Help with Pairing for non-display device
I recently started upgrading an nRF chip on old SDK to the latest nRF Connect. The device has only one button and currently uses a static passkey (written on the device) while advertising constantly.
I want to make the following updates:
  1. Limited advertising (advertise only when requested for a set period of time) - This works in my proof-of-concept.
  2. Confirm pairing using a button press or another unique method.
  3. Remove the static passkey.
I am able to send a feedback from the device to the nRF chip; however, when attempting to skip the static passkey, I do not achieve security level 3/4 during pairing. Is it possible to configure the chip to acknowledge that the pairing is confirmed/accepted using the button? What approach would you advise?
    You can take a look at Bluetooth: Peripheral UART
    Amanda H.
  • Thank you Amanda, this seems to be what I'm looking for. I'm still having slight problem applying it to my setup.
    I'm not receiving the .passkey_confirm callback, its seems my project is expecting me to input the random passkey generated. I'm getting the .passkey_display callback.
    What can be the cause of this, we are not using NUS if that is something, here is copy of my poc .cfg file
    Is the application based on the Bluetooth: Peripheral UART? If so, to confirm pairing or bonding, press Button 1 on the device and accept the passkey value.
    We are currently understaffed due to the summer vacation period, so delayed replies must be expected. I am sorry about any inconvenience this might cause.
    -Amanda H.
  • Hi Amanda,
    I'm just grateful for any assistance, I do understand it might take some time! Slight smile
    We are trying have this in our own project using the Peripheral UART example. These are the callbacks that we define:
    We send the "button feedback" from a different MCU, through the SPI interface. But as the "auth_passkey_confirm" is never called, the button functionality isn't doing anything at the moment - the implementation is similar to the UART example.
    The only thing I can see quickly is that I'm not using the NUS services.
    Would it help if I sent you the project?
    Could you provide the sniffer log and the device log?
    What NCS version are you using?
    You can upload the project if it's possible.
    -Amanda H.
