Code flashing successful but not working!
I am creating a new project that uses the nRF52810 as my controller, and during the development stage, I am using the PCA10040 nRF52832 development board. (I read somewhere that we can flash the nRF52810 code into the nRF52832 PCA10040 development board). My requirement is a simple LED indicator based on delay commands from an APK that uses the Nordic UART service to send and receive data. I added the timer peripheral to the ble_app_uart example project from the directory nRF5_SDK_17.0.2_d674dde\examples\ble_peripheral\ble_app_uart\pca10040e\s112\ses and flashed the code onto the PCA10040 nRF52832 development board to test it. The code works perfectly.
Then I took an nRF52810 custom PCB and connected the JTAG. The board is able to detect and erase the chip. When I flash the code onto the board, the IDE shows "flash successful," but the board is not working. Are there any other conditions for flashing the code into the nRF52810 custom board? Your response is valuable.
SDK version: 17.0.2
SEGGER Embedded Studio version: 5.42a
  •   , Sure, when I am debugging the code, it stops at NRF_BREAKPOINT_COND in the function app_error_fault_handler(). I am attaching a screenshot for better understanding.
  • Hi.
    Is "Fatal error" something you print out? From the call stack it looks like it's going into the error handler from the UART callback handler. Can you share that code?
    regards
    Jared
  • hi  , Sorry for the delayed response, we had a holiday for the past two days. I will share my project code for better clarification. Are there any stack or heap memory allocation dependencies while flashing the code into the nRF52810? It has very little flash memory, approximately 192KB.
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    //********ADDED_HEADER_FILES********//
    #include "nrf_delay.h"
    #include "nrf_drv_timer.h"
    #include "bsp.h"
    #include "app_error.h"
    //********END************************//
    //***************#DEFINES**********//
    #define UART_DEBUG
    #define TIME_MINITUE "MINITUE"
    #define BLUE_LED 12
    #define GREEN_LED 11
    #define VIBRATOR 26
    //****************END***************//
    //**************VARIABLE_DECLARATIONS********//
    char BLEDataBuff[64];
    char BLETempData[256];
    uint8_t ConnectionStatus=0;
    //**************END*******************//
    //***************INSTANCE_DECLEARATIONS*******//
    const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(1);
    //****************END**************************//
    typedef enum BLE_COMMANDS
      BLE_MINITUE=1,
      BLE_SEC,
      BLE_LED,
    }BLE_COMMANDS;
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
        memset(BLEDataBuff,0,sizeof(BLEDataBuff));
            uint32_t err_code;
            printf("Received data from BLE NUS. Writing data on UART.");
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
               BLEDataBuff[i]=(p_evt->params.rx_data.p_data[i]);
                //do
                //    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                //    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                //        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                //        printf("Failed receiving NUS message. Error 0x%x. ", err_code);
                //        APP_ERROR_CHECK(err_code);
                //} while (err_code == NRF_ERROR_BUSY);
            //if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            //    while (app_uart_put('\n') == NRF_ERROR_BUSY);
             #ifdef UART_DEBUG
              int length = strlen(BLEDataBuff);
              printf("\nlength : %d\n",length);
              printf("\nBLEDataBuff : %s\n ",BLEDataBuff);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                printf("Connected");
                ConnectionStatus=1;
                NRF_LOG_INFO("Disconnected");
                printf("Disconnected");
                ConnectionStatus=0;
                printf("PHY update request.");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        NRF_LOG_INFO("ENTER IN BLE STACK INIT \n ");
        ret_code_t err_code;
        NRF_LOG_INFO("NRF SDH ENABLE REQUEST : %d\n ",err_code);
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
            printf("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
         printf("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        printf("Ready to send data over BLE NUS");
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        NRF_LOG_INFO(" ENTER BUTTON LEDS INIT\n");
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
        //NRF_LOG_INFO(" BSP INIT ERROR CODE : %d\n",err_code);
        //NRF_LOG_INFO("BSP_BTN_BLE_INIT : %d\n ",err_code);
    static void log_init(void)
            nrf_pwr_mgmt_run();
        NRF_LOG_INFO("ble_advertising_start : %d\n",0);
    /**@brief Function for processing ble data (test_function)
     * function name :- process_bledata
     * parameter     :- bledata
     * process_bledata function is responsible for checking the data from ble
       if the data matches with certain keywords do led blinking
     * return value :- nill
    void process_bledata(char *bledata)
     #ifdef UART_DEBUG
     printf("\n enter in process bledata \n");
     if (strstr(bledata,"BLUE") != NULL)
           printf("RED LED GLOW \n");
           nrf_gpio_pin_set(BLUE_LED);
           nrf_delay_ms(200);
           nrf_gpio_pin_clear(BLUE_LED);
     else if(strstr(bledata,"GREEN") != NULL)
           printf("GREEN LED GLOW \n");
           nrf_gpio_pin_set(GREEN_LED);
           nrf_delay_ms(200);
           nrf_gpio_pin_clear(GREEN_LED);
          printf("unwanted data : %s\n",bledata);
    /**@brief Function for led configuration
     * function name :- indication_led_init
     * parameter     :- nill
     * indication_led_init function is responsible for configuring the leds
    void indication_gpio_init()
      nrf_gpio_cfg_output(GREEN_LED);
      nrf_gpio_cfg_output(BLUE_LED);
      //nrf_gpio_cfg_output(VIBRATOR);
    void ledonoff()
     while(1)
     //nrf_gpio_pin_clear(VIBRATOR);
     nrf_delay_ms(200);
     * @brief Handler for timer events.
    void timer_led_event_handler(nrf_timer_event_t event_type, void* p_context)
        static uint32_t i;
        int j=0;
        uint32_t led_to_invert = ((i++) % LEDS_NUMBER);
        switch (event_type)
            case NRF_TIMER_EVENT_COMPARE0:
                 nrf_delay_ms(200);
                 //nrf_gpio_pin_set(VIBRATOR);
                 // nrf_gpio_pin_set(BLUE_LED);
               //  nrf_delay_ms(200);
                // nrf_gpio_pin_clear(BLUE_LED);
                //bsp_board_led_invert(led_to_invert);
               // nrf_gpio_pin_toggle(GREEN_LED);
                //nrf_gpio_pin_toggle(BLUE_LED);
                //Do nothing.
    /**@brief Function for minitue to milliseconds conversion
     * function name :- minituetomilli
     * parameter     :- bledatabuff
     * the function is responsible for converting mintue to millisecond conversion
     * return value :- converted milliseconds
    uint32_t  minitue_to_milli(char *data)
        printf("received data: %s\n", data);
        int minit = 0;
        minit = atoi(data);
        printf("minit: %d\n", minit);
        uint32_t milliseconds = minit * 60000; // convert minutes to milliseconds
        printf("milliseconds: %d\n", milliseconds);
        return milliseconds;
    /**@brief Function for setting timer
     * function name :- timer_setting
     * parameter     :- BLETempData
     * the function is responsible for setting the trigger intervel of timer
    void timer_setting(char *data)
      printf("enter inside timer settings\n");
      char *token;
      uint32_t time_ticks;
      uint32_t err_code = NRF_SUCCESS;
     // int milliseconds =0;
      uint32_t time_ms=0;
      token = strtok(data + strlen(TIME_MINITUE), ",");
      printf("token = %s",token);
      time_ms=minitue_to_milli(token);
      printf(" time_ms : %d\n",time_ms);
      err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer_led_event_handler);
      printf(" nrf_drv_timer_init : %d\n",err_code);
      time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_LED, time_ms);
      printf("time_ticks : %d\n",time_ticks);
      nrf_drv_timer_extended_compare(
      &TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
      nrf_drv_timer_enable(&TIMER_LED);
    /**@brief Function for processsing ble commands
     * function name :- ble_processcommand
     * parameter     :- cmd
     * the function is responsible for calling the functions based on commands
    void ble_commandprocessing(char command)
      printf("enter inside ble command processing \n ");
      switch(command)
        case BLE_MINITUE  :   printf("enter in timer settngs \n");
                              timer_setting(BLETempData);
     * the function is responsible for processing ble commands
     * return value :- enum value of matched keyword in bluetooth command
    char ble_processcommand(char *data)
     printf(" enter inside ble processcommand\n ");
     memcpy(BLETempData,data,strlen(data));
     nrf_delay_ms(100);
     if (strstr(data,TIME_MINITUE) != NULL)
     return BLE_MINITUE;
    /**@brief Application main function.
        bool erase_bonds;
        int len1=0;
        char cmd=0;
        //uint32_t time_ticks;
        //uint32_t err_code = NRF_SUCCESS;
        // Initialize.
        uart_init();
        NRF_LOG_INFO("UART INTI\n");
        log_init();
        NRF_LOG_INFO("LOG INTI\n");
        timers_init();
        NRF_LOG_INFO("TIMER INTI\n");
        NRF_LOG_INFO("BEFORE ENTER BUTTONS LED INIT \n");
        NRF_LOG_INFO("BUTTON LED INIT \n");
        indication_gpio_init();
        NRF_LOG_INFO(" INDICATION GPIO INIT \n");
        //ledonoff();
        //nrf_gpio_pin_set(GREEN_LED);
        //nrf_gpio_pin_set(BLUE_LED);
        //while(1)
        //    nrf_gpio_pin_clear(GREEN_LED);
        //    nrf_gpio_pin_set(GREEN_LED);
        power_management_init();
        NRF_LOG_INFO(" POWER MANAGEMENT INIT \n");
        ble_stack_init();
        NRF_LOG_INFO(" BLE STACK INIT \n");
        gap_params_init();
        NRF_LOG_INFO(" GAP PARAMS INIT \n");
        gatt_init();
        NRF_LOG_INFO(" GATT INIT  \n");
        services_init();
        NRF_LOG_INFO(" SERVICE  INIT \n");
        advertising_init();
        NRF_LOG_INFO(" ADVERTISING  INIT \n");
        conn_params_init();
        NRF_LOG_INFO(" CONNECTION PARAMS INIT \n");
        // Start execution.
        #ifdef UART_DEBUG
        NRF_LOG_INFO("\n uart started \n.");
        advertising_start();
        NRF_LOG_INFO("ADVERTISING STARTED \n.");
        while(1)
           //printf("running inside while \n");
           nrf_delay_ms(100);
           if(ConnectionStatus==1)
             //printf("ConnectionStatus=1 \n");
             nrf_delay_ms(100);
        printf(" exit from connection \n");
        while(1)
        nrf_delay_ms(200);
        if(strlen(BLEDataBuff))
         printf("enter in if\n");
         cmd= ble_processcommand(BLEDataBuff);
         ble_commandprocessing(cmd);
         nrf_delay_ms(100);
         printf("exit in if \n");
        while (1)
            __WFI();
  • Hi.
    Are you able to read out the ERRORSRC register when program asserts and see if it's due to an UART ERROR?
    regards
    Jared
  • Hi  ,
    As per your suggestion, I checked the ERRORSRC register while debugging the code. I will attach an image of the ERRORSRC register values on my custom PCB with the nRF52810.
    I am getting confused because I flashed the example BLE app UART project from the pca10040e/s112 directory onto the development board(pca10040 nrf52832 ) . While debugging the code in the IDE, the same fatal error occurs.I will attach an image of the ERRORSRC register values on the development board .
    is there any issue with the code availabale in sdk 17.0.2  ? .
    I found that someone experienced the same issue and solved it by modifying the memory settings. The following link directs to their ticket:
    ,https://devzone.nordicsemi.com/f/nordic-q-a/32650/ble_app_uart-fatal-error-on-nrf52810
    How can the memory settings be modified here?
