Radio Activity Causes GPIOTE Interrupt Missing
I'm running a GPIOTE test that pulses a debug pin whenever CPU executes user registered GPIOTE handler. The GPIOTE trigger pin has a 8ms period, 8us duration low-active pulse. Theoretically, the debug pin should pulse the same rate as the trigger. However, whenever I turn on the radio (advertisement / in connection), it causes GPIOTE interrupt to go missing sometimes as you can see in the attached screenshot.
Yellow is the Debug Pin (GPIOTE Interrupt Handler) Blue is generated with ble_radio_notification handler, representing BLE ACTIVE with 800us distance on both ends.
SD: s110_nrf51822_6.0.0-1.alpha SDK: 4.4.2
Not sure if I'm missing anything...
Thanks, Bruce
Code Snippet:
GPIOTE Initialization
  /* enable negative edge interrrupt on RDY pin */
  nrf_gpio_cfg_input(RDY_PIN_NUMBER, NRF_GPIO_PIN_PULLUP); /* RDY is open drain */
  if ((gpiote_status = app_gpiote_user_register(&gpiote_user_id, 0, 1 << RDY_PIN_NUMBER, &interrupt_handler)) != NRF_SUCCESS)
  if ((gpiote_status = app_gpiote_user_enable(gpiote_user_id)) != NRF_SUCCESS)
GPIOTE interrupt handler
static void interrupt_handler(uint32_t event_pins_low_to_high, uint32_t event_pins_high_to_low)
  nrf_gpio_pin_set(DEBUG1);
  nrf_gpio_pin_clear(DEBUG1);
