I am working on a project which has external flash (FM25V01A ) connected to nrf52832 board over SPI. And when building the project, I am getting the following error:
In the overlay file when I put the memory size above few megabyte or Gigabyte, then the program run perfectly. However, when I try to put the actual size of the memory, which is (0x00004000) then I got the above error. My overlay file is given below
/delete-node/ &storage_partition;
chosen {
nordic,pm-ext-flash = &FM25V01A;
fstab {
compatible = "zephyr,fstab";
lfs1: lfs1 {
compatible = "zephyr,fstab,littlefs";
mount-point = "/lfs1";
partition = <&lfs1_part>;
automount;
read-size = <16>;
prog-size = <16>;
cache-size = <64>;
lookahead-size = <32>;
block-cycles = <512>;
&spi2 {
compatible = "nordic,nrf-spi";
status = "okay";
pinctrl-0 = <&spi2_default>;
pinctrl-1 = <&spi2_sleep>;
cs-gpios = <&gpio0 22 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
FM25V01A: FM25V01A@0 {
compatible = "jedec,spi-nor";
status = "okay";
label = "25V01A";
reg = <0>;
spi-max-frequency = <8000000>; /* Adjust based on your flash specifications */
size = <0x0004000>; /* Adjust based on your flash size */
//has-dpd;
// t-enter-dpd = <3000>;
// t-exit-dpd = <30000>;
jedec-id = [ c2 22 10 ]; /* Adjust based on your flash JEDEC ID */
&pinctrl {
spi2_default: spi2_default {
group1 {
psels = <NRF_PSEL(SPIM_SCK, 0, 25)>, /* gpio 0 pin P0.25 */
<NRF_PSEL(SPIM_MISO, 0, 24)>, /* gpio 0 pin P0.24 */
<NRF_PSEL(SPIM_MOSI, 0, 23)>; /* gpio 0 pin P0.23 */
spi2_sleep: spi2_sleep {
group1 {
&FM25V01A {
partitions {
#address-cells = <1>;
#size-cells = <1>;
lfs1_part: partition@0 {
label = "storage";
reg = <0x00000000 0x00004000>;
&i2c0 {
status = "disabled";
&i2c1 {
&spi1 {
&spi0 {
&uart0 {
&flash0{
&led0 {
&led1 {
&led2 {
&led3 {
&pwm_led0 {
&button0 {
&button1 {
&button2 {
&button3 {
&arduino_header {
I am also adding my prj file below.
CONFIG_SPI=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_FLASH_PAGE_LAYOUT=y
# Let __ASSERT do its job
CONFIG_DEBUG=y
CONFIG_LOG=y
CONFIG_LOG_MODE_MINIMAL=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=y
