I was trying to set up partitions on a nRF5340 DK so I can use MCUBoot, settings, and littlefs but am getting this error when flashing the dk:
E: Failed to open flash area ID 8 (image 0 slot 1): -19, cannot continue
The output Zephyr.dts has this:
flash_controller: flash-controller@39000 {
compatible = "nordic,nrf53-flash-controller";
reg = < 0x39000 0x1000 >;
partial-erase;
#address-cells = < 0x1 >;
#size-cells = < 0x1 >;
flash0: flash@0 {
compatible = "soc-nv-flash";
erase-block-size = < 0x1000 >;
write-block-size = < 0x4 >;
reg = < 0x0 0x100000 >;
partitions {
boot_partition: partition@0 {
label = "mcuboot";
reg = < 0x0 0x10000 >;
slot0_partition: partition@10000 {
label = "image-0";
reg = < 0x10000 0x40000 >;
slot0_ns_partition: partition@50000 {
label = "image-0-nonsecure";
reg = < 0x50000 0x30000 >;
slot1_partition: partition@80000 {
label = "image-1";
reg = < 0x80000 0x40000 >;
slot1_ns_partition: partition@c0000 {
label = "image-1-nonsecure";
reg = < 0xc0000 0x30000 >;
The overlay has:
fstab {
compatible = "zephyr,fstab";
lfs: lfs {
compatible = "zephyr,fstab,littlefs";
mount-point = "/lfs";
partition = <&littlefs_storage>;
automount;
read-size = <16>;
prog-size = <16>;
cache-size = <64>;
lookahead-size = <32>;
block-cycles = <512>;
/delete-node/ &storage_partition;
&mx25r64 {
partitions {
#address-cells = <1>;
#size-cells = <1>;
littlefs_storage: partition@0 {
label = "littlefs_storage";
reg = <0x00000000 0x00200000>;
lvgl_raw_partition: partition@200000 {
label = "lvgl_raw_partition";
reg = <0x00200000 0x00200000>;
settings_partition: partition@400000 {
label = "settings_partition";
reg = <0x400000 0x100000 >;
My prj.conf has this in it:
# Enable Flash CONFIG_FLASH=y CONFIG_FLASH_MAP=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n CONFIG_NORDIC_QSPI_NOR=y # file system CONFIG_FILE_SYSTEM=y CONFIG_FILE_SYSTEM_LITTLEFS=y
Here is the memory report:
