52840 17.1.0 s140 SDK :- examples/dfu/secure_bootloader/pca10056_s140_ble_debug
We are using nrf52840 17.1.0 s140 DK secure bootloader with BLE debug. We initialized the UART function. However, while performing DFU FOTA from a mobile device, I tried to print the received BLE packet using UART, but encountered the following error in the log:
If the nrf_drv_uart_tx send function is removed, the DFU process completes successfully without any issues. We are calling this function in the nrf_dfu_ble.c file within the static void on_write(ble_dfu_t * p_dfu, ble_evt_t const * p_ble_evt); function.
<info> app: Inside main
<debug> app: In nrf_bootloader_init
<debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
<debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
<debug> nrf_dfu_settings: Using settings page.
<debug> nrf_dfu_settings: Copying forbidden parts from backup page.
<debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
<info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
<debug> app: Enter nrf_bootloader_fw_activate
<info> app: No firmware to activate.
<info> app: Boot validation failed. No valid app to boot.
<debug> app: DFU mode because app is not valid.
<info> nrf_bootloader_wdt: WDT is not enabled
<debug> app: in weak nrf_dfu_init_user
<debug> app: timer_stop (0x20005998)
<debug> app: timer_activate (0x20005998)
<info> app: Entering DFU mode.
<debug> app: Initializing transports (found: 2)
<debug> nrf_dfu_ble: Initializing BLE DFU transport
<debug> nrf_dfu_ble: Setting up vector table: 0x000E8000
<debug> nrf_dfu_ble: Enabling SoftDevice.
<debug> nrf_dfu_ble: Configuring BLE stack.
<debug> nrf_dfu_ble: Enabling the BLE stack.
<debug> nrf_dfu_ble: No advertising name found
<debug> nrf_dfu_ble: Using default advertising name
<debug> nrf_dfu_ble: Advertising...
<debug> nrf_dfu_ble: BLE DFU transport initialized.
<debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
<debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
<info> nrf_dfu_serial_uart: Sending initial byte 0x24
<debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
<debug> app: Enter main loop
<debug> nrf_dfu_ble: Connected
<debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST.
<debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE (27, max_rx_time 328).
<debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
<debug> nrf_dfu_ble: max_conn_interval: 12
<debug> nrf_dfu_ble: min_conn_interval: 12
<debug> nrf_dfu_ble: slave_latency: 0
<debug> nrf_dfu_ble: conn_sup_timeout: 600
<debug> nrf_dfu_ble: max_conn_interval: 6
<debug> nrf_dfu_ble: min_conn_interval: 6
<debug> nrf_dfu_ble: conn_sup_timeout: 500
<debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 517, reply: 247).
<debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE (251, max_rx_time 2120).
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
<debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
<debug> nrf_dfu_ble: Set receipt notif
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
<debug> app: Shutting down transports (found: 2)
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
<debug> nrf_dfu_ble: Buffer 0x20006ED8 acquired, len 141 (244)
<info> nrf_dfu_serial_uart: Sending data
<error> app: Received a fault! id: 0x00004002, pc: 0x00000000, info: 0x2003FCE0
  • 1. Hi thanks for your reply let me explain in simple way in booloader_ble_debug sdk after while performing dfu the new firmware is going to write in the flash instead of writing the data in flash the same should be sent in the uart
    2. flash -> replace with UART transfer
    3. So whenever it is required we will write in flash or we will send same data in UART only one at a time
    4. we need to achieve this in booloader_ble_debug app
    New_firmware_write_func
    if(cond)
    uart_tx(data)
     rc = nrf_fstorage_write(&m_fs, dest, p_src, len, (void *)callback);
    5. We enabled UART transport in nrf_dfu_serial_uart.c for the nRF52840 using SDK version 17.1.0, S140. The relevant code is in examples/dfu/secure_bootloader/pca10056_s140_ble_debug:
    DFU_TRANSPORT_REGISTER(nrf_dfu_transport_t const uart_dfu_transport) =
       .init_func  = uart_dfu_transport_init,
       .close_func = uart_dfu_transport_close,
