CMakePresets to west build arguments
Dear Nordic support team,
We are using the SDK v2.6.1 to build targets for nRF52840 chips, and are using multiple configurations defined in a CMakePreset.json file.
It works well with the nRF Connect extension for VS Code.
However for CI / CD needs, we don't want a GUI to build our targets from command line, and I cannot find a way to do so without copying the lines provided in the 'Output' of the nRF Connect extension, such as:
[10:35:49] west build --build-dir /home/aurelien/anderson/embedded_app/build_hw04 /home/aurelien/anderson/embedded_app --pristine --board hw04 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/home/aurelien/anderson;/home/aurelien/anderson/embedded_app;/home/aurelien/anderson/paakeazy_projects/io_test;/home/aurelien/anderson/paakeazy_projects/audio_recording -DFOTA_UPDATE=TRUE -D_CMAKE_PRESET_NAME=build_hw04 -Db0_OVERLAY_CONFIG=/home/aurelien/ncs/v2.6.1/nrf/subsys/partition_manager/partition_manager_enabled.conf -Dmcuboot_OVERLAY_CONFIG=/home/aurelien/ncs/v2.6.1/nrf/subsys/bootloader/image/multi_image_mcuboot.conf;/home/aurelien/ncs/v2.6.1/nrf/subsys/bootloader/image/fw_info.conf;/home/aurelien/ncs/v2.6.1/nrf/subsys/bootloader/image/build_s1.conf;/home/aurelien/ncs/v2.6.1/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf;/home/aurelien/ncs/v2.6.1/nrf/subsys/partition_manager/partition_manager_enabled.conf;/home/aurelien/anderson/embedded_app/child_image/mcuboot.conf -Ds1_image_OVERLAY_CONFIG=/home/aurelien/ncs/v2.6.1/nrf/subsys/partition_manager/partition_manager_enabled.conf -Dmcuboot_CONFIG_BOOT_SIGNATURE_KEY_FILE="/home/aurelien/anderson/embedded_app/signature_keys/mcuboot-priv-rsa.pem" -DCACHED_CONF_FILE=/home/aurelien/anderson/embedded_app/prj.conf -DEXTRA_CONF_FILE=/home/aurelien/anderson/embedded_app/mcuboot_active.conf;/home/aurelien/anderson/embedded_app/overlay-secure-boot.conf
All the 'west build' parameters are already written in the .json file, it would ease the maintainability not to copy them and only rely on the .json file to perform pristine builds from command line.
How can I do that ? VSCode does it, so I'm guessing this is possible.
Thanks in advance,
BR
Aurélien
  • Hi Aurélien,
    You can build using a preset by adding the --preset flag to the build command:
    west build -d ${targetDir} -- --preset ${presetName}
    For example, if you have a build directory called build_dir and the following preset with the name my_preset:
        "version": 2,
        "cmakeMinimumRequired": {
            "major": 3,
            "minor": 20
        "configurePresets": [
                "name": "my_preset",
                "displayName": "Build for nRF7002 DK nRF5340 application MCU",
                "generator": "Ninja",
                "binaryDir": "${sourceDir}/build_dir",
                "cacheVariables": {
                    "NCS_TOOLCHAIN_VERSION": "NONE",
                    "BOARD": "nrf7002dk_nrf5340_cpuapp",
                    "CACHED_CONF_FILE": "${sourceDir}/prj.conf"
    Then you can use the following command to build on command line using the preset:
    west build -d build_dir -- --preset my_preset
    Make sure that the build directory in the preset (binaryDir) matches the build directory provided in the west build command.
    Marte
  • Thank you for the reply, it seems very promising, but I need some additional help for this issue
    My arborescency looks like this:
    main_folder
        |_ project_1
            |_ CMakeLists.txt
            |_ CMakePresets.json
            |_ source files
        |_ project_2
            |_ CMakeLists.txt
            |_ CMakePresets.json
            |_ source files
        |_ boards / arm
            |_ hw01
                |_ board.cmake
                |_ hw01_defconfig
                |_ hw01-pinctrl.dtsi
                |_ Kconfig.board
                |_ [...]
            |_ hw02
            |_ hw03
    In the VSCode config, the boards we defines can be found in the different projects thanks to the following parameter:
        "nrf-connect.boardRoots": [
            "${workspaceFolder}/boards",
            "${workspaceFolder}/project_1/boards",
            "${workspaceFolder}/project_2/boards",
    But when I go to main_project/project_1 and I enter the west command it cannot fine the defined boards :
    CMake Error at /home/aurelien/ncs/v2.6.1/zephyr/cmake/modules/boards.cmake:167 (message):
      Invalid BOARD; see above.
      /home/aurelien/ncs/v2.6.1/zephyr/cmake/modules/zephyr_default.cmake:129 (include)
      /home/aurelien/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      /home/aurelien/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:18 (find_package)
    FATAL ERROR: command exited with status 1: /snap/bin/cmake -DWEST_PYTHON=/home/aurelien/ncs/toolchains/2be090971e/usr/local/bin/python3.9 -B/home/aurelien/main_project/project_1/build_hw03 -GNinja --preset build_hw03 -S/home/aurelien/main_project/project_1
    How can I add the path to the boards directory in the shell environment so west is able to find it ?
    Please note that the "board" is set in the CMakePresets, for instance :
                "name": "build_hw02",
                "displayName": "Build for hw02",
                "binaryDir": "${sourceDir}/build_hw02",
                "cacheVariables": {
                    "BOARD": "hw02",
                    "CONF_FILE": "${sourceDir}/prj.conf",
                    "_CMAKE_PRESET_NAME": "${presetName}"
    Many thanks for your precious support.
    Best regards
    Aurélien
    You can add BOARD_ROOT to the CMakeLists.txt or the build command.
    With west build:
    west build -b my_custom_board -- -DBOARD_ROOT="board_root_path"
    In CMakeLists.txt you must make sure to add the BOARD_ROOT before find_package:
    list(APPEND BOARD_ROOT board_root_path)
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    Note that the board root is the directory that includes the boards directory. In your example with main_folder/boards/arm/hw01, the board root will be main_folder.
    Marte
  • Works like a charm, thank you.
    Aurélien
