The question of CIS and BIS modes work at the same time
In my last question, devzone.nordicsemi.com/.../can-cis-and-bis-modes-work-at-the-same-time-or-switching-freely, I have asked that if the CIS and BIS modes can work at the same time. And i got the answer is can, and there is example show that in the V2.7.0 SDK.
But i found the example(ISO combined BIS and CIS) is only using for the common data transmissions, what i want is that the CIS and BIC modes can work at the same time for the le-audio, And i found that the nrf5340 audio application in the V2.7.0 SDK is still only can configure one mode at one time. I know that in theory, le audio can also be considered as transmitting data, but due to specific bandwidth and resource limitations, I have to confirm again whether nrf5340 can achieve le audio working in both CIS and BIS modes at same time. If it can, is there any plan to implement it into nrf5340 audio application? If it can not, does nrf54H20 can enable the two mode at the same time for the le-audio?
By the way, i also found that the nrf5340 audio application in the V2.7.0 SDK can not work well, when it started as the default headset mode, it will output these following logs.
Thank you very much and looking forward to your help!
    So this is the output you get after flashing the default app with headset mode enabled to an Audio DK? How are you flashing it?
    I haven't looked into this myself, but I see from the cases you've linked to that it should be able to do both concurrently. It seems to be confirmed in several of those cases. It might just be that the sample we linked to doesn't demonstrate this.
    Elfving
  • Hello Elfving,
    Yes, the default nrf5340 audio application is headset mode. I use vscode to build it and flash it and i have modified nothing to the project.
    Can you confirm this, as we need to evaluate the functionality of our product.
    Thank you very much and looking forward to your reply!
    Can you provide more information about your use case and your specific bandwidth and resource limitations?
    Which device do you use on the other side, as gateway? Which changes have you made on the gateway device? Can you provide application log on the gateway side?
    Dejan
  • Hello dejans,
    What i want is the gateway can receive a BIS stereo  audio signal(at least 48K sample rate), and send to the headset through CIS mode, May I ask if this is feasible?
    We do not have any sample which could demonstrate your desire scenario. In described scenario there is a risk that BIS ISO packets could collide CIS/ACL/ADV packets which could cause packet drop resulting in restricted quality and latency. However, there are some resources you could take a look at - combined BIS and CIS and configurations for parallel use of BIS and CIS.
    Dejan
