we have a solution using UWB from Qorvo using the Nordic 52833.. however
this works well with an Apple 11-13, but on 14+ Apple has removed the second antenna from the phone, so it cannot do ranging natively.
the AR approach does not work for our blind users (camera they cant see and it kills our voice driven UI)
AND Android UWB is different than IOS UWB..
anyhow.. we want to explore a user held device also with a qorvo 52833/40  to run FIRA ranging..  this works.. (think phone case)  but
now I need to connect the ranging process and data to our phone app..
does the 833/40 have the horsepower while UWB ranging (FIRA) to handle another BT connection to our phone app
the data is small, and not terribly frequent
I see the ranging sample app.. over an OOB BT connection..  this would be similar output
so our phone app would connect to the device (bt?)
send commands to the nordoc resident app
the nordic resident app would execute start/stop ranging, FIRA commands lo the FIRA UCI app that Qorvo provides
and send the ranging data to the phone app.
the device would be battery powered, not wire connected
and if it has an IMU we could use that for user info on orientation.
  • it wasn't two protocols  it was the same protocol with two different configurations.  one ranging,  and  one as a raw data mover.
    but as I said. using uwb between phone and external device doing ranging means the phone has to  have uwb.  not using uwb as the data mover means many more phones could be used.
  • Hi Sam
    Håkon is out of office, so I've been assigned this case in his stead.
    I'm afraid this will be out of our hands, as UWB is not something done on the nRF52833 inherently. I believe Qorvo only uses the nRF52833 for Bluetooth connection/pairing to handle the data part of setting up UWB. All firmware related to UWB will be done by Qorvo/Apple in this case, and you should refer to their support channels for help with this issue. Let me know if I'm misunderstanding anything and please explain what assistance you require from Nordic on this.
    Simon
  • thanks.. I see that both SOC's I use have a Nordic 52833/40 as the host processor for the solution
    DW3001C  which runs the 52833 (built before the 840 was released)
    and the Murata 2AB which runs the 52840
    I didn't mean the nrf chips DO the UWB signals.. they run the UWB control APP.. fira/UCI in my case.
    Qorvo/Murata do/choose not to answer my question about adding another/changing the app.
    in both cases I want to replace the USB/serial port component of the existing fira UCI app with Bluetooth transport.
    the 833 will be very limited output
    the 840 will be the brunt of the work.
    does Nordic provide tools or guidance on performance measurement on these devices?
  • Thank you for explaining, I think we're on the same page now. You basically just want one more connection from the nRF52 side, right. I'm not familiar with UCI or the UWB solution, but I imagine that managing one more BLE connection should be possible here as long as it's not doing big data transfers as well.
    I'm not sure what tools and performance measurements you're looking for here, but you can refer to the Zephyr documentation on connection management to see how multiple BLE connections should be handled, and possible the Throughput sample to do some testing on what numbers you can achieve with multiple connections in your use case.
    Simon
  • yes.  I have a couple questions related to sdk
    the fira platform qorvo supplies is built on the now legacy  sdk 17.1.0 and the segger build system.
    is there any mechanism to migrate that to the newer visual studio style?
    Secondly  if I have to use the legacy sdk is there any doc on how to configure it? comments say to use the config tool off the context menu. but I don't see that
    I need to add ble and bluetooth native for selective builds
    the case device would need bt native w pairing to lock to the phone and transfer data in both directions  and ble central to connect (one build)
    to the end device ble peripheral  to sync fira operations. (other build)
    the current build uses  usb serial to take commands from the host and send data back on both devices,   usb only
