DFU Process
nrf52840 17.1.0 s140 SDK :- examples/dfu/secure_bootloader/pca10056_s140_ble_debug
We are using nrf52840 17.1.0 s140 DK secure bootloader with BLE debug. We initialized the UART function. However, while performing DFU FOTA from a mobile device, I tried to print the received BLE packet using UART, but encountered the following error in the log:
If the nrf_drv_uart_tx send function is removed, the DFU process completes successfully without any issues. We are calling this function in the nrf_dfu_ble.c file within the static void on_write(ble_dfu_t * p_dfu, ble_evt_t const * p_ble_evt); function.
<info> app: Inside main
<debug> app: In nrf_bootloader_init
<debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
<debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
<debug> nrf_dfu_settings: Using settings page.
<debug> nrf_dfu_settings: Copying forbidden parts from backup page.
<debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
<info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
<debug> app: Enter nrf_bootloader_fw_activate
<info> app: No firmware to activate.
<info> app: Boot validation failed. No valid app to boot.
<debug> app: DFU mode because app is not valid.
<info> nrf_bootloader_wdt: WDT is not enabled
<debug> app: in weak nrf_dfu_init_user
<debug> app: timer_stop (0x20005998)
<debug> app: timer_activate (0x20005998)
<info> app: Entering DFU mode.
<debug> app: Initializing transports (found: 2)
<debug> nrf_dfu_ble: Initializing BLE DFU transport
<debug> nrf_dfu_ble: Setting up vector table: 0x000E8000
<debug> nrf_dfu_ble: Enabling SoftDevice.
<debug> nrf_dfu_ble: Configuring BLE stack.
<debug> nrf_dfu_ble: Enabling the BLE stack.
<debug> nrf_dfu_ble: No advertising name found
<debug> nrf_dfu_ble: Using default advertising name
<debug> nrf_dfu_ble: Advertising...
<debug> nrf_dfu_ble: BLE DFU transport initialized.
<debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
<debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
<info> nrf_dfu_serial_uart: Sending initial byte 0x24
<debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
<debug> app: Enter main loop
<debug> nrf_dfu_ble: Connected
<debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST.
<debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE (27, max_rx_time 328).
<debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
<debug> nrf_dfu_ble: max_conn_interval: 12
<debug> nrf_dfu_ble: min_conn_interval: 12
<debug> nrf_dfu_ble: slave_latency: 0
<debug> nrf_dfu_ble: conn_sup_timeout: 600
<debug> nrf_dfu_ble: max_conn_interval: 6
<debug> nrf_dfu_ble: min_conn_interval: 6
<debug> nrf_dfu_ble: conn_sup_timeout: 500
<debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 517, reply: 247).
<debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE (251, max_rx_time 2120).
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
<debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
<debug> nrf_dfu_ble: Set receipt notif
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
<debug> app: Shutting down transports (found: 2)
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
<debug> nrf_dfu_ble: Buffer 0x20006ED8 acquired, len 141 (244)
<info> nrf_dfu_serial_uart: Sending data
<error> app: Received a fault! id: 0x00004002, pc: 0x00000000, info: 0x2003FCE0
