I have seen a few posts including:
- Change advertised name (Bluetooth) - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com)
- NCS bt_set_name() - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com)
- Setting Bluetooth Device Name in Zephyr - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com)
but I still haven't been able to adapt one of the examples to show the name dynamically.
This is the code:
#include <zephyr/kernel.h>
#include <zephyr/bluetooth/gap.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/conn.h>
#include <dk_buttons_and_leds.h>
#include <stdio.h> // For snprintf
#include <stdlib.h>
#include "ble_manager.h"
LOG_MODULE_REGISTER(ble_manager, LOG_LEVEL_DBG);
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
/* STEP 2.1 - Declare the Company identifier (Company ID) */
#define COMPANY_ID_CODE 0x0059
/* STEP 2.2 - Declare the structure for your custom data */
typedef struct adv_mfg_data {
uint16_t company_code; /* Company Identifier Code. */
} adv_mfg_data_type;
/* STEP 5.1 - Create the advertising parameter for connectable advertising */
static struct bt_le_adv_param *adv_param = BT_LE_ADV_PARAM(
(BT_LE_ADV_OPT_CONNECTABLE | BT_LE_ADV_OPT_USE_IDENTITY), /* Connectable advertising and use identity address */
800, /* Min Advertising Interval 500ms (800*0.625ms) */
801, /* Max Advertising Interval 500.625ms (801*0.625ms) */
NULL); /* Set to NULL for undirected advertising */
/* STEP 2.3 - Define and initialize a variable of type adv_mfg_data_type */
static adv_mfg_data_type adv_mfg_data = { COMPANY_ID_CODE, 0x00 };
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, BT_LE_AD_NO_BREDR),
//BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
/* STEP 3 - Include the Manufacturer Specific Data in the advertising packet. */
BT_DATA(BT_DATA_MANUFACTURER_DATA, (unsigned char *)&adv_mfg_data, sizeof(adv_mfg_data)),
static unsigned char url_data[] ={0x17,'/','/','a','c','a','d','e','m','y','.',
'n','o','r','d','i','c','s','e','m','i','.',
'c','o','m'};
static const struct bt_data sd[] = {
BT_DATA(BT_DATA_URI, url_data,sizeof(url_data)),
static void connected(struct bt_conn *conn, uint8_t err)
if (err) {
LOG_ERR("Connection failed (err %u)\n", err);
return;
LOG_DBG("Connected\n");
LOG_DBG("Disconnected (reason %u)\n", reason);
BT_CONN_CB_DEFINE(conn_callbacks) = {
.connected = connected,
.disconnected = disconnected,
int ble_manager_init()
LOG_DBG("Starting '%s'", DEVICE_NAME);
int err;
err = bt_enable(NULL);
if (err) {
LOG_ERR("Bluetooth init failed (err %d)", err);
return -1;
LOG_DBG("Bluetooth initialized");
// Generate a random 6-digit number
unsigned int random_number = 100000 + rand() % 900000; // Ensures a range from 100000 to 999999
LOG_DBG("Random number: %d", random_number);
// Assuming random_number is already defined and holds a random 6-digit number
char device_name[18]; // Ensure this is large enough to hold the resulting string
// Create a formatted string with the random number
snprintf(device_name, sizeof(device_name), "DeviceName %d", random_number);
// Set the Bluetooth device name
bt_set_name(device_name);
LOG_DBG("Bluetooth device name: %s", device_name);
err = bt_le_adv_start(adv_param, ad, ARRAY_SIZE(ad),sd, ARRAY_SIZE(sd));
if (err) {
LOG_ERR("Advertising failed to start (err %d)", err);
return -1;
LOG_DBG("Bluetooth advertising");
return 0;
And this is the prj.conf:
# Logger module CONFIG_LOG=y # Button and LED library CONFIG_DK_LIBRARY=y # Bluetooth LE CONFIG_BT=y CONFIG_BT_PERIPHERAL=y #CONFIG_BT_DEVICE_NAME="TEST Peripheral" CONFIG_BT_DEVICE_NAME_DYNAMIC=y # Maximum chcaracter of the device name # (Range: 2 to 248) CONFIG_BT_DEVICE_NAME_MAX=17 # Increase stack size for the main thread and System Workqueue CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_MAIN_STACK_SIZE=2048
Is there something else I need to do either in the bt_data or in the bt_le_adv_start?
