Hello support team,
i have an issue regarding the i2c configuration on an nrf52832.
The Setup is:
- EvalBoard nrf52dk_52832
- BME280 Sensor attached via I2C
- NCS 2.6.1
- Using a modified i2c devicetree
- changed pinctrl of i2c0 node
- For the Test we used the Zephyr's I2C and Sensor Shell to query the bme280
The Problem is:
- P0.4/P0.5 as SCL/SDA does not work, wheras P0.27/P0.28 does work
With P0.26/P0.27
i2c scan i2c@40003000
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- 76 --
1 devices found on i2c@40003000
With P0.4 and P0.5
70: -- -- -- -- -- -- -- --
0 devices found on i2c@40003000
Here are the corresponding registers:.
I ensured that the wiring is not the problem through interchanging of the scl/sda lines
Perhaps there is a restriction on these pins.
I attached the devicetree we used for this test.
Let me know if you need more information.
Roman
