Using a one shot timer to stop BT scan after a while caused a kernel panic
I'm using the Bluetooth sample called Central HIDS and want to develop a feature that stops BT scanning after a few minutes.
However, during development, I encountered that when BT started scanning, the one shot timer entered the expiration function after reaching a specific time. Executing the bt_scan_stop() API to stop BT scanning in the expiration function would cause a kernel panic and system restart.
Here is an excerpt of some modified code. The rest of the code is the same as the sample code.
/* other defines */
#define AUTO_SCAN_TIME		K_MINUTES(2)
struct k_timer scan_timer;
/* other announcements */
/* other functions */
static void scan_timer_expired(struct k_timer *timer_id)
	int err;
	printk("Stop scanning\n");
	err = bt_scan_stop();
	if (err) {
		printk("Stop LE scan failed (err %d)\n", err);
	printk("Scanning successfully stopped\n");
static void scan_init(void)
	int err;
	struct bt_scan_init_param scan_init = {
		.connect_if_match = 1,
		.scan_param = NULL,
		.conn_param = BT_LE_CONN_PARAM_DEFAULT
	bt_scan_init(&scan_init);
	bt_scan_cb_register(&scan_cb);
	/* do other work */
	k_timer_init(&scan_timer, scan_timer_expired, NULL);
void main(void)
	int err;
	printk("Starting Bluetooth Central HIDS example\n");
	/* do other work */
	scan_init();
	/* do other work */
	err = bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
	if (err) {
		printk("Scanning failed to start (err %d)\n", err);
		return;
	k_timer_start(&scan_timer, AUTO_SCAN_TIME, K_NO_WAIT);
	printk("Scanning successfully started\n");
First, I defined a duration called AUTO_SCAN_TIME and an expiry function called scan_timer_expired() for the one shot timer.
The stop BT scan function is called in the scan_timer_expired() function.
Next, initialize the one shot timer in the scan_init() function.
Finally, after BT starts scanning, start the one shot timer in the main() function.
This is the UART console log.
*** Booting Zephyr OS build vasco_phase1_20230727 ***
I: 8 Sectors of 4096 bytes
I: alloc wra: 0, fe8
I: data wra: 0, 0
I: SoftDevice Controller build revision:
I: 6d 90 41 2a 38 e8 ad 17 |m.A*8...
I: 29 a5 03 38 39 27 d7 85 |)..89'..
I: 1f 85 d8 e1             |....
I: HW Platform: Nordic Semiconductor (0x0002)
I: HW Variant: nRF52x (0x0002)
I: Firmware: Standard Bluetooth controller (0x00) Version 109.16784 Build 2917677098
I: No ID address. App must call settings_load()
Bluetooth initialized
I: Identity: DA:3F:22:39:70:D5 (random)
I: HCI: version 5.3 (0x0c) revision 0x11fa, manufacturer 0x0059
I: LMP: version 5.3 (0x0c) subver 0x11fa
Stop scanning
ASSERTION FAIL @ WEST_TOPDIR/zephyr/kernel/sem.c:121
E: r0/a1:  0x00000004  r1/a2:  0x00000079  r2/a3:  0x00000001
E: r3/a4:  0x0001f891 r12/ip:  0x00000000 r14/lr:  0x00024953
E:  xpsr:  0x41000021
E: Faulting instruction address (r15/pc): 0x0002a622
E: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
E: Fault during interrupt handling
E: Current thread: 0x20002060 (unknown)
I: alloc wra: 0, fd0
I: data wra: 0, 1c
Environment and tools I use:
nRF Connect SDK version: v2.2.0
Hardware: nRF52840 DK
Could anyone help with this?
Please feel free to let me know if you need more information.
